Question about LG KP Cell Phones
How to activate MMS on my Nokia Asha305? - KP LG Cell Phones
It's on my Smart No. 09199634778. It received messages from Smart that I have MMS pictures. Can they be shown here?
Yes sir,to retrieve MMS data,you should activate you MMS/GPRS by configuring the settings of your network provider or Smart provider.
Here's how to Activate the your MMS/GPRS
Key in SET MMS and send to 211.
To download SMART GPRS phone settings:
Key in SET GPRS and send to 211.
Example: If you have a Nokia 6230, that's "SET MMS N6230"
To activate SMART GPRS:
Key in "GPRS ON" and send to "333′
To activate SMART MMS:
Key in "MMS ON" and send to "333′
Note :
The configuration settings will be sent to your phone. You will need to select "Save All" to save the settings in the phone. Some MMS and GPRS handsets already have pre-loaded phone settings.
Activation of MMS and GPRS will require a confirmation message from SMART. A message will be sent to the sub once the feature has been activated.
Hope this solution helps you. Thank you for visiting FixYa..
Jul 24, 2011 | Nokia N70 Smartphone
I cant activate my MMS
Title: MMS settings
For Hotlink GPRS Activation
Press *133# to activate your Gprs & MMS
For the setting
1. SMS "GPRS "BRAND" "MODEL" and sent to 22333 example "gprs nokia n70"
2. SMS "MMS "BRAND" "MODEL" and sent to 22333 example "mms nokia n70"
Manual WAP Settings
? On Desk, tab Control Panel -> Internet setup. (or similar)
? Tab New access pt. and tab No, then tab Next and key in the following:
Connection name: Maxis GPRS / Maxis 3G
Data bearer: GPRS
? Tab Next
Network type: IPv4
Auto-retrieve access point: (Unchecked)
Access point: net / unet
? Tab Next and key in the following.
Prompt password at every login: (Unchecked)
Username: maxis
Password: wap
? Tab Next then tab Finish and OK to complete the setup.
? Homepage: http://wap.maxis.com.my/wml/index.wml
? Session Mode: Permanent
? IP adress: 202.075.133.049
? Login Type: Automatic,
? Authentication Type: Normal
MMS Settings
May 12, 2011 | Computers & Internet
How to activate my wap mms on nokia 2630???
Thanks for visiting FixYa!
Your Nokia 2630 cell phone does have MMS capability. If you want MMS service you will need to call your cellular service provider and subscribe to the service. There will be a monthly fee as this is (usually) not a free service. If you have already subscribed to the MMS service and still are not able to send and receive MMS messages, contact your cellular provider and request they re-set your MMS service on their system.
Once MMS has been activated, you won't need to activate it on your phone. Your phone will automatically recognize MMS messages and notify you when one is received. (Or sent).
Apr 15, 2011 | Cell Phones
How to view mms message on X2 nokia cell phone
Hello Dear
To view MMS on your Nokia X2, ask your service provider first if it is activated then go to the MMS setting and turn it on there.
1.GO to Msg Settings
2.then click MMS
3. Check Your Config Setting.
4. Turn on ADVERTS
5. In MMS RECEPTION check the automatic one.
Hopfully it would work.
Regards
(please rate the solution if you find it helpful)
Mar 15, 2011 | Computers & Internet
How to activate my mms and gprs NOKIA 5800? Go Nokia 5800,,1234 send to 2951? but the reply is invalid. how?
try to call your service provider and tell them what was happened..they will send you a gprs and mms activation..
Mar 08, 2011 | Nokia 5800 XpressMusic Smartphone
How to activate the gprs of n5310 xpress musi, using my smart buddy sim
Here's a quick tip on how to activate your phone's Smart MMS and Smart GPRS settings if you're with the Smart network:
Download MMS and GPRS settings from Smart:
To download SMART MMS phone settings:
Note :
Feb 15, 2011 | Computers & Internet
I activeted gprs & mms settingin but my nokia 6300 mms not sent & not receive mms, pls help me to sent & receive mms on my nokia 6300. & i use bsnl pri-paid card
Please activate any GPRS and MMS plan and selected GPRS and MMS settings as default. Also check with your service provider which all providers you can send and receive mms because some service providers do not allow to send mms to other service providers like Aircel.
May 24, 2010 | Nokia 6300 Cell Phone
Mms retrieving
You need to contact your Service Provider to ask two things.
  1. If MMS is active on your number and if it is not active can they make it active.
  2. Ask them to send you MMS settings OTA (Over the Air) These usually come in the form of a text message.
Sep 01, 2009 | Nokia 6300 Cell Phone
My 3110 wont let me send pictures
hi there,
you can follow the procedure inserted below hope it will help you to solved your problem...
any further question you can log on this site,,
http://www.yugatech.com/ringtones/tips-tricks/activating-your-smart-mms-gprs/
Here’s a quick tip on how to activate your phone’s Smart MMS and Smart GPRS settings if you’re with the Smart network:
Example: If you have a Nokia 6230, that’s “SET MMS N6230
Key in “GPRS ON” and send to “333′
Key in “MMS ON” and send to “333′
Note :
The configuration settings will be sent to your phone. You will need to select “Save All” to save the settings in the phone. Some MMS and GPRS handsets already have pre-loaded phone settings.
Feb 16, 2009 | Nokia 1110 Cellular Phone
How can i activate GPRS and MMS setting for my china mobile phone
hi there,
here i post some procedures you can follow for activation your GPRS and MMS.
Automatic Activation of GPRS/MMS/WAP
Go to Menu -> Services -> WAP -> Settings -> Edit Profile
Select Sun WAP, Press Activate Profile and Save
Go to Menu -> Messages -> MMS -> Message Settings -> Server Profile
Select Sun MMS, Select Activate Profile and Save
For corporate accounts, fax a letter of request and ID of the authorized signatory to 395-0138. Approval and activation maybe slightly delayed.
Text “ACTIVATE” and send to 2300
If unable to activate,please call Sun Customer Hotline (200 on your mobile phone).
* If surfing or MMS sending does not work or results in an error, please proceed to the next step for manual setting.
Manual Activation of GPRS/MMS/WAP
Setup/Enable GPRS
Go to Menu -> Services -> Data Account -> GPRS
Select Sun GPRS
Account Name: “Sun GPRS”
APN: “wap”
Select SUN MMS
Account Name: “Sun MMS”
APN: “mms”
Exit and save settings
Setup/Enable MMS
Go to Menu -> Messages -> MMS -> Message Setting -> Server Profile
Select Sun MMS, Select Edit Profile
Rename Profile: “Sun MMS”
Homepage: “’http://www.mmscenter.suncellular.com.ph”
Data Account: “Sun MMS”
Connection Type: “HTTP”
Proxy Address: “202.138.159.078”
Proxy Port: “8080”
Select Activate Profile, Yes to activate profile
Setup/Enable WAP
Go to Menu -> Services -> Wap -> Settings -> Edit Profile
Select “Sun WAP”, Select “Edit Profile”
Rename Profile: “Sun WAP”
Homepage: “http://www.suncellular.com.ph”
Data Account: “Sun GPRS”
Connection Type: Select “HTTP”
Proxy Port: “8080”
hope it will help you to solved your problem or still you have any question regarding on it that you can't understand you can go on this site and log on.
http://www.kokeytechnology.com/gadgets/cell-phonesmobile-phones/how-to-activate-gprs-and-mms-of-nokia-phones-powered-by-sun-cellular/
Feb 16, 2009 | Nokia 6300 Cellular Phone
Cell Phones Logo
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
