Question about Optics
My rws excalibre not holding its charge of air what could be wrong with it
When i charge my excalibre with 200 bar maximum of air its not holding the air what could be wrong with it
Rifle will not fire,side bar rod and cover broke long time ago,i threaded a 3/16 rod iwas able to crank it back loaded it but it will not fire.
  • Get the proper spares for it. You know it has a safety?
  • DIANA ORIGINAL : Model 48 & 52 - Airgun Spares www.airgunspares.com/store/category/64/791/DIANA-ORIGINAL/Model-48... Diana/Original Piston Seal. Fits Models: 34, 36, 38, 46, 46E, 48, Stutzen, 300R, TO5, P31, 66, 75 & Remington Express
  • Diana/Original - Airgun spares ' Chambers Gunmakers ... https://www.gunspares.co.uk/categories/24035/DianaOriginal ... Shotgun & Rifle spares. HOME ' CATEGORIES. Airgun spares; ... Diana/Original - Airgun spares. Please select the MODEL you require`
  • RWS Parts. Diana RWS Air Guns, RWS Air Rifles and ... www.pyramydair.com/m/RWS-Parts/44/73 RWS Parts. We carry Diana RWS Air ... You must be 18 years or older to buy any air gun or air rifle in our ... (T01) Model number 30223000. Umarex: RWS. Starting at ...
  • May 01, 2016 | Optics
    1999 flhr road king shock air pressure
    Recommended Suspension Air Pressure: FLHX, FLTRX, FLHR/C
    SHOCK LOAD TOTAL WEIGHT PRESSURE
    LB. KGPSI kPa
    Solo rider up to 150 up to 680 0
    150-200 68-91 0-10 0-69
    200-250 91-113 10-20 69-138
    250-300 113-136 20-30 138-206
    over 300over 136 30-50 206-345
    Solo rider with capacity
    luggage of 40 lbs (18 kg) up to 150 up to 68 10-20 69-138
    150-200 68-91 20-30 138-206
    200-250 91-113 30-40 206-276
    250-300 113-136 40-50 276-345
    over 300 over 136 50 345
    Rider plus passenger ALL ALL 40-50 276-345
    Maximum GVWR ALL ALL 50 345
    If Tour-Pak is installed, add 5-10 psi (34-69 kPa) to shock pressure.
    Do not exceed 50 psi (345 kPa) suspension pressure.
    May 13, 2014 | Harley Davidson FLHR Road king Motorcycles
    Replace main spring in RWS
    hello friends you broke my rifle spring my rifle crosman optimus ea .177 cal. and the dealer put a new one, but it has presicion not know if I should wait for 500 shots or more like new or will be another problem, thanks for your help
    Oct 08, 2012 | RWS Diana 34P air rifle - 0.177 Caliber
    How much air should be in a 2008 road king classic air shock
    SOLO RIDER
    Up to 150 lbs = 0 psi
    150 - 200 lbs = 0-10 psi
    200 -250 lbs = 5-15 psi
    RIDER WITH PASSENGER
    Up to 150 lbs = 10-15 psi
    Up to 200 lbs = 20-25 psi
    MAXIMUM = 20-35 psi
    Aug 28, 2012 | 2008 Harley Davidson FLHRC Road King...
