Question about Minolta DiALTA Di183 Copier
Minolta Di183 display shows 88
We bought this Minolta Di183 and the only thing we get is an 88 in the display area. It seems to come on, but that is it.
  • Minolta Master
  • 6,573 Answers
1 Call the Utility Mode to the Display.
❍ Calling the Utility Mode to the Display (p.7-1)
2 Making sure that “U--” appears on
the Display, enter “5” from the 10-
Key Pad.
3 Press the [Start] key.
Enter the 6-digit administrator
number from the 10-Key Pad.
? Do you know how to enter the
administrator number?
➜ Enter the six digits successively.
? Do you want to correct a wrong
number just entered?
➜ Press the [Clear] key and then
enter the correct number.
5 Press the [Start] key.
6 Check that “Ad-” appears on the
Enter the code assigned to the
desired subfunction from the 10-
Key Pad.
? Do you know the code for Copy
➜ To select Copy Track, enter “1.”
? Do you know the code for Disable Auto Shut OFF?
➜ To select Disable Auto Shut OFF, enter “2.”
8 Press the [Start] key.
GO to Konicaminolta US website down load a operators manual free
Posted on Aug 02, 2009
  • Norman  J Weimar Jr
    Norman J Weimar Jr Aug 04, 2009
    Known unrecoverable NVRAM symptoms:
    1. Stuck on hour glass screen
    2. Incorrect meters
    3. When performing the NVRAM restore procedure the codes repeat themselves
    Note : One thing that has been noticed is these machines seem to be highly susceptible to voltage sags and spikes. It is HIGHLY recommended to install
    a quality power line conditioner on these machines.
    Known fixes for various codes:
    C-D36E and C-E002 – Install Phase 3.01firmware (H5 or H6 depending on model).
    This mean that the machines Non-Volatole Ramdom Acess memory, per KM Service Web site has crashed. have a service technician install the Firmware
Tray falure loading papers
Paper jam at the drum area. Are you printing to this machine ensure the print properties equals what is a the machine Landscape paper not portrait vise versa. Ensure machine not set to metric size paper vise Inch in the USA
Mar 20, 2014 | Minolta DiALTA Di183 Copier
Minolta di183 driver x64
Sir the Minolta Di183 is a Legacy copier from Minolta at best you mite find Windows 95 or XP at best. Not going fine Windows 7 Vista. But try the konicaminolta web site. Drivers are free.
Jan 08, 2014 | Minolta DiALTA Di183 Copier
C06 50 error code minolta dialta copier
The scanner which is the bright lite under the big glass has a home sensor to let the copier know that scanner is back home and ready to scan again. will the code is saying the senor is bad, could be dirty get some can air. Remove big glass will be though to get at small and black under the scanner bay side.
Dec 02, 2013 | Minolta DiALTA Di183 Copier
Minolta dialta di183 copier error code c06 50
C 0650 - Faulty scanner home position sensor.
Remove the glass and clean the home sensor.If the scanner moves smoothly remove foreign matter and other obstacles,clean the scanner rails,clean or change the scanner bushing.Place WD 40 oil on scanner bushings.
My dialta minolta di183 is showing C06 50 code and i dont know how to go about it
Clean the home scanner sensor scanner is what moves as it scans the document. then go back to home position there is sensor that tell the copier it is back home clean dirt or might need to be replaced.
How do I stop the maintenance indicator light in Minolta di183 photocopier? pls help
Call in a service tech to replace the parts that are at there service interval. Seems pretty logical to me.
Jun 12, 2013 | Minolta DiALTA Di183 Copier
No user manual
It means it needs a service call. Are there any letters or numbers on the display?
Sep 25, 2007 | Minolta DiALTA Di183 Copier
Minolta DiALTA Di183 Copier Logo
149 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
