Question about LG 42LC2D 42 in. LCD HDTV
Jvc tv HDMI invalid mode - LG 42LC2D 42 in. LCD HDTV
Why can't I use the HDMI port on a JVC LT-42E478?
your hdmi is not connected tight or the cable is bad,or it is dirty,use canned air to clean out plug.extend your comp screen to the tv
Jul 14, 2015 | JVC Televison & Video
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Jan 21, 2015 | JVC Televison & Video
Tried to conntect my xbox 360 slim to my 46" JVC tv via hdmi cable but it wiill not show up, but the tv does display the ps3, i have tried it with different leads and different ports but still nothing, i...
the settings on the xbox are not in the right mode for your tv. you need to change them projectors are 720p so you would need to change the xbox to this.
Oct 21, 2013 | JVC Televison & Video
I have an HDMI hooked up from the back of my DVR box to my JVC, but the picture still doesnt look as clear as it should.. Would it have to do with how my settings are programmed? If so, how should my...
Check ur DVR box setting make sure is on HDMI cable setting mode or HD setting mode.The picture will be in HD setting and the picture will be coming into tv clearly.
Apr 21, 2011 | JVC LT42P789 42 in. LCD TV
I have a jvc LT42P510 tv and it is hooked up to a Dish Network 722k hi-def dvr receiver, the dish remote will not function in the dish mode, for example when the dish receiver is plugged into the tv using...
hi,
Check the version of the hdmi cable you used. Try to use hdmi cable version 1.3 or above . Also try hdmi cable with version 1.2 .Version of the cable is very important one.
ok
Mar 04, 2011 | JVC LT42P510 42 in LCD TV
When I connect the HDMI cord from the ps3 to the t.v. is say's invalid mode.
you need to go into your ps3 settings and pick HDMI.
unless you did that and your tv is not 1.3 HDMI (that is the version of the software that speaks to your tv from ps3)
Dec 14, 2010 | Protron PLTV-26 26 in. HD-Ready LCD...
Not getting hdmi signal from pc to tv
turn off pc completely(shutdown) make sure hdmi cable is unplugged. plug into tv first, turn tv on, plug hdmi cable to pc then power up, it should now be able to recognize the tv. Try it in projector mode if available.
Mar 17, 2010 | JVC TBC Remote For Pro SVHS VCRs Remote...
Jvc 56dlp connect computer
If you are getting an invalid input its because the resolution setting on your computer is probably set too high. The JVC only accepts 2 resolutions one is like 600x400 and the other is 1280x768. I had this problem all the time with vista. It can't seem to remember what resolution to use. The exact setting are also listed in owners manual.
Apr 08, 2009 | JVC HD-52G786 52" Rear Projection HDTV
I have jvc 61 hd hila and my hdmi d ont run , not actived
You need to change the Input mode of your TV to HDMI and also the device you will connect to the TV should aslso be slected to HDMI.
There is nothing seperately that needs to be activated.
Thanks
Nov 28, 2008 | JVC Televison & Video
Setting up Unit
I called the JVC tech service rep. I went from the Cable box to the JVC unit with a Digital Optical Cable, from dvd/vcr player to jvc unit with a Composite Cable and Audio Cables. From cable box to tv with hdmi cable and from jvc unit to tv with componet cables and cable box to dvd/vcr with Audio/ Video and S-Video cables. This allows me to have the cable TV access and Surround sound in all mode. I have HD and Digital surround sound in three diiferent modes. Everything is working great.
Thanks for the opportunity for help just the same.
Sincerely, cthomas249
Sep 25, 2008 | JVC THD-50 System
LG 42LC2D 42 in. LCD HDTV Logo
132 people viewed this question
Computer Repairing
Computer Repairing
