Question about Toshiba TP50F60/61 TV
BLINKING POWER LIGHT
TV WILL NOT COME ON WHEN YOU TURN IT ON THE POWER LIGHT JUST BLINKS I TOOK THE BOARD OUT THAT HAS THE REMOTE SENSOR ON IT AND BEHIND THE REMOTE SENSOR THERE ARE TWO TUBE LIKE PIECES ONE IS WHITE TESTS GOOD THE OTHER IS A DARK GRAY COLLORED AND HAS NO POWER WHEN TESTED AND LOOKS LIKE IT IS BLOWN NEED TO KNOW THE NAME OF THIS PART SO I CAN TRY TO FIX MY TV
  • 6 more comments
  • CHARLES ALLEN Jul 20, 2007
    ttech if you are checking I have Model TP5F60 and I really appreciate any help you can give on this my husband is disabled and he misses his tv
  • Anonymous Jan 04, 2008
    I have a Toshiba 42HP95 and all it does is blink the red led. Power supply seems to have1 some poweer but does not switch on to power the full TV.Power supply is 1H277W. A C Detect is 3.5 volts. The panel standby is 5.2 volts and there is also 5.2 volts available from pin 2 on P803 of main power board. No other voltage is available. When plugged in Relays are working but power switch has no effect whatsoever. The red light blinks and the set is dead. Any help will be appreciated. I have the service manual but no schematic of the main power supply.
  • Anonymous Feb 27, 2008
    I have a tp50f60 with the same problem (blinking red light, no picture). I change the HOT transistor 2sD2253 or Toshiba part number 23314713, it is attached to the Heat sink. Radio Shack was used to sell it at $2.34 but not any longer. You can find it for around $20.00 It have three welded conections. God bless..
  • contender05 May 07, 2008
    TV went out, would't turn on. We found a lose cap and re-soldered it. Worked for about a month. Then it started with wavy lines, blue dots, red dots, white squares, red squares, etc. Then it would go out with blinking power light. We found if we unplugged it and plugged it back in, it would work for 10 -20 minutes. Read your suggestions / ideas about convergence and replacing IC's. After adjusting convergence we have decent picture. Time will tell if it's a fix. Still may need to place convergence IC's. Where are they located? Keep you posted, thanks...SF3
  • Anonymous May 12, 2008
    We have a Toshiba TP50F60 and we're experiencing the same problem of blinking power light problem and it won't come on. We've unplugged it for a couple of days and plugged it back on the same thing. Help!!!
    Randy
    My wife and I own an Toshib TP50F60 and it won't come on all we get is that blinking red power light. We've unplugged it for a couple of days and plugged it back up the same thing. Help!!!
    Randy D
  • alfie1320 Jun 30, 2008
    The tv comes on and last for 2 minutes and then goes off. The power button just blinks red, any suggestion. Thanks, Lois
  • Anonymous Jan 02, 2009
    no picture just blinking power light
  • 139 Answers
Muddy,No,The Problem lay in the Power Supply Delection of your Set Please summit me a Model #
Posted on Jul 19, 2007
Sony Screen wont turn on. Replaces tcon. No Power going to tcon.
Hi Nick, Please trace the 12V line. Most probably it is coming from the main board.
Dec 10, 2016 | Sony Televison & Video
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
When the tv is turned on with the remote control,the red sensor light turns into green and blinks 10 times and the tv comes on, but it goes off immediately.As it turns off ,the sensor light turns into red...
Hi, my name is John. Welcome to FixYa. You have a problem in the D board. I will post what you need to check here, such as the transistors, capacitors etc. thanks for choosing FixYa....John
Nov 30, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Hl-s4266w Powers on for about 15 seconds then turns off. Was told it is a timer that needs to be turned off by using factory remote - I have lost the remote! now what?
Not sure about the timer. Our 55" samsung broke last week and it was shutting on/off no picture just turn on music recycling off/on. The blue light was lite on TV and red light to the right was blinking. The TV repair guy replace the Power Supply board b/c of swollen capacitors, was under warranty. The board runs about 70 bucks though. Took him all of 5 mins after unscrewing the back cover of TV. The board is at the bottom center after cover is removed. Hope this helps
Mar 18, 2010 | Samsung HL-S4266W 42" HDTV
Red blinking light when tv is turned off
You can't fix it. There is a bad board in this set; either the main board or the power supply board. You'll have to call a professional.
Mar 30, 2009 | LG 37LC7D 37 in. LCD HDTV
RCA R52WH74 power light blinks but no power
i unfortunately cannot help you with your problem, but i have a question, how did you disconnect the front panel?
Mar 24, 2009 | Televison & Video
I have RCA HD50LPW167 DLP TV with NO Sound and NO Audio. The LED blinks when I turn the TV on but that's all it does. Took it to the local RCA authorized repair shop and they told me that the digiital...
Still sounds like a lamp:
TV won’t turn on
• Press the TV button or ON/OFF button while remote is in TV mode and there’s a source of power to the outlet or outlet strip.
• Make sure the TV is plugged in.
• You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
• Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or fl ashing
section below for more information.
• When you fi rst plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when power is reapplied to the TV. The TV can only be turned
on after the Power indicator goes off.
• Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else, such as a lamp.
• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 84.
Remote Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Connections, then Special Features, then
Remote Setup. Choose TV (default).
Power indicator is blinking or fl ashing
If the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on. If the TV doesn’t turn on after 5 minutes and
then the light blinks steadily for one minute, one of the following options is possible:
• Lamp door may be open.Face the back of the TV. Locate the door at the bottom of the TV and close it. Turn off the TV and turn
back on. The lamp should turn on.
You can easily replace the lamp yourself by following the lamp replacement instructions. If your TV is still covered by
the warranty, call 1-866-723-6486 to receive troubleshooting assistance and a lamp replacement.
• If your TV’s warranty has expired, call 1-800-338-0376 to purchase a lamp replacement.
To order the correct lamp, you’ll need to know your TV’s model number, serial number, and lamp type—this
information is listed on the Service Model Number sticker (example of the sticker is shown above). Face the back of
the TV. The sticker is located on the right side of the TV.
Hope this helps :)
Mar 07, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Televison & Video Logo
410 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
