Question about SanDisk Sansa e200 MP3 Player
My sansa is stuck on refresh database
Its stuck on refresh database and when i plug the usb into the computer it doesn't read it so i cant even add or erase data off of it. It also doesnt let me go to menu or nothin only thing i can do is turn it on and off
  • Anonymous Dec 27, 2007
    I have the same problem and nothing I have tried has helped
    Problem Solver:
  • 14 Answers
Turn it to recovery mode by putting it on hold, while off, and holding the record button along with power until it go's into a screen with a black background and white text. Then update it with the updater. You can get it here: http://sandisk.com/Retail/Default.aspx?CatID=1376 NOTE: Updater will NOT work on windows vista. Good luck and i hope this fixes it! Have a nice day!
Posted on Jul 18, 2007
SOURCE:
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
Stuck on fresh database
Some songs or files with extension device can't read, so it takes so long/infinity to refresh. Plug the device to pc, format it.
Good luck
Feb 18, 2010 | SanDisk Sansa Clip MP3 Player
Sansa e260 frozen on refresh database
Make sure USB mode is MTP....If this doesn't work make sure that you are connected to a 2.0 USB port....I had to install the update on to my labtop and finally it recognized it and updated
Push the power button in until it turns off then proceed with the above
Apr 11, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database?Need Serious HELP!
Have you removed the battery, wait then reinstall it to try to reset it? Been the Sansa website and their FAQ or tech support?
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e270 refresh database
Go under settings and change USB Mode to other choice. Then format. After formatting change back to original setting. I had same prob. Tech support told me to do this and it worked. Have had no problem since.
Jan 07, 2008 | SanDisk Sansa e260 MP3 Player
My screen freezes with "refresh database"
Dude, c'mon - you have a Linux based system - did you really think it was going to work? Just playing with you. I would check the Linux forums on this one - if you're smart enough to use Linux, then you're smart enough to grab software info from Sandisk's website/cust svc line and pass it to your Linux buddies to hack.
Dec 26, 2007 | SanDisk Sansa e200 MP3 Player
I had the error of refresh database fail but my pc still cant see the mp3 player
Check in the Device Manager on the computer. With the device connected Right Click on My Computer and select Properties>Hardware Tab>Device Manager. If there are any errors (red or yellow) by the Sansa, right click on it and select un-install. Disconnect the device and after it restarts, re-connect. The drivers will re-install. If that is not the issue, try using a different USB port, preferably in the back. Or, change the device mode Settings>Mode or USB Mode and try connecting to PC. You can add to the question if you need more assistance. Best of Luck.
Sep 30, 2007 | SanDisk Sansa e250 MP3 Player
Refresh Database
This is happening alot aparently, Sandisk is telling everyone to just reset it but that aparently isnt really working. only suggestion is to set the USB mode to MTP and try it.
Aug 02, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
111 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
