Question about Bosch Washing Machines
I have a Bosch Avantix 7 washing machine, when trying to set programme get a key icon on display panel and will not accept programme selected just a flashing zero, have checked door, outlet/drainage pipe and hoses all appear to be ok
SOURCE: water coming out of the drawer
I have had this problem on the WD860 washer drier and it sounds more or less identical - the problem is that lint and general clothing material (and I'm sure some slightly less clothe-like items) are blocking the filter in the water pump that sends the water out of the machine. Now the only problem I have is that this was previously discovered by a Hotpoint engineer and promptly dealt with under the warranty, however I do not know how to get back in to the water pump housing (without damaging it) to clear out the new filter blockage. The waterpump is located to the rear of the machine on the right hand side (from the back) at the bottom of the drum - it is quite easy to access with a philips head screwdriver to remove the back panel, however then comes the problem - the water pump appears to be part of an all-in-one sealed unit that runs from the drum to the waste pipe and I can't figure out how to access it without causing damage. (Admins may wish to move this post to the as yet non-existent WD860 section - but the problem does sound identical to the one that floods my kitchen more or less everytime I use the damn thing!)
Posted on Jul 27, 2007
  • 146 Answers
SOURCE: Washing machine wont complete drainage at end of wash cycle
Look under the washer tub where the drain hose comes out and attaches to the pump. Your pump impeller is either clogged or worn out. Try removing the pump and checking from there.
Posted on Jan 07, 2008
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
  • 82 Answers
SOURCE: hotpoint aquarius 1200 washing machine leaking
this could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Posted on Jun 28, 2009
  • 574 Answers
SOURCE: Bosch Classixx 1200 red wash light flashes but doesn't start
Could still be the water inlet valve. What you need to do is pull the washer out where you can get to the valve and the plug. Unplug the inlet valve and start the washer and when you start it as normal check the volts of the plug and see if its 110 if it is you know that the valve is getting power to open but not,replace the valve. If you dont get any voltage then it could be the relay or control board
Posted on Sep 02, 2009
Model ESL 499. Why doesn't it start?
You have activated the delayed start function. Please read following instruction from user manual.
8. Delayed Start button
Allows the start of the programme to be delayed by a minimum of 1 hour, up to 9 hours. How to set the delayed start When the button is pressed, the number appears in the display (4). Press the button again to select the number of hours by which you wish to delay the programme start, up to a maximum of 9. E.g.: if you have selected number , the wash programme will start in 2 hours' time. To cancel the delayed start set, press the button until the number appears. Close the dishwasher door to start the countdown: a long audible signal (about one second) informs you that the function is active. If you open the door again you will see, in the display (4), how long there is to go (in hours) before the programme starts. A flashing dot in the digital display means that the delayed start function has been activated. Opening the door has no effect on a countdown which has already been started. If, during the countdown, you wish to see the programme number selected in the display, press the Programme Selector button (5). If, after having started the countdown by closing the dishwasher door, you wish to cancel the delayed start, press button (9) (Cancel) for about 2 seconds until the short «instruction accepted «signal is heard».
Dado
Sep 16, 2015 | Electrolux Dishwashers
Unable to start the washing programme ,Lock key appears on the display
pick the last program you used...
press the clock button for five seconds the lock key should now be gone
if not switch off
and do every program one by one
but do take dial back to the OFF bit ???
try again
Jan 06, 2014 | Bosch Logixx WFR 2867 Front Load Washer
I have a bosch logicxx 7 washing machine. I've
Suggestion: Keep the beep button pressed or keep pressing till the beep indicates 'off'.
Mar 24, 2013 | Washing Machines
Bosch excell 7 varioperfect washing machine will not programme, the key flashes on the display
Dont worry your machine is ok
the flashing key means your child lock is on, and has to be disengaged
What you need to do is press and hold the on/off button for approx 5 seconds This should turn the lock off.
I hope this was useful.
Oct 20, 2012 | Bosch Washing Machines
How do I unlock my bosch washer dryer logixx 7/4. the red lock key symbol is on
Model WVH28420GB :
Firstly, follow the instructions for "Emergency Release" on page 13 of the Operating Instructions for this machine.
If, when you switch on the machine and select a washing programme after doing this, the key symbol still appears, press and hold down the 'Timer' button (second from top on the left hand side of the message panel) for a few seconds until the key disappears. Now operate the machine as you normally do.
Dec 04, 2011 | Washing Machines
Washer Bosch Classixx 6 1200 Express. The machine is displaying a "key locked" sign in the timer countdown panel. As there is no button to press to lock/unlock, how do I getr rid of this sign. ...
You need to press 2 buttons simultaneously for 3 to 7 seconds. Look for a small child's face or a lock icon (Sometimes both) on the Facial panel, there will be arrows pointing from that icon towards 2 buttons, these are the 2 you need to press.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Bosch Washing Machines
How do I turn off the beepers on my Bosch washer
To turn the beep off (or volume down) on the Exxcel 7 (BOSCH WAE24468GB you do the following:
1. Turn setting dial to off. 2. Turn dial one step clockwise (wait for panel to light) 3. Keep finger on 'RPM' button and turn dial another step clockwise and release finger. 4. The default setting of '2' should appear on the display, this represents the Button Signal Volume 5. Pressing 'Ready in' button cycles through the volume settings from 0 (off) to 4 (very loud!). 6. Turn dial another step clockwise to set the 'Information Signal Volume', which is also set to '2' by default. This is the one that annoys everyone at the end of the cycle!
All the manuals are on the Bosch website, if you know the model code.
Mar 07, 2009 | Bosch Washing Machines
Annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Dec 06, 2008 | Washing Machines
Zanussi Washing machine
when any of the buttons are pressed ERR is displayed.
Jan 24, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
