Question about Miele Washing Machines
W1716 showing fault F63 can't find handbook
What is F63 fault?
I have a 2002 holden Astra and want to know which Fuse is for the window washer as it stopped working, the manual does not show it, only the wipers and they still work
I suggest you check in the vehicle handbook to make sure but I think the washer fuse is a shared fuse and if everything else works the problem is unlikely to be a fuse.
I suggest you check the washer pump first as these fail fairly regularly, either because water has leaked into the motor or because of corroded connections.
If the pump works ok with an independent supply and ground, move on to checking the supply and ground separately with a test lamp. If this proves ok suspect the pump of having an intermittent fault. If there is no supply the fault might be a faulty switch but it would be wise at that point to check the circuit with a wiring diagram before proceeding further.
May 15, 2016 | Holden Cars & Trucks
I have 2004 x type sports 2.D
I doubt it but advise you to refer to your vehicle handbook for a definitive answer and the correct operating procedure. If in doubt consult the local dealer as it is possible there is a fault.
Feb 25, 2015 | 2004 Jaguar X-Type
Car will not start.
and the mystery vehicle is????
Aug 10, 2017 | Cars & Trucks
My s type jaguar dtc p1638 i dont undarstand the mining of that why, 2000 year it asking me to look in the manual tecnical book
Fault codes are listed in the technical handbook, no good to you as it's a Jaguar service item unless you can get a copy of JTIS from ebay etc.
Fault Code:- P1638 Indicates a Power-train fault
The fault is generally due to a problem in the Computer & Output Circuit area
Fault Description: CAN ECM / INST network malfunction
Action of ECM:- none
After clearing the DTC, complete the Ignition ON 10 seconds
Check for a reoccurrence of fault DTC.
Possible Fault:- CAN open circuit fault - INST to ECM CAN short circuit fault INST failure ECM failure D
May 26, 2011 | 2003 Jaguar X-Type
We have a washing machine WD-1274FHB which is not working and showing error code SE which is not in handbook - help - wife has a pile of washing & is stressing out. Jim
SE fault on this washer is a failed hall sensor on the motor. You will need to replace the drive motor as the sensor is not replaceable.
Part No. WMD-300C2
Apr 25, 2010 | LG Washing Machines
My hyundai 1.6 petrol matrix has intermittant
answer from the uk.you will only have a problem showing up if the engine management system records a fault within that system, so, the only solution is, if you have remote locking,change the batteries and use to unlock car not using the key.or if no remotes,change keys on a regular basis.(they are coded to the car) do not use grey (service key) only 2 x black keys supplied with car....check handbook re keys....
Mar 23, 2010 | 2007 Hyundai Sonata Limited Sedan
Have a 2004 GTO with the following error: Fuel Guage Error - Contact Dealer Service Error - Contact Dealer Air Bag Fault - Contact Dealer Any idea how to fix this?
If these are false readings (which I doubt) you can try resetting the system to restore all factory default settings. You need to have the system set in customisation mode to do this.
Check your vehicle handbook which explains the steps to do this.
Once reset drive the car and check the warnings.. If they remain (and they probably will) you will need to take the car to the dealer to diagnose and rectify the problem.
Your handbook explains what each of the warnings means and the air bag fault warning should not be ignored. "Service error" means there is a fault with the instrument panel and Fuel Gauge Error means there is a fault with the fuel level measurement system
Oct 20, 2009 | 2004 Pontiac GTO
Electrical problems
i had the same problem. i had to get another central locking motor. but in ur handbook there is a way to open ur petrol can manually i cant remember how off the top of my head but if you dont have ur handbook i will dig mine out. i asked somebody to pick me one up from the scrap yard and they said they were missing from all polos and golfs so i think it is a common fault.
Apr 25, 2009 | 1999 Volkswagen Golf
Washing Machines Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
