Question about Nintendo Wii Console
Wii console to Philips HDTV Connection not working
I connected my Wii console to a new Philips HDTV using a universal component cable. In the Wii "settings" under "TV resolutions" I can see the HDTV tab to select, but it is grayed out & cannot select the option. How do I get my Wii console to recognize my HDTV?
  • 57 Answers
In order to use the 480p (HDTV/EDTV) resolution, you MUST be using the Wii Component Video Cable. Any other cable will not display the 480p resolution, you have use the 480i (Standard) instead. You can order the Wii Component Video Cable through Nintendo's Web site. Using that cable, you can select the 480p resolution. Hope this helps.
Posted on May 16, 2010
  • andre felix Nov 15, 2011
    Yeah, but the problem is: With the component cable and the Wii set to 480i, there's no image on TV. So how can I set it to 480p? :(
  • 52 Answers
You need an aftermarket 480i connector got mine off of ebay for 10 bucks. it will have 5 wires insted of the three. connect this to the green red and blue jacks and the red and white to the audio in. hope this helps good luck
Posted on Aug 30, 2009
  • rcastro775 Jan 12, 2011
    I'm a bit confused... ThEDSfan says you need to use a genuine Wii Component Video Cable and another, Vatillson, says you can use an after-market cable. Which is which and why are some after market cables working while others wont?
Wii to Philips LCD TV 32"" - sound but no video. Just bought a refurb. Philips LCD TV for our WII. The standard AV cable gave sound, no video. The warning message flashes up in the beginning...
Looks like the AV port in your Philips television is busted. It's the only factor if the Wii is able to function with other tv with the same cable. You can either purchase a new television/get the one you have fixed (these will cost money) or you could just purchase an hdmi cable which doesn't use the same port so it could possibly work with your Philips television.
Jul 07, 2011 | Nintendo Wii Console
My wii console has sound but not visual checked all connections all ok it is connected by component cable please advise
Try to connect your Wii to another component input on the same TV, or to another TV. If the video works in one of those cases, then there is a problem with the TV. If not, your cable is likely broken. Try using a new component cable. If all this fails then there is a serious issue with your console that probably cannot be repaired at home.
Mar 11, 2011 | Nintendo Wii Console
The picture appear black&white. I have HDTV.
I had this problem with a 'universal' console component video cable. Had a B&W Wii screen, and couldn't set the Wii to HDTV.
Spent most of an afternoon switching the Wii between LCD televisions, annoying Samsung tech support (who are a very, very good tech support system, by the way) and so on.
Took back the cable and the guy said, "Did you remember to turn the little TV/HDTV switch here?"
There IS a tiny little switch on these combo cables, right on the common point of the various console connector plugs. I switched it. It worked. All is good again. Hope so for you too.
Dec 28, 2010 | Nintendo Wii Console
New Wii is in black and white on my Samsung tv...any suggested fix?
    What to do will depend on how you're connecting your Wii console to your TV.
    • With the yellow, white, and red AV cables that came with your system:
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs.
      • If this is your first time hooking up the Wii console or have you moved it to another TV, Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
    • With the blue, green, white, and red component cables (sold separately):
      • Review our step-by-step Wii Component Cable to make sure the cables are properly inserted and that your TV is set to the proper input.
    If you have verified the connection is correct, and are still receiving a blank or black and white screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700
Dec 26, 2010 | Nintendo Wii Console
I plugged our wii into new tv. the screen shows a black and white picture. how do i fix it?
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs... if this is your first time hooking up the Wii console or have you moved it to another TV, . Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
Having just installed a new Wii console I have good sound but everything is in fuzzy black and white - no colour at all. What should I do to get colour?
      • Review our step-by-step Wii Component Cable connection guide to make sure the cables are properly inserted and that your TV is set to the proper input.
Nintendo Wii works fine on standard tv but not on hdtv.
FOUND THE PROBLEM !!!!! The problem appears to be the Freeview somehow interfering with the Wii signal. When the aeriel lead is removed the Wii works fine, and the audio/visual signal is great. When the aeriel lead is in I have the problems. I hope this solution proves to be of use to anyone else having similar problems.
Dec 29, 2009 | Nintendo Wii Console
Nintendo Wii AV Cables not work
It could be a problem inside the Wii where it only outputs a signal through HD. Have you tried a different TV using the original cables? If the problem persists I would recommend calling Nintendo.
Jul 27, 2009 | Nintendo Wii Console
Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
Feb 25, 2009 | Yamaha HTR-5760 Receiver
Hook up
hi, im using a HDTV with my wii, but im just using the standard cables ie, wii - skart connection , one to wii sensor, and one to mains plug from wii,
and works fine..
All the best
john
Jan 02, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
1,359 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
