Question about Panasonic PT-AE900U Multimedia Projector
My vivatech qumi 2 projector won't recognize any input
Projector auto shut down
The blink pattern indicates the LED emitter is overheating.
Sep 08, 2014 | Vivitek QUMI Q2 720p LED Projector QUMI-B
Video input not recognized
Will it work if you change the input to manual and select the correct imput source?
Mar 18, 2008 | Hitachi CP-X275 Multimedia Projector
Vivitek Qumi Q2 reset ?
Unplug the power cord from projector
--> HOLD down (keep holding down) the right key on the keypad (top of the projector) and Insert the power cord back to the projector
--> The "Power" and "Ready" LED light should blink TWICE and unplug the cord from the projector (while still holding down the right key)
from facebook site
Jan 02, 2013 | Vivitek Qumi Q2 WXGA 3D Ready LED Pocket...
Infocus 5000 won't recognize my computer
How about a little more information?
Does the projector turn on?
has it ever worked?
What type of interface (VGA, DVI, HDMI, RCA)
What type of computer (notebook or desktop)
That being said, double check your cable connections and make sure you tell your computer to look for the projector (Dell laptops used to use FN+F8 to switch from laptop to projector). Windows 7 has a menu choice "Connect to Projector". Mac computers - check system preferences and make sure the projector is ON before you plug it into the Mac.
Nov 25, 2012 | InFocus ScreenPlay 5000 Multimedia...
Proper PC Adjustment Parameters?
Hello,Instead of replicating your laptops desktop can you please try extending the desktop. This way your laptop can keep its native resolution and so can the projector. Let me know how it goes.
Nov 17, 2011 | Sanyo Office Equipment & Supplies
I'm having trouble getting my monitor to recognize my laptop when I hook them up. I tried going to my desktop, then adding a device or projector, then adding the monitor but the tv still won't...
What you'll need to do is set your TV to whatever input you're using on the laptop (VGA or HDMI). Then go into Display Properties, which can be found in Control Panel. Select the grayed out 2nd display and check "Extend desktop onto this monitor". Slide the resolution to something your TV can support such as 1366x768 or 1920x1080. Apply, OK, OK and you're done. The exact steps that you'll need is slightly different than the instructions here because of variation in TVs and OSes, but it's mostly identical.
Aug 19, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
My projector won't project anything. the computer recognizes the projector, but the projector does not recognize the computer. also when i turn on the projector the benq logo doesn't show.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Aug 19, 2011 | BenQ PB6240 Multimedia Projector
Source not found I am using an Acer Aspire One
Make sure you are using ports other than the USB port. Vivitek Service indicates that at least some of their projectors do not use the USB port for input. "The USB port is not in input port. This is used for service only. Please use another input port such as RGB input. Regards, Vivitek Customer Service
Hope this helps.
May 16, 2011 | Vivitek D825MS Projector
No image
1-SWITCH YOUR PROJECTOR OFF.
2-CONNECT EVERYTHING AS NORMAL CONNECTION.
3-SWITCH DOCUCAMERA ON.
4-SWITCH YOUR PROJECTOR ON.
5-CONFIRM THAT INPUT OF PROJECTOR IN RIGHT INPUT TO CAMERA.
6- CONFIRM THAT CAMERA CABLE IS GOOD BY PLUGING IT IN VIDEO INPUT OF ANY TV.
Mar 06, 2008 | Epson - PowerLite S1+ Multimedia Projector
Panasonic PT-AE900U Multimedia Projector Logo
43 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
