Question about Candy Washing Machines
Candy GO FS 262 wont spin - Candy Washing Machines
My candy 1862d will wash but wont spining.i tried once blowing air through d pressure switch to clear any blockage and it spinned but now its not spining even when i performed similar operation
sounds like a faulty pressure switch , or the small pipe connected to it is blocked, machine will not spin if is seances water in the machine. you hear a small click if you blow very gently into pressure switch and as you stop blowing and the air comes out you hear another click as the switch operates
SAFETY always make sure the machine is unplugged from the mains electrical supply before working on machine.
Nov 20, 2016 | Candy Washing Machines
Candy GO FS 272s won't spin and the light is flashing 8 times?
error code 8 means a problem in the motor speed sensor
Nov 15, 2015 | Candy Washing Machines
Replace on/off switch on candy Gando,range 4, GO FS 262
and???? you have a broken swich source a spare part from candy.....
replace if it you can if your not sure seek another who knows what too do...
Mar 04, 2015 | Candy Washing Machines
Not spinning displays e03
hi i have a candy washing machine and it wont turn on with the mains i have tried everthing and it wont come on at all anyone to help me please email me at paul.barnett2@live.co.uk thanks
Dec 03, 2013 | Candy CNW136 Front Load Washer/Dryer
The start button on Candy Nova CDV-262 won't stay in.
there seem to be a bad connection try sliding a thin knife next to the switch and see if that works
Feb 17, 2013 | Dryers
Problems with grando 0 go sf 262 washing machine
see this and fix it. God bless you
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control.
Sep 27, 2012 | Candy Washing Machines
Candy nova cdv 262, heat works but drum does not revolve
Hi dodgedrums...
I can answer your question, but you will need to resubmit your question if you need help in the repair.
I have never worked on a Candy machine so therefore I cannot help with the dissassembly of the dryer for repair
Your problem is most likely to be a broken belt, or a faulty motor...normally even a novice mechanic can repair with the proper advise which you will normally find here at Fixya.
Please take time to rate me
Jul 20, 2011 | Candy CDV262 Dryer
Agitates but wont spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Candy CN146 Front Load Washer
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Candy washer dryer 1400 spin cmd 146
try taking the soap dispenser draw out a give it a thorough clean inside and on the underneath of the drawer, then clean inside the machine where the drawer fits into. Sometimes a build up of detergent/softener can cause this.
I hope this helps
Jan 19, 2009 | Candy CNW136 Front Load Washer/Dryer
Washing Machines Logo
137 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