    How much air pressure to put in shocks with 2 riders
    2006 Touring shocks =
    Table 2-6. Rear Air Suspension Pressures
    Shock Loading Recommended Pressures
    PSI kPa
    All Models Except FLHRS, FLHX - Standard Shocks
    Solo rider up to 150 lbs. (68 kg), hereafter referred to as "Average" 0 0
    Solo rider 150-200 lbs. (68-91 kg) 0-10 0-69
    Solo rider 200-250 lbs. (91-113 kg) 5-15 35-103
    Average rider with passenger up to 150 lbs. (68 kg) 10-15 69-103
    Average rider with passenger up to 200 lbs. (91 kg) 20-25 138-172
    Maximum GVWR (see Section 2.1 Specifications) 20-35 138-241
    FLHRS, FLHX Only - Low Profile Shocks
    Solo rider up to 160 lbs. (73 kg), hereafter referred to as "Average" 0-5 0-35
    Solo rider 160-200 lbs. (73-91 kg) 0-10 0-69
    Solo rider over 200 lbs. (91 kg) 5-10 35-69
    Average rider with passenger up to 150 lbs. (68 kg) 20-30 138-207
    Average rider with passenger over 150 lbs. (68 kg) 25-35 172-241
    Maximum GVWR (see Section 2.1 Specifications) 40-50 276-345
    111WWAARRNNININGG
    Use this table as a starting point in determining suitable rear air suspension pressures. Do not exceed
    maximum GVWR when loading vehicle and do not pressurize system in excess of 50 psi (345 kPa) for
    FLHRS, FLHX models and 35 psi (241 kPa) for all others. Excessive load weight and/or air suspension
    pressure can adversely affect handling and lead to loss of vehicle control, which could result in loss of life
    Aug 30, 2011 | 2006 Harley Davidson FLHR Road king
    Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
    You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
    Maximum Memory: 2GB
    Slots: 2
    Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
    Hope this helps.
    Jun 17, 2011 | Acer Aspire 5315 Notebook
    What kind of blank DVDs do I use to copy an old VHS video tape to the DVD? I have the Sony RDR-VX530. When I put a DVD in, I get an Error message saying that I have the wrong DVD.
    According to page 30 of the operation manual, the following information may help;
    DISCS THAT CAN BE USED IN THIS RECORDER:
    4x-speed or slower DVD+RWs
    2x-speed or slower DVD-RWs (version 1.1, 1.1 with CPRM) (Content Protection for Recordable Media)
    4x-speed or slower DVD-RWs (version 1.2, 1.2 with CPRM)
    16x-speed or slower DVD+Rs
    16x-speed or slower DVD-Rs (version 2.0, 2.0 with CPRM, version 2.1, 2.1 with CPRM)
    2.4x-speed DVD+R DL (dual layer) discs
    (when using DVD+R DL discs, see the instructions supplied with them prior to use)
    4x-speed or slower DVD-R DL (dual layer) discs
    DISCS THAT CANNOT BE RECORDED ON:
    DVD-RWs (version 1.0)
    DVD+RWs that are not 2.4x-speed compatible
    8 cm discs (mini-DVDs)
    DVD-RAM (any speed/any version)
    DVD-R DL (dual layer) discs in VR mode
    A free pdf copy of the manual for this model can be downloaded online.
    Hopefully that provides some insight to your question.
    May 25, 2011 | Televison & Video
    How do I install a main spring in a RWS 34 spring airgun
    You actually need special mainspring compressor to accomplish this. HOWEVER I strongly recommend you do not attempt this yourself. These springs are under a lot of pressure and can put a world of hurt on you should you screw things up. I suggest you contact Pyramid AIr to see how much they would charge you to send back.
    Feb 28, 2010 | Sport & Outdoor - Others
    I am charging the Garmin Edge 305 for 24 hrs or for at least over night, yet the Edge 305 will show 2 to 3 bars of charges and will last maximum 1 hour of riding time. What to do?
    Discharge completely device then charge again for 8 hours.
    If not working, then attempt Soft reset :
    Hold mode and lap/reset for 10 seconds then release.
    Start the device then by long press on start. DEvice should start and charge then
    Mar 16, 2009 | Garmin Edge 305 GPS Receiver
    Nuvi 200
    Do you have a garmin home charger.
    To do a test , is that working when you connect your unit with the car charger.
    Less than 0.9 % of the units has a battery problem. I don't think you have one.
    When it's full charge , what is the maximum bars you get ?
    Dec 09, 2007 | Garmin Nuvi 660 GPS Receiver
    Optics Logo
    47 people viewed this question
    Top Optics Experts
    Joe Lalumia aka...
    Joe Lalumia aka...
    Mark Campeau
    Level 1 Expert
    Are you an Optic Expert? Answer questions, earn points and help others
