Question about Kyocera Copystar CS-5035 Copier
Copystar 5035 - drawer 2 - we had not been using drawer 2; tried to load it with 8.5x14 paper, however, now that we are trying to use the drawer, we are getting an error message "paper drawer is out of order"... I have consulted our Owner's Manual, but there is no information on how to rectify this problem. Thank you.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
You have to reset the drawer by; 10871087 and run SIM 906
You should be able to just key in the Code you wish, then hit the print key to activate.
Then use the touch screen to reset then print key again.
Posted on Jan 28, 2009
I have a knoncera 5035 copier for classroom use (my own) Copies got very light & I replaced the toner (INK) but the copiers are still very light. It is not hooked up to print to just copy what do I do...
There are a few things to check
Is your paper fresh
Open the left hand side and check the transfer roller sometimes people break the retainers and loose the springs etcwhile removing paper jams
Oct 28, 2013 | Kyocera Copystar CS-5035 Copier
Our Copystar CS-5035 Copier is not sending the copies to the finisher, instead they are coming out in the middle of the copier.
Press the * key and select Machine Defaults. Key in 6482, and scroll down to Select Copy Output Mode and press the Change # key. Select the desired output location.
If 6482 doesn't work use 5000
Jan 09, 2013 | Kyocera Copystar CS-5035 Copier
Download printer driver for cs 5035
go to www.copystar.co,
look under download, choose legacy black and white copiers MFP
the under the subcategory select print driver, choose the KX driver thats support your windows version, then run it and you good to go. let me know!
Nov 23, 2011 | Kyocera Copystar CS-5035 Copier
Copystar 5035 lite copies
Lite copies caused by developer unit, try to run mode 130 which will add toner to your developer, or try change the density of the copier, if non works, this means you have to change the developer unit.
Nov 04, 2011 | Kyocera Copystar CS-5035 Copier
My kyocera km 5035 has an error code of c 2642. Any suggestions?
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
Jan 27, 2011 | Kyocera Copystar CS-5035 Copier
Ii need to change the number of rings before the fax machine answers on my Copystar CS 5035. How do I do this.
touch the menu button, go to fax default, key in code 6482 and then scroll settings and change the the number of rings
Aug 06, 2010 | Kyocera Copystar CS-5035 Copier
I am just trying to find the driver for a Copystart CS-5035. I cannot find anything on the Kyocera web site.
www.copystar.com go to downloads. select legacy/mfp copiers. then select your model then under technical resources select drivers
Aug 03, 2010 | Kyocera Copystar CS-5035 Copier
Copystar 2050 DUPLEX CANNOT BE COMBINED
this is most often seen when the default drawer is disabled...dashes instead of paper size. to reset drawer try touching 10871087 then 906 and the start button this resets the disabled drawer. also make sure no paper is stuck behind the drawers.
Aug 11, 2009 | Kyocera Copystar CS2540 Copier
Paper Drawer is out of order
DRAWER OUT OF ORDER
You have to reset the drawer by;10871087 and run SIM 906
You should be able to just key inthe Code you wish, then hit the print key to activate.
Thenuse the touch screen to reset then print key again.
Jan 26, 2009 | Kyocera Copystar CS-5035 Copier
Kyocera Copystar CS-5035 Copier Logo
145 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
