Question about Uniden BC246T Handheld Scanner
Programing a uniden BC246T
They sent me a nine pin connector to go from my computer to the radio and my computer dosn't have a nine pin connection.
I bought a radio shack connector to go from the nine pin to a nine pin thru a USB port. And that did not work ether the computer dosn't reconize the cable connection. Please Help
Buy a RS 232 to USB converter to connect your computer to the radio.
Posted on Jul 13, 2012
Not all programming software supports usb. Either find software that supports usb or you can buy add on cards to your pc that will give you a serial port. Hope this helps
Posted on Feb 01, 2009
I have a uniden BC246T and want to reset it and just add my local frequencies. but cant seem to figure it out.
The easiest way to program your scanner is to download software from www.butel.nl for your scanner. You will be able to manage your scanner better and you can download frequencies for your area from www.radioreference.com .
Jul 18, 2011 | Uniden BC246T Handheld Scanner
Need to connect my J-NAV 500 GPS to my laptop, however, manual doesn't help much regarding which wires to to which pins on the 9 pin "D" connector. Thanks
This device if the manual is right uses an RS232 connection, what you are goiung to look for is a nine (9) pin connection it will look similar to your VGA connection on your computer. Do not connect the cable to your VGA connection, the nine pin connector will connect to the gps unit and the other end of the connector will connect or at least should connect to your computers com1 one connection or maybe the usb connection not sure. Should note that this unit has been dicontunued and the only manuals i could find were in Japanese which i don't speak, but that should be your connection.
Hope this helps
Jun 26, 2011 | JRC Plot 500F GPS Receiver
Where can i get a instruction manual for my bc246t i cant program my codes into my scanner
You can download and print the factory manual for your scanner, at no cost, here:
http://www.uniden.com/pdf/BC246Tom.pdf
You can also find a comprehensive database of active frequencies in your area (they're not codes), and a lot of other useful scanning information, here:
www.RadioReference.com
Bill B.
Listening in - professionally - since the 60's
Mar 06, 2011 | Uniden BC246T Handheld Scanner
How do i get barrie on my bc246t
Don't know what "barrie" is, but you can find a comprehensive database of active frequencies in your area by visiting
BillB
Jan 26, 2010 | Uniden BC246T Handheld Scanner
Need a manuel for my scanner bc246t
You can download/print the manual here:
Aug 06, 2009 | Uniden Hand Held Scanner - BC-246T 2-Way...
Need Program for Uniden BC246T scanner
scannow.org it is a free programming software
Apr 02, 2009 | Uniden BC246T Handheld Scanner
Trouble programming my new Uniden scanner
go to www.radioreference.com and look in the uniden forum, they have everything you need to know there
Jan 02, 2009 | Uniden BC246T Handheld Scanner
Programming my bc246t
Hello Ranger66,
I had the same problem. did you set the radio to "xfer information"? if not, to do this follow these steps
1. press menu display ---menu--- and program system under
2. twist thr top right knob until "xfer information is displayed".
3. press the "E" or yes button, this will disply the baud rate.
check to see if the radio connects.
Dec 31, 2007 | Uniden BC246T Handheld Scanner
Check here to see if the info your looking for is there, just punch in your state and county and the info listed beside the freq's should tell you. Hope this helps,, Mechanic
http://www.radioreference.com/apps/db/
Dec 27, 2007 | Uniden BC246T Handheld Scanner
Countinous Garbled Sound
Probably a DIGITAL/ENCRYPTED talkgroup that you cant get on the 246T
Nov 26, 2007 | Uniden BC246T Handheld Scanner
Uniden BC246T Handheld Scanner Logo
123 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
