My computer seems to be trying to boot from a network rather than from computer.It show a black screen with a message that says"pxe boot file not found" and system won't boot up.
  • 413 Answers
You have to change the boot settings in bios Follow this link and it will give you the keystrokes needed to enter bios and show how to change the order
Thanks for using fixya and please don't forget to rate the solutions
Posted on Jan 26, 2009
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
It was working good all of sudden screen became black and the PXE E61
It seems to have lost communication with the hard drive. Check physically (pop out and then back in) and in BIOS. Make sure its the 1st boot option.
Also disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option.
Sep 30, 2012 | Acer Computers & Internet
When turn on computer NO WINDOWS XP .On the screen was PXE-E53 : No boot file name received PXE-MOF: Existing Broadcom PXE ROM Operating System not found
That means your computer trying to boot from LAN port. Go bios and change the settings of PXE boot to disable and make Hard disk as first boot device. Save the settings and restart your pc. It will work
Mar 31, 2011 | Acer TravelMate 4101WLMi Notebook
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
Black screen with info that pops up immediately upon booting up
That sort of message comes up when your computer is unable to boot to the hard drive. Those messages basically mean that it is trying to boot from a network, (which it isn't hooked upt to). Your hard drive could have failed, or your boot sequence could have been inadvertently changed too.
First, make sure your thumb drive is not installed in the laptop, as this can cause the problem too.
You can check your boot sequence by rebooting your computer, and entering the BIOS, usually by hitting F1 or F2 on start up. Tab over to the Boot section, and see what the boot order is: Usually it should be: CDROM drive, Then Hard drive, then removeable drives.
If this is ok, check and make sure that your hard drive is showing up in the BIOS on the main page too.
If not, it might be bad....
Hope this helps!
Apr 23, 2010 | Toshiba Satellite X205-SLI1 Notebook
When I boot up my computer I got Black screen saying "Yukon PXE V3. O5 beta 01 (20041028)" and "PXE-61: Media Test failure, check drive" as well as "PXE-MOF:Exiting PXE ROM" which keep pop up. HOw do I...
These messages are usually associated with a computer trying to boot off a network. In your case, your computer is not able to boot off of the hard drive, or CD, so it is looking for anything to boot off of. This means that your hard drive has failed or the boot sector is corrupt. To fix it you either need to reload windows, and or possibly replace the hard drive too.
First, though, you should check the system date and time to make sure they are correct. A bad system CMOS battery could affect your booting process too.
Jan 14, 2010 | Toshiba Tecra S2 Notebook
My tosiba a70-kl1 starts up with a black screen and error messages stating "PXE-E61: Media tes failure, check cable" and "PXE-M0F: Eiting PXE rom"
You haved enabled the capability for your computer to "boot" itself by reading from a boot-server connected to your network-cable.
But, the network-cable is unplugged, resulting in the "check cable" message.
What this _could_ mean is that the computer primarily tried, and failed, to boot from your disk-drive, and secondarily tried, and failed, to boot from your CD-ROM, and so it made a tertiary triy, which failed, to boot from the "network", i.e., that your hard-drive is not functioning.
Reboot, and enter "BIOS setup", and disable the "boot from network" option, to get rid of those error-messages. But, it's still possible that your disk-drive is malfunctioning.
Sep 14, 2009 | Toshiba Satellite A70 Notebook
System will not boot up
Hi there
Hit F2 on boot up and go into the Bios settings, look for the boot order and change it to HDD as first boot device, hit F10 and save and exit.
The PC will restart and should boot into the hard drive.
Good luck
Jan 26, 2009 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
I’m almost positive that you have a bad hard drive. PXE means Pre-Boot Execution Environment.
If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) to start your system from harddisk.
when the hard drive has failed, the system cannot detect it and tries to boot from the next available device – the network card. Your system is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error. You have to replace the hard drive and reinstall the operating system.
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know wheter the information i given you is helpfull or not
Apr 26, 2008 | Intel Motherboard
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
483 people viewed this question
David Payne
David Payne
