Question about Logitech QuickCam Express Web Camera
My mic hisses and cracks, annoying others in the chatroom...
I get a loud wail, a hiss , and cracks whenever starting i try to voice chat with anyone and even when i run a hardware test i get the same result. also when i run the test, my volume automatically jumps to full volume and i cant ajust it without it moving right back up.
  • 12,061 Answers
Try another driver for your camera... and or another connection port? Also try it on another PC see if the fault "follows you" as it were..
Posted on Jul 18, 2007
SOURCE:
How can I reduce white noise / hissing I'm getting over the mic on a Behringer Xenyx 1204 USB setup?
Hi, you didn't say if the mic actually passes sound? The C-1 is a condenser Mic & needs phantom power - switch on the rear of your mixer. If that's no help, what happens if you disconnect the mic, then turn the levels back up? Still hissing or gone? If it's gone then it's the Mic - must use a 3 wire cable, preferably XLR so it gets the phantom power. If the hiss is still there without the Mic then sounds like the mixer is faulty - try some of the other channels..... How loau is the hiss - just in the background or as load as a vocal "one, two" test? A few things to check anyway...... Good Luck!
Dec 01, 2016 | Behringer Music
I got a rode classic II with avalon m5 mic pre. So when i crank up my mic pre to 60 n i can start listening some hissing from my monitor...or is it normal for a valve mic coz when after recorded with this...
The hiss is caused by your monitor system level and your preamp gain being so high. At high gain settings, a preamp is going to get noisy, and tube mics have a higher noise level to begin with.
If you can't hear it on your recordings, then it's not a problem.
Sep 17, 2011 | Rode Classic II Professional Microphone
Model C-60 Yamaha organ. Loud hissing sound
This is likely in the power amp or the drivers for it.
The key to troubleshooting is a schematic. Try to procure one.
You MIGHT try using circuit cooler in the area of the power amps to isolate a bad component or cracked circuit board.
Mar 10, 2010 | Yamaha Music
Hiss noise
its never normal for your phone to make sounds other than what you want it to make. try lowering the speaker volume to the lowest setting but still allow yourslf to be able to hear. check to see if its still making the sound. if so try getting your music from a diffrent source. if that also fails try voice record if its avalible on your model phone. play voice listen for the unwanted noise. reason for this is to narrow the problem . how long has the phone done this?
your phone speaker is most likely the problem seeing that even the phones own tones has a static sound.
could have blown speaker .
Nov 15, 2009 | Nokia 3110 Cellular Phone
I am getting a lot of hiss when I record low
it is not a problem there are many problem
Aug 23, 2009 | PreSonus Computers & Internet
Loud hissing through rear (souround sound) speakers
I have the Sony Bravia KDL-46S4100. The high-picthed hiss drives me insane. I have a work around but not a fix. Go into your TV's menu and find BACKLIGHT. Adjust it from 1-9 with the house quiet and find what frequency of the hiss is the least annoying.
Sony Bravia high pitch hiss hissing sound high frequency
Nov 22, 2008 | Audio Players & Recorders
Switched from a g4 PowerPC to a g5 Intel Imac and now Mic has a lot of digital hiss
the Samson C01U picks up the noises running inside the computer, or laptop whichever you have. You can't change that. But if you want to get rid of it. I use Cool Edit Pro. There's this effect we have for Noise Reduction. I won't go further on unless you have this program, or something similar. But basically it takes out any unwanted static
Aug 30, 2008 | Samson C01U - USB Studio Condenser...
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
Hissing from one of the two NT5 mikes
have you concluded that it is 1 of the mics?if mics are ok you need to purchase a mic pre.
May 28, 2007 | Rode NT5 Professional Microphone
My nokia's hissing at me!!??
Replace the mic .Then problem persist Check filtering circuits of Speaker
Dec 13, 2006 | Nokia 6230
Logitech QuickCam Express Web Camera Logo
63 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
