Question about Kirby Ultimate G Bagged Upright Vacuum
Need to Know how to change to a shamporer
Cant find my directions and cd on how to operate. I need to know what to do to change the vacum over to a shaqmporer
  • susan329 Jan 29, 2009
    how do you attach the guard onto the shampooer for the Ultimate G model please. Susan
  • Kirby Expert
  • 324 Answers
You can buy manuals HERE, but before you do so I'd say - see our FREE online shampooer manual HERE.
Good Luck
Posted on Jan 27, 2009
Electrolux Unirapido not working green light flashes when start button is pressed!
I have the same problem with this type of vacum. I have tried a lot of things but the problem is with the software included in a 20 pins chip on the pcb so it can not be repaired. But, if you look in the back of the vacum there is a rubber stopper wich hides 2 pins. Maybe those pins can be used to reset the vacums pcb. I really dont know because in can't test it any more. I solved my vacum bypassing the vacum mainboard (pcb). Now my internal battery is directly connected to the 2 motors using a simple switch to powering on and off. The original pcb is conected only to the batery, recharghing wires and led wires so i can recharge the batery as usual. Sorry for my english, hope you understanded what i was trying to explain. good luck
Apr 15, 2013 | Vacuums
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
Cant find one
Hello. You can call the Fantom company directly at 800-798-7395. Or use their website http://www.fantom.com/fantom/default.aspx
please rate my answer as very helpful. thanks. Joe800-800----
Apr 21, 2010 | Fantom Vacums Lighting Canister Vacuum
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
Replacing the belt
remove the two screws from the top of the vacume instead of from the bottom and it will be right inside there.! changeing the vacume belt after that is all very simpl and self expl.
Mar 12, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Feb 27, 2008 | Eureka Boss SuperLite Bagless Upright...
Brushes don't turn
i once was a vacume salesman and i have handled a lot of differnt kinds of vacumes there are a few things that will make the brushs not spin the belt could be broken is some there is a swith that when you lower the handle will turn on the brushes. or if the vacume is on the barefloor setting in somecases they also wont spin i hope this helps.
Nov 11, 2006 | Kenmore 31913 Progressive Direct Drive...
Kirby Ultimate G Bagged Upright Vacuum Logo
43 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
