I need to reset the time & date on my printer
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
What make and model printer?
Posted on Jan 21, 2013
Press Setup. Press Basic Settings. Press Date & Time. See page 64 of this manual.
Jan 21, 2013 | Used Hp Officejet J4580 All In One Printer
How do you reset time & date
There are several ways depending on your phone model. You could go to "menu"then choose "settings" then choose "time & date." from there you may reset the time and the date.
Hope this one helps.
Oct 06, 2010 | Lands Phones
HOW DO I SET TIME AND DATE?
The Date & Time have been reset message appears after the Language screen the first time you turn on the camera. It may also appear if the batteries are removed for an extended time.
  1. SET DATE & TIME is highlighted. Press the OK button.
    (Select CANCEL to set the date and time at a later time.)
  2. Go to Step 4 below, Setting the date & time, anytime..
  1. In any mode, press the Menu button.
  2. Press autourg00205001id1456505.jpg to highlight Setup Menu autourg00205001id1561971.jpg, then press the OK button.
  3. Highlight Date & Time, then press the OK button.
  4. Press autourg00205001id1474816.jpg to adjust the date and time. Press autourg00205001id1474821.jpg to advance to the next setting.
  5. When finished, press the OK button.
  6. Press the Menu button to exit.
Aug 27, 2010 | Kodak Cameras
I have reset the time on my printer and when I print a document that correct date/time are printed correctly BUT the date at the bottom of a printed page is incorrect. This would be the date that the...
the real date is printed from the computer and the wrong one is the default date from the printer...What you have to do is to get into the settings and correct the date into the printer..Look for the time and date in the main menu ..and select and correct it ..After that restart the printer and the problem will be gone ..This may be an issue resulted from a total reset made or a failure of the internal battery ..
If the dat ewill not be kept set after you correct it ...it means the internal battery need to be changed cause when it is unplugged it will not hold the settings ..
Aug 23, 2010 | Dell Dimension 4600 PC Desktop
How do I reset the time on a Panafax UF 490
At standby the display will show the date and time. Once the standby display is set, it will automatically be
updated.
General Description
Setting the Date and Time
SET MODE (1-8)
2 USER PARAMETERS?
3 DATE & TIME?
4 01-01-2001 15:00
5 Enter the new date and time.
Ex: Date : 10th
December: 12th
Year : 2001
Time : 3:00 PM
If you make a mistake, use or to move the cursor
over the incorrect number, then overwrite it with a correct
one.
10-12-2001 15:00
6
7
1 2
2 0 0 1
1 5 0 0
Mar 24, 2010 | Panasonic PanaFax UF-490 All-In-One Laser...
How do i reset the entire system back to default? Previously someone had put an admin lock on it so now i cant use it properly and i need to reset the menus.
Hi
· It is called the Cold reset
A cold reset resets the values of permanent storage variables back to factory default. Often this is
necessary for clearing the HP MFP Digital Sending Server IP address.
The following items are cleared during a cold reset:
● Embedded Jetdirect IP address
● SMTP IP address
● LDAP IP address
● Embedded Web server password
● All control-panel configurable items
The following items are NOT cleared during a cold reset:
● Local address book e-mail addresses
● Real-time clock (date and time)
● Page counts and maintenance counts
● Product serial number and formatter number
● Service ID
● Event log
To perform a cold reset
1. Turn off the digital sender.
2. Turn on the digital sender.
3. While the product is performing its memory count, hold down the #6 key. When the three status
LEDs are illuminated, release the #6 key.
4. Press the #3 key four times until the display shows COLD RESET.
5. Press the #6 key once to initiate the cold reset. The product will continue its boot-up sequence.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2010 | HP Digital Sender 9250c scanner Printer
Can't figure out how to reset date/time/header information on faxes & reports.
After you change to fax mode, press menu and then general setup for the date and time. After that you scroll down to fax setup to change the header.
Oct 16, 2009 | Brother Multi-Function Center MFC-240C...
Thinkpad R40 find date & time for start-up
Right-click the time in the lower right, select: adjust date and time, select: internet time, select either source, select: apply (if high lighted)--otherwise close. You need to be connected to the internet for the internet time to work.
Sep 18, 2009 | IBM ThinkPad R40 2722 Notebook
Date & Time Stamp
The date is printed on the photos using the "pict bridge" software. The date printing option is set on the computer, not the camera. If the printer has it disabled or it is a printer that doesn't support it, you won't get the date.
Jun 19, 2009 | Fuji Finepix Z20fd Digital Camera
12 people viewed this question
jasbo
jasbo
