Question about Brother MFC-9180 Printer
Can I connect Brother MFC 9180 to MacBook Pro?
Is there a cable to connect both?
  • Brother Master
  • 7,993 Answers
Use a usb cable or connect through a wireless connection if MFC has such a capability.
Posted on Jan 21, 2013
3 Suggested Answers
qwertyisone
  • 6 Answers
SOURCE: Brother printer MFC 9180 Blobs on page at certain ...
The blobs are probably dried toner on the drum. The solution is to use a soft piece of cloth and rub the blobs off the drum through the gap at the front of the drum unit. The drum can be rotated by turning the gear cog on the side, then once the residue has been removed from the drum and it is clean, the blobs should have disappeared. I wouldn't use any solution on the drum, just gentle rubbing should suffice.
Posted on Aug 19, 2010
  • 46 Answers
SOURCE: I have a brother mfc 9180 and the error message
your new drum should have had a plastic "starter sheet" installed just level with the exit hole. this sheet resets the counter, and should not be removed before fitting the new drum. The sheet will be automatically ejected when you have fitted new drum. If you still have this sheet it can be refitted to the drum, then reinstall the drum. Works for me ! MFC 9180
Posted on Oct 29, 2010
I have a Brother MFC-9180, it has a DR8000 in it. The machine come up on the display saying "Change drum soon" which I have done, the new drum did not come with a page to feed into the drum. I want to...
Did you reset the drum counter?
When you replace the drum unit with a new one, you need to reset the drum unit counter by completing the following steps:
  1. Turn the the machine's power switch back on.
  2. Press Menu => Machine Info. => Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
I hope this helps.
Or Try this:
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/002800/000037/faq002837_009.html?reg=as&c=au&lang=en&prod=mfc7220_us_as
Oct 20, 2013 | Brother International Brother MFC-9180
MFC-J5910DW wont scan to macbook
Hi Russ unfortunately I cannot help with your query, but have a quick question.. I have a Mac Book Pro running 10.7.5 but cannot get the install cd rom to work, what drivers did you download for it? Many thanks and hope you sorted your issues out! Giles
Oct 11, 2012 | Brother International Inkjet Multifunction...
I have my mfc-240c already loaded as default printer on my pc, and am now trying to load the driver onto my macbook pro. I no longer have the manual. It is asking me for the node name and I have input...
You can find updated drivers and the manuals for your printer here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc240c_all
I suggest you remove the current drive , download and install a new driver for your Macbook Pro to see if this makes a difference.
If necessary the website has an extrensive Troubleshooting section that may be of assistance.
Mar 07, 2011 | Brother MFC 240C All-In-One InkJet Printer
Brother printer mfc 9180 Blobs on page at certain intervals
May 20, 2010 | Brother MFC 9180 All-In-One Laser Printer
How do you connect to your computer
You can buy this cable or use the one provided by Brother
Belkin PRO USB 6' Cable USB cable, 4 pin USB Type A (M) - 4 pin USB Type B (M), 6 ft
Belkin Cable 4 pin USB type A (M) , 4 Pin USB type B (M)
Detail in this link
http://www.superwarehouse.com/Brother_MFC-3220C_5-in-1_Color_Multi-Function_Center/MFC3220C/p/332703
Apr 22, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
I have a brother mfc 9180 and the error message keeps coming up replace the drum. I have done this How do I reset it
Jun 05, 2009 | Brother MFC 9180 All-In-One Laser Printer
I can't networt to a printer
It sounds like a software configration issue. try and access the Network menu on your MFC and remove any static IP that might have been setup by your software and retry to configure the printer.
Jun 13, 2008 | Belkin (F5D7230-4) Router (587009)
Brother MFC 9180 - Wrong operation signal
Press every button on operation panel, I've known this model to get em stuck , please define if input is noticed in display and if mode switch ie fax, copy operates if key isn't stuck.
Jan 30, 2008 | Office Equipment & Supplies
Brother MFC-9180 Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
