Are you feeding the page through upside down?
Most ADF Units require the page to be writing side up as they loop over the scanner and feed out with the text facing down.
Check the ADF Tray as it will have a picture showing how the pages are meant to be placed to be fed through the ADF.
Look up at your hood... there will be one hose running to the left side of the windshield, and one running to the right side. The right (Driver's) side goes down to a "T" connector, which is right near your master brake cylinder, but up on the hood itself... it connects back there. I couldn't figure it out either... luckily I have 2 Outbacks... a 1998 and a 2001... both connect the same way.
first go to message settings on your phone and check whether message center number is there or not if not get it by calling customer care and use it ......also check whether message is sent as text or not if not make it as text and try.
You are talking about a Samsung all in one printer model CLX3185 and not a PDA right? You can put the document that you want to fax into the automatic feeder on the top of the printer or directly on top of the glass - your choice. If you use the auto feeder on top of the printer, look for a picture of paper near the insertion point that shows you whether the text side goes down or up when you put the paper in. If using the glass on the flat bed, the text goes down.
Once the document is loaded in either place, push the button that says "fax" and enter the number with the Country Code first and then press start. The line you are using to fax should have international calling enabled in order for this to go overseas.
If you have Microsoft word on you computer, you may do any one of these steps that you are most comfortable with. First, you may click the document twice to rename it eg "name.doc" insure that you put .doc at the end or you may right click the file and choose open with and select Microsoft word and then go to save as and save it as a word document. Or you can open the file in word-pad and copy the text and paste it in a word document and save it. Rich text format is a Microsoft word-pad document while .doc is a MS word document or now they have .docx.
There is never ant option for .txt docs. It is only for a word doc and what you save it as is your problem. So, dont worry about it. After .txt you will ask for normal txt or rtf. The list is very long. So, the short cut is to open a new doc and save it as whatever you want.
Is the issue the same with a anormal text document or just with heavily colored docs?
If the text doc gets printed fine, then it is an issue with print spooler and we might need to work on that.
revert & lemme know
