Question about Dryers
My tumble dryer keeps squeaking when running and there is black dust around the bearing at the back
2 Suggested Answers
SOURCE: Squeaking!!!!
Asko T701 dryer,
Squeaking loudly for the full dry cycle
Warrant wet out last year. We complained to the repair man that it was squeaking prior to the warrant running out, he said they just do that. It is now very loud and I know noise = friction, and I am concerned. I looked into it and sprayed some silicon on the belt, but it sounds like the front gasket is the problem.
Is this a common problem, and is there a common fix?
John
Posted on Jan 21, 2008
Indesit idv65 tumble dryer squeaking really loud
hi check drum bearing to see if worn
Jan 21, 2014 | Dryers
Whirlpool tumble dryer making a loud noise
the dryers drum that spins around is driven by a belt . A belt tensioner is attached to provide a secure fit when turning. The tensioner has a idler pully which has a bearing in it. When worn the bearing squeaks or wears out causing this noise you have. Sears sells the belt and idler pulley as a set to retify this situation you have. Instructions come with these kits
May 11, 2012 | Dryers
My dryer squeaks upon starting to dry a load of clothes...everything else works fine except it squeaks the whole entire time. Any advice?
GE dryers have a straight rod in the back center of the drum that goes through the rear bulk head and that is what supports the drum in the rear, it is also what squeaks when it gets warn out , around that short rod that goes into rear bulk head from the drum is a black Teflon plastic sleeve called a barring replace it and that will fix the noise
Apr 05, 2010 | GE DVL223EBWW Electric Dryer
The dryer was squeaking when it was on but know it
possible worn bearing.the more wear on the bearing the lower the drum will be.the drum sounds like its rubbing the bottom of the dryer.check for black dust behind the dryer
Feb 20, 2010 | Amana Dryers
Tumble dryer is very noisy
i had the same problem.it ended up being the bearing that holds the drum in place.it had worn that bad that the drum was rubbing the bottom of the dryer.the bearing is located on the back of the dryer if the bearing is worn there will be like black dust around the area.this does stain so be carefull
Feb 19, 2010 | Miele Dryers
Dryer drum squeaking when operating
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fggf
May 24, 2009 | Fisher and Paykel DE60FA-US Dryer
Dryer Squeaks
ok your having the begings of a rear bearing problem now let me tell you whats happing if you pull the dryer out and look about at the middle of where the drum is at the back then you will see a silver small rectangle peice in the middle of that is what looks like a small finger with a steel ball under it on the little ledge there should be a little pile of black dust the little finger is making the little ball cut into the back of the rear bearing but the rear bearing is still good now get you a little can of spray lithem grease clean the dust off turn the dryer on and spray that little ball till its coated then every time you hear it squel repeat the proceadure untill one day it wont stop then we will have to change it and on that day you better have some help lol
Mar 31, 2008 | Kenmore 94702 Front Load Stacked Washer /...
Squeaking!!!!
see the video on bearings
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Nov 19, 2007 | Dryers
Dryers Logo
13 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
