Question about Frigidaire FEF366BC Electric Kitchen Range
No power to erc on oven
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Have you checked the breakers? Do you get anything at all on the display?
Posted on Jan 21, 2013
I have a flashing code on my kenmore electric oven, model 911.47709200. the code is F7 dc, what does it mean?
Stuck Keypad. Roper ovens with 2 Digit Displays:
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Oct 25, 2011 | Ovens
Ge double wall oven, model number jkp26gotibb has an f1 error code. Part is no longer available. Is there any other way to fix this problem with out replacing the whole oven.
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 16, 2010 | GE Built-In 24" Double Electric Wall Oven
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F7 Shorted Touch Panel Replace Glass Panel
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
Dec 18, 2009 | Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
What does an F1 fault indicate
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC) * Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
Jun 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore model # 911-494-79790
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
May 11, 2008 | Kenmore 30169 Electric Single Oven
Frigidaire FEF366BC Electric Kitchen Range Logo
35 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
