Positive negative wires for sansui s-700di
Black, unmarked wire makes it hard for me to identify which is the positive and negative cable
fcsr
  • 43 Answers
SOURCE: i have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Posted on Nov 14, 2008
  • 9 Answers
SOURCE: Is the third wire positive or negative going into the battery on a Kawasaki 1100zx jet ski?
Most lithium ion battery packs I have come across, that typically have three terminals, have a terminal to allow the charger to do one of two things. This terminal will give the charger circuit a temperature reading, or, it will give it a reference to allow for both cells to have a balanced charge. On the battery I used for one of my projects there was a board that measured the voltage across 3 different cells to prevent over charging, over current, and undervoltage conditions. Without
Posted on May 17, 2009
Benimur
  • 6966 Answers
SOURCE: 1985 Yamaha xj700 Maxim-I am
Hi and welcome to FixYa,
Pls see your other post, but basically:
  • in most, one end of the red wire is connected straight to the battery's + terminal. The other end of the red wire goes to the main fuse;
  • the black of course as you posted goes to the ground;
  • interchanging the 2 wires from the starter relay would make no difference;
  • the starter relay is not directly grounded;
  • the starter relay's + wire goes to the starter button;
  • the starter  relay's - wire goes to starter cut-off activated by safety interlocks (neutral and clutch lever).
Good luck and thank you for asking FixYa.
Posted on Jul 09, 2009
asnowman
  • 788 Answers
SOURCE: What is color coding for speaker wires on Teac
Yes you are right. The only thing that you need to be aware of is, that if the speakers are hookd up backwards they will be out of phase with each other. Keep the solid black on the negative and you will be OK.
I hope this information allows you to resolve this issue.
I am doing this for free.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Jan 09, 2010
Testimonial: "Great thanks for the advice. Silly sods who wrote the manual failed to say which wire was +. BTW, could it have messed it up if I'd wired it wrong?"
hazelgrace
  • 340 Answers
SOURCE: what is the blue wire for:; Is it positive or
Blue = Neutral, Brown = Live and you are correct Yellow & Green = Earth
The live wire (brown) must be connected to the fuse if there is one.
You could say that the blue wire is negative (or zero) and the brown wire is positive as this is the one the high current passes through. The blue wire completes the circuit, which is needed for current to flow.
Hope this helps!
Posted on Oct 13, 2010
Replace battery saturn sl1 1998
Disconnect the negative and positive battery cables from the terminals on the battery. Take that battery out. Now then buy another battery for you make and model. Put the positive and negative battery cables on the battery terminals of the new battery. MAKING SURE, you have them on the RIGHT CABLES ON THE RIGHT TERMINALS. POSITIVE --- (RED) as the NEGATIVE CABLE is ----(BLACK). If you get them mixed up and try to start the car or something. You will blow a ton of fuses. and no telling what else! Its not hard as long as you can read the (-) << NEGATIVE (BLACK) WIRE and (+) << POSITIVE --(RED) WIRE on the battery.
Jan 27, 2014 | 1998 Saturn SL
I bought a standard audio/video (red, white, yellow) RCA cable. I also bought a wall-mounting bracket (like a light switch wall mount, if you know what I mean). I didn't realize that the backs of the 3...
Okay on the bracket # 1 is positive, 2 is negative, 3 is positive and 4 is negative. Now the rca cable The copper wire is negative and the shielded wire is positive. Hope is this helps. please rate. thank you.
Aug 22, 2008 | Audio Players & Recorders
Would like a schematic or picture of battery terminals on 1995 fxds in order to identify positive and negative
The battery posts are identified with a + sign for positive and a - sign for positive.
Unless someone has changed the wiring, the positive wire should be red and run down to the starter and solenoid.
The ground (negative) should be black and run to a bolt on the frame.
Apr 10, 2011 | Harley Davidson FXDL Dyna Low Rider...
What wires hook to the positive battery cable, and the negative cable?
the red wire goes to positive terminal, the wire from starter-+ POSITIVE. black wire goes to negative on terminal - NEGATIVE. from ground to battery. have a good one !
Jan 29, 2011 | 1988 Acura Legend
I need help to identify radio wiring
Is this what you needed?
1986 Toyota Celica Car Stereo Wiring Information
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4?
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4?
Car Audio Rear Speakers Location: Side Shelves
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Oct 25, 2010 | 1986 Toyota Celica
Identifie radio wiring
1995 Ford Taurus Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Antenna Trigger Wire: Orange/Light Blue
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Dark Blue/Orange
Right Rear Speaker Positive Wire (+): Pink/Light Blue
Right Rear Speaker Negative Wire (-): Tan/White
pls rate
Jan 23, 2010 | 1995 Ford Taurus
I change my battery post now I don't know where they go on the - or + side can you help me out
Hello. Yes. the black wire is the ground wire. It goes from the frame to the negative post of the battery. The red wire is the hot wire and it goes to the positive post.
Nov 24, 2009 | 1994 Buick LeSabre
Ppi dcx 1500.1 is it 2 powerful 4 da 12in. L7?
Hello montyski20,
The amp outputs 500 watts RMS into 4ohms, 750 watts RMS into 2ohms and 1000 RMS into 1ohm.
The L7 can handle 750 watts RMS (375 watts per each coil). If your L7 is the 2ohm version, you should wire the voice coils in series, the positive marked coil to the negative unmarked coil. Then connect the remaining positive and negative to the amp terminals. This gives you a 4ohm load (500 watts). If your L7 is the 4ohm version, wire the voice coils in parallel, both marked and unmarked positives together, likewise both negatives and then to the amp terminals. This gives a 2ohm load (750 watts).
Paralleling the 2ohm sub will result in a 1ohm load (1000 watts) and that is too much for the L7.
Hope this helps.
Aug 02, 2009 | PPI DCX-1500.1 Car Audio Amplifier
Hook up for an AR 404 receiver
Copper is positive, aluminum is negative. OR One of the wires should have a white (or black) stripe on the insulation...this is negative wire. OR If using 18 gauge extention cord wire, the positive wire will have small grooves running the entire lenght (very difficult to identify, unless you have good eyesight) Hope this helps.
Jun 11, 2009 | Kenwood AR-304
8 wires on my subwoofer??
"One has positive and negative input, another positive and negative output (red and black on each)"
Just from your description, it sounds like pos/neg input are the 12 volt pos neg supply for the amp inside the subwoofer. Red is pos, black is neg.
"positive and negative output (red and black on each)"
This sounds like it's used if you want to proved 12 volt pos/neg to another component.
"and a third wire with left input right input positive and negative (blue, red, yellow and black)"
This is for the cables coming from the "subwoofer out" on the amp. This is 4 wires altogether -- correct?
May 08, 2009 | Audio Players & Recorders
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
