How do i select AV2 whithout remote ..in BPL quadra point focus tv,
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: not getting all the channels provided by the operator in old bpl tv
BPL quatra focus have a tunner which doesnt support S band and Hyper band. If you have to get allmost all channels then you have to upgrade the tuner. Tuner is component inside the TV to wich we attach the antenna or cable. There is no other option other than replacing the tuner. Replace a tuner with S band and Hyper band capability. If you need any more assistance feel free to contact by fixya. Tuner will look like one in the picture wich you will find inside the tv.
Posted on Jun 16, 2012
Testimonial: "Thank you...:)"
Sir I have loss remote of BPL TV model no. FWR 59WA1.plz tell me which no remote applicable for that tv.
Umesh, Check the attached links, the remotes may be what you are looking for, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
MEPL BPL TV REMOTE Model ISORT JXPSE compatible
Compatible BPL TV Remote No RC 66RL 33RL
Jun 16, 2016 | Televison & Video
HOW UNLOCKED IT?"MY BPL T.V. IS LOCKED"
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Aug 16, 2015 | Televison & Video
Need the code for rca DVD RTD315 SYSTEM FOR DirecTV REMOTE RC66X
Direct TV press menu scroll down to settings& help select settings scroll down to remote control select program remote AV2 select select DVD scroll down to RCA move switch to av2 codes press mute and select until light flashes twice enter code press powerare 20522,20571 ect more codes are abailbe by selecting more codes if code work move switch back TV
Jul 24, 2015 | RCA Televison & Video
Not getting all the channels provided by the operator in old bpl tv
Jun 16, 2012 | Televison & Video
BPL PSM ON problem
Picture Status Memory(PSM): Selects excellent preset picture controls for multi-media, personal, movies, sports, and weak signal programs. usually on remote control, or in TV setup.
You need to use your manual and turn it Off.
Apr 18, 2010 | Televison & Video
Need codes for proscan to put in direct tv remote
phone_header_def.png saveupto_a.png phone_callnow_def.png DIRECTV Specials DIRECTV Packages DIRECTV Receivers DIRECTV DVR DIRECTV HD DIRECTV vs. Cable DIRECTV vs. Dish DIRECTV Sports Home > Remote Codes DIRECTV Remote Codes remote_codes_header.jpg TV CODES VCR CODES DVD CODES STEREO RECEIVER CODES
STEREO AMPLIFIER CODES DIRECTV RECEIVER CODES
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
May 06, 2009 | Proscan 32LA30Q Television
Need code for Directv remote for 26LG Flat Screen TV
Program TV Code
1. Turn on the TV.
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Jan 14, 2009 | Directv RC23 Remote Control
You just dropped me without answering my question or really even trying
I can see you are frustrated so I'll see if I can help. Here are the Akai TV codes:
10812, 10702, 10030, 10672, 10060
As you can see, they are 5-digits for the direct remote, not 4.
This should help!
Program TV Code
1. Turn on the TV.
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Hope this helps
Happy New Year!
Chris (ziraffa)
Dec 31, 2008 | One For All URC-3021 Remote Control
Sharp tv 2004 model
Program TV Code
1. Turn on the TV.
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
Jan 26, 2008 | Audio Players & Recorders
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
