Question about Kenmore 15864/15862 Top Load Washer
AGATATOR NOT WORKING PROPERLY
I HAVE A KENMORE SERIES 90 AND THE AGITATOR DRIVE EICES ARE WORN OUT. I SEE THE PARTS ON YOUR SITE BUT HOW DOES IT COME APART SO I CAN REPLACE THEM? I HAVE THE TOP CAP OFF AND CAN SEE THE CAM GEARS BUT DONT SEE HOW THAT COMES APART.
  • Anonymous Jan 28, 2009
    I have excess noise with the aggitator, all parts are worn. no solution found other than ordering new part and replacing worn parts out...
  • 130 Answers
After the top is off you should pull off a cap. Then I usually will take the not off and pull the upper portion of the agitator off.
Posted on Jan 26, 2009
The agator is popping up
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It's possible that the plastic bolt that holds the agitator on the drive tube is loose or damaged.
Look at the section on the Sears site for Agitator, basket and tub.
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
If it's loose, use a 1/2 inch extension for a socket set to tighten it.
Also see the following illustrated description of how to get to it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Dec 03, 2010 | Kenmore 24872 Top Load Washer
Kenmore 90 series 11026912690, agitator makes loud noise
If the problem is just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers (such as Kenmore) use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. These parts are commonly sold as part of their in-store inventory.
NOTE: Other causes can include a broken motor coupling, bad gearcase (transmission), or worn clutch assembly. It does not sound like the problem is associated with any of these components however.
If the motor coupling were bad, the washer would not spin at all (whether you held the agitator or not), but would still have the ability to drain.
If the gearcase (transmission) were bad, the washer would either not spin, or may spin with assistance (meaning, if you gave the drum a spin by hand to get it started).
If the clutch were bad, the symptoms would be similiar to that of the gearcase and the tub would probably also have problems stopping.
This problem sounds like it may only be associated with an agitator that could be loose, causing an off balance tub. Read through the information provided and let me know if you have any questions. I hope this is helpful to you.
May 28, 2010 | Washing Machines
I need to remove the agitator to replace the agitator dogs but there is no bolt head to unscrew is there a special tool for this model 11022912101 series 90
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22912101&pathTaken=partSearch
look at the diagrams for the agitator, basket and tub and you should see how the top components of the agitator fit.
See the part "Dog, agitator "
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
Mar 13, 2010 | Kenmore Washing Machines
Washer now agitating lazily. Ken. HD 60 series. Agitator doesnt seem to be fully connected? How do you remove the agitator?
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
I'd also check the Motor Coupler for a worn center rubber piece.
Jan 16, 2010 | Kenmore Washing Machines
Hi, I have a Kenmore Washing machine that I have had for the last 12 years that I know of. The Oscilator is no longer doing its job this morning. I removed the cap and looked down in the center of the...
If you are referring to the AGITATOR, Whirlpool manufactured washers (such as Kenmore), use a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly.
Since you mentioned that the agitator appeared to be working, this problem may be caused by either worn agitator dogs, a worn agitator cam assembly, or a loose agitator bolt. The following link explains what the dogs are and how to replace them:
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please post back with your complete model number (located on a nameplate along the wash tub opening under the lid) and let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Jan 10, 2010 | Washing Machines
Kenmore Series 70 top load barely agitates....
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Three places to look.
1. Assuming that this washer has a two piece agitator, I'd check the "agitator dogs" on the top section.
2. It's possible that the splines on the agitator have worn over time.
See the following description of how to remove the agitator.
Look inside the agitator at the splines.
3. It's also possible that the splines on the agitator shaft have worn.
With the agitator off, check the condition of the splines. If they are worn, the options are to replace the agitator shaft (disassembling the transmission) or replacing the transmission itself.
May 06, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
Tub won't agitate and when it does spin, makes a grinding noise.
its probably in the gear case. or spin tube bearings. did you see any oil leaks on the gear case or clutch and break area.
Feb 07, 2009 | Kenmore 24032\24036 Top Load Washer
Top half of agatator don't turn
Remove the agitator. Place it on the floor. Put your feet on the base and yank the top portion off. Replace these:
124bfd8.jpgPart number 80040 agit dogs(4)
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 4 years old has prob
You may not have the coupling seated properly. However, if the unit is agitating and spinning at the same time, you may have a more serious transmission problem.
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
82 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
