Question about Cooktops
Ge cooktop burner does not get heated but hot sensor light goeson
The flat top might have a scratch on it.
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    to be sure you would do a voltage check from the switch.but i replace more burners than switches on those.and because the lite comes on that could indicate the switch works but its only half of the voltage[the lite only needs 110 to work
    Novelist:
  • 222 Answers
Common for the glass top have a scratch,coz this a glass it normal for every time u use coz the metal for the pots & pans are sharp for the glass.tnx gerbee
Posted on Jan 27, 2009
Burner light stays on
This is caused by a faulty sensor that is located between the burner element and the top. To replace the faulty part you will need to uninstall the cooktop and remove the glass top. The sensor is a rod a little smaller than a pencil that you will see right on top of that burner.
If you choose not to replace the sensor it will not cause any issues other than you will have to live with that light constantly on and you will know when the top is hot for that element.
Jun 19, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
GE Profile glass top cooktop- burners do not heat, indicator lights do work
If none of the burners are working but the pilot light does you are having a power problem and only getting 120 volts to it. Check the breakers to make sure they are on correctly. 240 volts is needed to operate the cooktop. Hope this helps. Rick
Mar 09, 2010 | GE Cooktops
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
How to remove burnt grease, fix lightly scratched black stovetop?
Hi, I assume we are talking about a flat glass top. First the bad news. using any abrasives will permanently scratch the glass hence the dull spot. You can however make it look a little better. Grease spots and the like can be removed with a flat razor blade scraper which needs to be held flat to avoid the corners making scratches. Use any good glass/ceramic cooktop cleaner ( which is the ONLY cleaner you should ever use ) (available in your local grocery diy store and some hardware stores). The cleaner is a thick liquid, put about a dime size drop on each burner area and use a paper towel to buff out the finish like waxing a car. Once it looks clean flip your paper towel over and shine the top to like new. Good Luck!
Jan 28, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
GE profile performance electric cook top is not producing enough heat in the front burners.
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Jan 23, 2009 | GE 30 in. JP340 Electric Cooktop
Burners of electric cooktop not getting red hot
Hello
Welcome,
Sounds like you have a bad surface heat controller.
Nothing to do but call a hands on tech to replace a part.
please remember to leave a rating before you sign off
Dec 11, 2008 | GE 30 in. JP340 Electric Cooktop
Ge profile electric counter top stove
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
May 01, 2008 | GE Profile JP930 Electric Cooktop
Plastic melted on my glass cooktop
didi you try heating the burner slightly to soften the plastic a bit before trying to scrape off, cant see any reason why that wouldnt work, using a razor blade held flat will scrape just about anything off of the glass tops!
Apr 29, 2008 | Jenn-Air JED8430 Electric Cooktop
Burner too hot
you set it fro low and goes straigt to high???? no adjustment in heat setting either of or high?? if so youll need to repalce the infinte switch controllins that burner
Mar 11, 2008 | GE 30 in. JP326 Electric Cooktop
Hot Surface Light stays on
Our success has been to heat the elements to hot for about 5 minutes. Then let cool to reset temp sensor.
Can cause the problem by turning a burner on for a short period of time
Dec 16, 2007 | Whirlpool GJC3034 Electric Cooktop
Cooktops Logo
268 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
