How can I fix hardwood floors with water damage?
Slight buckling in floors
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
Use small finish nails and countersink. Then get sawdust and mix with glue to fill the countersinked nails. Sand floor as needed and apply finish.
Posted on Jan 21, 2013
Which is better between hardwood floor or laminate floor??
I think.. hardwood is much better than laminate wood flooring, but each type of flooring has its advantages and disadvantages. Hopefully this article can help you to choose the floor you want.
Main Differences Between Hardwood And Laminate Flooring
Jul 31, 2015 | Building Materials
Can I safely use the Shark pro Steam Pocket mop S3601 on dark hardwood floor?
You will not hurt your finish by using the steam mop...use it without any type of cleaner on the mop head and you should get a great streak free shine...
Jan 07, 2015 | Shark Vacuums
Remove mold on hardwood floor
Spray the oak floor with a 50% solution of white vinegar solution mixed with water and let stand for an hour, then clean with hot soapy water. Alternatively clean the floor with a steam mop, as either method will kill the mould on your floor.
May 24, 2014 | Shaw Solid Hardwood Floor 2 1/4" x 3/4"...
What are the differences between bamboo and solid wood floors?
Bamboo is much more environmentally friendly than solid wood as bamboo regenerates in time. Moreover, bamboo is harder than some solid woods such as red oak and black walnut.
Feb 06, 2013 | Building Materials
What are the advantages of laminate flooring over hardwood flooring?
First, you can get the exact visual design that you wanted and it will cost you considerably less. Second, laminate flooring can be installed above and below the grade unlike hardwood flooring. Moreover, the laminate flooring is installed without using any nails or glue which make it much easier to it yourself. Furthermore, laminate flooring is extremely durable, easy to maintain and can be replaced easily.
Leaking under left side. water lines ok. too close to ground to see where water is. hardwood kitchen floor is buckled. ice maker is putting out too much ice and falling out onto shelf. what do i need to...
It sounds like the water tray for the defrost mode is full, you need to check if the tray has moved or maybe the door rubber are not sealing and this will cause extra ice built-up, and will cause the leak.
Jun 02, 2011 | Refrigerators
Hardwood floor cleaner
Yes, you can use the Bruce hardwood floor cleaner. I've used it many times to clean up after jobs. It brings a nice shine to the floor and is designed for either a hardwood or laminate floor. Hope this helps.
Apr 19, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Can you use irobot Scooba on laminate floors?
they are suppose to be hardwood floor safe but maybe you should call the manurfacturer and make sure
Mar 21, 2009 | iRobot 5800 Scooba Vacuum
Orech scratching hardwood floor ???
I would recommend using another cleaning method developed for use on hardwoods. It seems to me like even if you replace the wheels, eventually they will wear down again, causing more damage to your floors. Check home depot, ask them what the recommend. Hope I could help.
Jan 27, 2009 | Oreck XL2200 Bagged Upright Vacuum
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
