Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Changed evap mtr & thermister evap still wont come on what next
I dont think the pc board is bad the only thing not working is the evap mtr
  • 65 Answers
LOOK AT THE CONTROL BOARD AGAIN. LOOK FOR A BURNT OUT RESISTOR OR TAKE IT OUT TOTALLY AND LOOK AT THE CIRUITS ON THE BACK. IT WAS NOT UNCOMMON FOR THE MOTOR TO GO BAD AND DAMAGE THE BOARDS.
Posted on Jan 27, 2009
My lg wm1832cw washer was in spinmode when it made a bam noise and lost power. I had to change the board ans when I did the upside down f and e came on. I changed the thermistor but am still getting the...
check the wire harness from main board to thermister. tE error code is either an open or shorted thermister. If you replaced the main board and thermister, the only other option you have is a bad harness. Reseat connectors on the main board and all along the harness to the thermister
Feb 10, 2013 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Motor is not coming on
Sounds to me mtr. may be bad. If u have a meter & know how to use set meter to read ac volts next disconnect plug that goes into mtr. check to see if voltage is present if so bad mtr. i would even try to spin mtr see if it gets going but most likely need to replace
Apr 04, 2012 | GE Refrigerators
I am getting the dreaded tE code on my LG Washer. I understand that it could be the Thermistor going bad ot wiring. Any good info on a wiring diagram for this unit and maybe some pointers to check this...
Sorry i dont have any wiring diagrams for the refrigerator,yet a thermister is a electronic thermostat. its basically a varible resister and it has a certain ohms rating at one specific tempature and the value of the ohms drops at it get hot and the ohms increase at it gets cooler so it works by telling the control board its 1100 ohms and the control will calulate that as being 72 degress f ....as the dryer heats it reports to the dryer its 500 ohms and can be determined that 500 ohms is 155 degrees and so on and so on. The basic way a thermister works is the same regardless if its used in a dryer or refrigerator or what not only difference at freezing temps its say to the control it's at 7000 ohms
I may not be exact on the ohms values yet that is how a thermister works
May God bless and keep you well,
GENE
Oct 14, 2011 | LG WM2487HWMA Front Load Stacked Washer /...
KM450MAB my machine makes a batch of ice then goes into harvest cycle and dose not come out of it, it gets realy hot. What can be the problem?
Probably the suction line thermister, this sensor should signal a timer in the main control board to initiate harvest. If the thermister is OK than there may be a problem with the control board
Nov 20, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Small evap leak
this could be due to a cracked line for the evap or a bad vent valve or bad purge valve, check all the evap lines closely for cracks, this would be better with an evap machine, you would be able to smoke test, this is done by filling the evap system with smoke in order to test for a leak, if it passed the smoke test then the next thing is to test the vent valve to make sure it closes good, this is done with the smoke and by powering the valve shut,and making sure it doesnt leak, most saturns i work on end up with bad vent valves or a cracked line, hope this helps.
Apr 17, 2010 | 1999 Saturn SL
I have a pro form xp 542 s tread mill and think it is the speed sensor that is bad but i dont know where it is located or what it looks like,can u help me?
You have a bad mtr controller- did u leave the item plugged in wall without surge protector-did the power go off at house and then come back on(clocks blinking 12 one day)?? if yes to both you had a surge, if no still your controller/power board( all in one board) is bad
Jan 06, 2010 | Proform XP 542S TREADMILL Drive Motor
Air condioner climbs to 86 degrees
These latest models rely on a cheap part called a thermister. Older ones used a mercury based cold control. A pc board sends a small amount of power through the thermister to judge the temp. As the temp changes the resistance inside the thermister changes. These el cheapo mexican thermisters are a dime a dozen. They have a quick connect. The thermister must be suspended near the coils but not directly on them or temps will not be judged correctly. Since a thermister is less than $10 bucks i would replace that first before calling someone.
Aug 21, 2009 | GE AJCQ08ACB Air Conditioner
GE side by side not very cold on fresh food side
there is one of two thing that could be going wrong here ; you may have a bad evap fan mtr and control board or yourr damper is not opening properly. i would say you have the later of the two due to the fact the rf is still making ice. one thing that causes this issue is too much weight in the door causing the door to lean and not trigger in door light switch or the switch itself is damaged. the door hinge and camm assembly can be adjusted from the bottow using a standard socket set
Jun 09, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge Fan not working
you have a bad main board and evap. fan mtr
May 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
52 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
