Question about Janome Sewing Machines
Using the button hole foot with JL 300 - Janome Sewing Machines
2 Suggested Answers
SOURCE: Attaching fit button-hole foot?
Just pull down on the original metal foot. It will snap off and then you can snap on the button hole foot. Good luck!
Trudy
Posted on Dec 02, 2008
ELNA 540 Experience how do i use the foot marked with an R? What is the settings for a rollstitch?
The foot labeled R is the buttonhole foot. Raise the machine needle and put the foot on the machine. Pull the button holder to the back of the machine and place the button for the garment in holder. Push the button holder to close it against the button. For thick buttons, you may want a slightly larger space for the button. Just pull back the holder a fraction. Push the button hole lever down as far as it will go. (The lever is on the side of the foot near the button holder.) Place a corner of the fabric under the foot and press the up/down needle button twice. Pull the thread to the back of the fabric. Then position the fabric at the starting point where the button hole is to be sewn. Make sure that there is no gap between the slider and the stopper on the foot. Select the button hole style (06 regular, 07 oval, 08 keyhole). Then set the machine to sew. This is shown in the manual on pages 53-63 (pages 59-70 in the PDF).
For a rolled hem on a lightweight fabric, use stitch 10 and set the stitch width to 3.5 and the stitch length to 0.8. Use the Satin Stitch pressure foot (labeled F). Lay the edge of the fabric in the center of the foot. (Make sure that there is a clean cut to the edge with no dangling threads.) See page 48 of the manual (page 54 of the PDF).
Elna has the manual for the Experience 540 here on their manuals page: http://www.elnausa.com/en-us/pages.php?page=107 . The Experience 540 is listed on the left in the section labeled Top-loading 7 mm Max Stitch Width Machines. The direct link to the manual is http://www.elnausa.com/data/files/2_users/55/Inst-book-EL540%28EFG%29.pdf .
I hope this helps.
May 13, 2017 | Elna Sewing Machines
Singer 7444. Can't use button hole. I have
try changing the needle
clean under the needle plate and in the bobbin area
and make sure you use every thread guide
Aug 11, 2013 | Sewing Machines
I have an Elna 6003 and think it is very difficult to make a button hole. What could I be doing wrong?
some machine have a button hole lever that has to be pulled
down, before they work.
are you using the button hole foot?
if the machine is mechanical, are all the dials set for button hole?
if the machine is electronic are all the settings correct?
also change the needle
if you have the button hole foot on & the button hole lever is down
& a new needle,, the it is possible that the machine needs to be
checked to see if there is something wrong with the buttonhole
function
Aug 28, 2012 | Sewing Machines
Just purchased a Singer 4423 machine, need more detailed instructions for buttonholes
when you press the button hole option & then pull the button hole lever
down it will rest against the button hole foot, having the button in the
button hole foot help the machine gage the size the button hole needs
to be, if the machine keeps on sewing & doesn't stop automaticily then
there is something wrong with the button hole option.
Jul 18, 2012 | Singer 4423 Sewing Machine
How to make bottom hole
use your button hole foot. mesure your button before setting foot down. set your masjien to button hole stitch and press reverse to do the backward line. cut open with a picker
Jan 10, 2012 | Singer Sewing Machines
One step button hole instructions Singer model 3827
Insert the button into the special button hole foot. put the foot on the machine.Pull down the button hole lever( It's near the presser foot lever towards the back of the machine). Place your needle where you want the button hole to be. Select the button hole pattern and press on the pedal. Watch for the end of the button hole.
sewman7
May 15, 2009 | Singer 7422
Trudy
Nov 17, 2008 | Necchi 3537 Mechanical Sewing Machine
I have emerald 183 and i can't figure out how to use the buttonhole feature. it keeps sewing just one side. also where exactly do i put the button?
Make sure you have pull down the arm that will engage the button hole mechaizm. Put a button in the back of you button hole foot, attach foot, reach up on the left side just below the light and pull the lever down, choose the button hole , lower tension to 3 and sew out the button hole. The button hole foot should push on the arm when it gets to the end and complete the rest of the button hole. If the columns do not match then it has to be serviced by a husqvarna dealer.
Sew Technologist
Apr 21, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Buttonhole problem
When doing the button hole....after installing the button hole foot and lowering the foot....and adding the button so the automatic button hole size is determined...you lower the button hole lever it will touch the back of the button hole foot. this holds the button hole foot in the proper position...if this lever is not all the way down...the machine blips at you...check to see that it is down all the way...I hope this helps you..It truly does all that it advertises and is a great machine...BBill01
P.S. you can adjust width and length of the stich also...see instruction manual. pg 28-30
Jan 06, 2007 | Juki HZL-E80 Computerized Sewing Machine
Sewing Machines Logo
49 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
