Question about aldi.com
Ibought a dentitex sonic toothbrush in february 2012 and a fault has occurred in which when charging, the green light will not stop flashing after 12 hours and change to a constant light
I put the toothbrush on charge once a week because I do not have the facility to keep the toothbrush on constant charge during the week.Can you please advise as this fault has arose two weeks ago and after 12 hours charging, it is possible to "cook" the battery and the toothbrush is still under warranty
Tip
Keeping a clean and healthy toothbrush
Keeping your toothbrush clean can help to keep you from getting sick. You can do a few small things to help keep your toothbrush clean and help to keep yourself healthy. Many people keep their toothbrushes in containers or in a cabinet, but in reality keeping your toothbrush closed in a container helps to breed bacteria on your toothbrush. If you want to keep your toothbrush in a closed container then you should make sure that it is completely dry before storing.
Something that we never think about is washing our hands before we handle our toothbrush. Make sure to take a few second to wash your hands thoroughly before picking up your toothbrush, and then rinse off your toothbrush before you put toothpaste on.
Be sure to replace your toothbrush often and especially when necessary. According to the American Dental Association (ADA) you should replace your toothbrush every 3 to 4 months. Whenever you get sick you should replace that toothbrush right away when you get better so the bacteria doesn't stick around.
Keeping a healthy toothbrush keeps you healthy too!
on Sep 30, 2013 | Health & Beauty
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
Do electric toothbrushes require a different amount of toothpaste compared than manual toothbrushes?
No, you should put the same amount of toothpaste on all types of toothbrushes. You should put enough so you can clean your teeth well.
Feb 12, 2013 | Health & Beauty
Electric rechargeable braun toothbrush 500
I had the same problem at the beginning of the year. I think i had bought 3 electric tooth brushes and all seemed to cave in within a couple of weeks. My friend recommended going to Macy's to buy one, which I did and it is still going strong. Maybe you charged it for a very long period of time and it overheat the system circuit? I'm not sure but I would recommend getting a new toothbrush.
Jul 04, 2012 | Oral B Braun B Professional Care 500...
My braun toothbrush will not charge it is the 5. in a year. I am very fed up with Braun Oral B. Why is it not charging. Bought this one 5 weeks ago.
Have you left it to charge for a long period of time? Maybe it overheated the power source? If you cant get it to work I would suggest buying at Macy's. They seem pretty reliable and have good warranty's for these sort of things.
Jun 30, 2012 | Oral B Braun B Professional Care 500...
I have a 3 wheel falcon. Its wonderful but all of a sudden I'm going along and it stops short for no reason
When the failure occurs does a light flash on the tiller. If you see a flashing light count the number of flashes get back to me, your controller has found something wrong. When the scooter stops short do any lights light or is the scooter completely dead. Take the batteries to a battery shop.Have them load test them. I have a Rascal 600t my batteries will put out 500 cranking amps. If the batteries test good have the shop charge them up for you. Does it work right now. Yes, check your charger. No, check the freewheel mechanism when its in freewheel mode it electrically disconnects the motor. Well this thing gets wet at times i have to WD40 mine to get it to work right. The last thing to do is but the back end up,run it, while wiggling wires. Pay particular attention to connectors. The toggle switch in the tiller often gets intermittent. On my scooter the plugs on my get loose causing my scooter to fault out or to stall.Hope this helps
Jun 01, 2012 | Pride Sonic 3 Wheel Portable Scooter
My Oral-B Sonic Complete stops working afer 2x use despite being on the charger always.
These toothbrushes need to be completely discharged every six months or so to keep the battery fresh. Maybe the battery has packed in.
Take it out of the charger and turn it on till it stops completely then re-charge. It might kick start the battery.
Mar 28, 2011 | Vacuums
aldi.com Logo
137 people viewed this question
Top aldi.com Computers & Internet Experts
David Payne
David Payne
Are you an aldi.com Computer and Internet Expert? Answer questions, earn points and help others
