Question about Hoover Washing Machines
Hns 6855 z problems with the centrifuge - Hoover Washing Machines
Cleverbridge
Have you contacted Cleverbridge for help / support ... e.g. by email at:
cs@cleverbridge.com or by phone: +1-866-522-6855 (in USA)
or
0800 8620377 (UK Freefone number)
Jan 15, 2014 | Computers & Internet
Error 1 on the 5402 centrifuge how to repair problem
Dear Sir,
In a 5402 Eppendorf Centrifuge, Error 1 states primarily for an EEPROM error. EEPROM is a tiny memory chip that stores individual details of the centrifuge, mainly the microprocessor time base (for correct time set operations), the mains voltage (115 or 230 V, to inform and set the motor current levels), and the imbalance level adjustment for the imbalance sensor. When the centrifuge powers up, these data are readen, and if all OK, the centrifuge is ready to go. If one of them corrupts, especially the 115 or 230 Volt information, we get Error 1 and no start allowed.
To check and reprogram this EEPROM we have to acess the service routine. This is done by by jumping together pins 1 and 5 of X8 conector, on the base of the electronic board, located behind the power cable panel in the back of the centrifuge. There are about 20 setting or check parameters, but usually 1 or 2 of the described above need to be reprogrammed. Please e-mail me for details:
phdeletr@gmail.com.
Regards,
Paulo H. F. Pimenta
Dec 11, 2013 | Eppendorf 5402 Refrigerated Centrifuge
I have a x2600 the pictures are showing up white and have lines in them
I recently bought this from HNS and this problem only happens when I take pictures too up close! it takes a while for the camera to focus sometimes but when it does it usually looks good. I would not give this camera a 5 star, but probably a 4. If your white pictures are consistent, I would return it!
Dec 23, 2012 | GE Cameras
When I check my scale with 100lb weight it reads 100 kg or 220 lbs??
you need to turn the calibration setting to 100 lbs, then it will be calibrated
Mar 17, 2011 | Detecto Model 6855 Bariatric Scale
Centrifugal Switch Closed is what my Furnace is telling me and it will not kick on i have a Coleman Evcon heating and cooling unit
Hello, I had the same problem and replaced the Centrifugal motor which still did not fix the problem. It turned out to be the squirrel cage that the Centrifugal motor turns. It was sticking on the rubber gasket between the motor and the squirrel cage/housing assembly. I loosened the set screw that holds the cage on the shaft and moved the cage up 1/8th of an inch and it solved the problem.
Jan 13, 2011 | Heating & Cooling
Can i get an instruction manual for hinari dh1000 dehumidifier
If you fo to www.hinari.co.uk
there is a customer service no. below
CUSTOMER SERVICE: 0161 621 6900
SPARES LINE: 0161 621 6855
Sep 16, 2010 | Heating & Cooling
Dishwasher not getting hot or drying
Same Problem Here - I Noticed your Post is quite old - Please did you solve the problem my friend..........???
Dexpex@hotmail.com
Apr 29, 2009 | Zanussi 24 in. DE6844ALU Free-standing...
Zanussi aquaius DE 6855, starts off ok ,rinses ,but then stops and wont pump the water out and the lights start to flash on and off. Any ideas
Either the exit hose does not reach a high enough point or the waste-pipe is blocked. I had this problem in both situations.
Jul 31, 2008 | Zanussi Dishwashers
Washing Machines Logo
21 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
