Question about Hoover Washing Machines
Hoover dyn 9144 dg will not spin
Motor operates but drum will not spin up to full speed
  • 38 Answers
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Posted on Aug 19, 2007
WhIzAtIt
  • 136 Answers
SOURCE: Kenmore 20722 Motor Coupler or Cluch assembly?
Its easy to check the coupler, i would do that first to make sure then if its ok , well clutch. Kenmores, a.k.a. whirlpool's , are very common to have both problems. Just remove da pump and hoses, then remove the motor and check the coupler.
Posted on Sep 21, 2007
  • 209 Answers
SOURCE: Hoover Premier 10.1 kg washing machine
do you actually see the motor spinning? or think you hear it, check the belt hasn't come off, or gone slack, it needs to be fairly tight but not too tight, if the belt and pulley go round but the drum doesn't then you have serious damage and need a new inner drum hope i have helped and if i can help more get back to me, i am an appliance engineer of 20 years
Posted on Oct 07, 2007
ewilder693
SOURCE: smoke filled drum hoover
what's the problem
Posted on Aug 12, 2009
  • 197 Answers
SOURCE: Hoover AM1100 Washing machine, wont final spin.
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Posted on Nov 09, 2009
I have a Hoover washing machine model( DYN 10146PG-14S)operates five seconds and then turns off everything? Is there anyone who can help me please
Sounds like electrical leakage to earth operating a circuit breaker, this can be caused by many things however perhaps most common is the Heater in the machine, disconnect both wires to this bottom of the drum then try machine to see if it powers up, if yes then get/fit new heater .
Sep 30, 2016 | Hoover Washing Machines
Hoover 750 lc heavy duty macking noise whene spinning dry
Possible drum bearing. Check for any knocking by turning drum by hand whilst empty.
Sep 13, 2014 | Hoover Washing Machines
Hi i have a hoover washing machine hnf 6127 it functions perfectly but wont spin the drum goes round on the wash cycles but will not pick up speed on the spin i have checked the filter is not blocked
If it is not picking up speed on the spin cycle then it is the motor or the belt. check the belt first for proper tension and make sure the motor has the proper output. I think something is slipping and not transferring torque to the tub.
Mar 12, 2014 | Hoover Washing Machines
Hoover DYN 9144 DG - 80
washing machine won't start. display screen is flashing constantly, no error codes up. does any one know what the problem is??
Mar 23, 2013 | Hoover Washing Machines
Nov 09, 2009 | Washing Machines
Washing Machines Logo
314 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
