Question about Toshiba Satellite M40-S417TD Notebook
FL Inverter Board adjustment
I had problems with my inverter board and had replaced it myself. It works only marginally better but seems to still turn off whenever I crank up the contrast too high. I noticed a small potentiometer on the board though and am wondering if it can be adjusted to prevent this from happening or if it shouldn't be touched at all?
    Scholar:
  • 46 Answers
Dear User, I would suggest not to tampering with your lcd inverter potentiometer, as it control the amount of voltage being use by the lcd montior. As you have seen from earlier event, it turns off once it reach a certain point. In which, whats really happen is that its reaching a certain temperature and voltage, to which it's shut off to save it's self from burning out. It can also be the lcd inverter was set wrong from the manufacture, and turns off just like before.
Posted on Jul 19, 2007
I have a Sanyo FVD48p4 that has suddenly stopped showing the picture, but there is still sound.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 19, 2017 | Sanyo Televison & Video
How can i fix lg tv black screen
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Aug 03, 2016 | LG Televison & Video
Series #: NX3203, Manufactured Date: Sep 25, 2008. Last night I turned the tv on and there was no picture but I had sound. Is this something I can fix myself or do I need a new tv
Jan 20, 2016 | Televison & Video
My picture is getting darker on 95% of channels all the time
Sep 30, 2015 | Televison & Video
My toshiba 42" REGZA 42RV535U
U have sound but no picture?Picture does flashes a few sec?Yes,than those 2 long LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Jan 13, 2011 | Televison & Video
I have a hP pavillion dv2620us. I get an intermittent black screen whenever I use the laptop. During normal use, the laptop screen just goes dark/black. There is still power to the laptop and you can sort...
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter board. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Sep 30, 2010 | HP Pavilion DV2620US Notebook
Ok I've got the common power inverter problem
Check the SMD fuses on the inverter board see if any of them have blown. You will need a continuity meter to check this.
Jul 10, 2009 | Emerson LC320EM8 32 in. LCD TV
New Power Supply
Saadi2,
In my line of business I have purchased over 20 of these units. The power supply is listed on the Viewsonic Store web-site. Part# is B00005305 cost is about $65.00. Being a Tech myself I went the route of replacing individual parts but had no luck. Take into consideration time to repair its cheaper to by the replacement board. You can always fix the damaged board later as a back up.
Good Luck, OTBMAN
Apr 07, 2008 | ViewSonic NextVision N3260W 32 in....
Sanyo lcd 32" vizion integrated hdtv
I have this tv as well with the same problem. From the research I've done, one of the 16 ccfl's(backlight bulbs) goes bad and they all will not come on then. I have not been able to find a replacement ccfl for this particular tv. The ccfl size if 3mm x 711mm. I have a feeling the scope of this problem is very large with this particular tv and this forum represents the tip of the iceberg. Sanyo unfortunately makes a piece of junk and we have that piece of junk sitting in our homes with no good solution other than to say, dont waste your money on another Sanyo tv.
Jan 09, 2008 | Sanyo DP32746 32 in. LCD Television
Problem in monitor
Sounds like the inverter board or lamps are bad
Feb 26, 2007 | Dell E173FP 17" LCD Monitor
Toshiba Satellite M40-S417TD Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
