Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub-Zero 550 water dripping on right side of freezer forming ice on draw
I have a Sub-Zero 550 and water is dripping onto the freezer draw and freezing making it hard to open the freezer. It seems like water is leaking out of the tray. How do I fix? How do I get to the tray and drain line to see if it is plugged up? I have the same problem. Technician investigated today and after defrosting the ice build up, figured out that the condensation drain itself was broken. He had never seen this before; the Sub Zero people said there is no fix as the drain is encased in the foam insulation. As the unit is 15+ years old, Sub Zero said we were on our own.
  • Anonymous Jan 29, 2009
    Water is leaking into the freezer and freezing on the tracks.
    It must be the same issue, My 550 is 21 years old and is a piece of junk!
  • Anonymous Jan 31, 2009
    12 year old subzero. Same problem. Ice forms on right side track, and you could kill yourself while (unsuccessfully) trying to open the freezer.
    Should not happen in an expensive refrigerator like this.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
The drain line has been clogged. There is actually a defrost heater kit for that problem if you can get the obstruction out. Did you call factory at 800-222-7820 or a local factory authorized servicer? The drain is accessed by removing the fan shroud and evaporator cover. There are a number of of phillips head screws that hold this in place. Once you have removed the two cover you will see the drain tube on the left side of the unit. I use a hair dryer to start defrosting the tube. If you have another freezer in the house it is easier just to turn the freeezer section off for a day or so. I use nitrogen to blow the line out from the bottom once everything has defrosted. Test for water flow, then put unit back together. Call the factory at the number above for the heater kit part number and they will also give you the local authorized parts supplier. The locator web address is http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code
Posted on Feb 22, 2009
  • Larry4490 Oct 02, 2010
    Had the same problem. Blew out the line instaled the tube heater kit. Problem solved. Our 550 is older than I can remember and still runs great.
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
My Sub-Zero drain ices up too!
There is a drain tube heater and a floor pan heater kit for this model from Subzero
This is Not for a DIY project
Affordable Appliance Repair
Lake Forest, CA.92630
Aug 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Subzero 550 Gurgling whenever door closes
Personally it does not bother me that much on mine. But since you asked, there is drain line that runs into the drip tray underneath. The line should not have any bends in it to form a P-trap which will hold enough water in to form a seal, so when the door closes and the pressures equal you have a gurgling sound. If it really bothers youtry these steps, remove the kick plate by removing the two phillips head screws on either side. The drip pan is suspended in the middle of the support and will probably have water in the drip pan so put a towel down before you start. Once off shine a light to see if the tube has a bend in it. Depending on when it was made there may be a clamp that hold the drain tube in place. Carefully pull the hose past that clamp to remove sag and eliminate the bend which forms the P-trap. You have to be careful as the hose maybe brittle and come apart. So if you pull to hard you may wind up replacing that line which requires pulling the unit at considerable cost. There is a check valve that can be ordered but was only used for a short time. The inline check valve was a part number 4202130. If it bothers you too much and don't want to try the fix here is the Sub Zero locator page for parts and service. http://www.subzero.com/locator/locator.aspx?type=0&zip=02030
Dec 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
550 Sub zero
your drain is clogged or frozen over,the drain is most all the time in the middle back bottom of freezer,you might have to remove the freezer back wall to get at the drain,use a hair dryer to melt the ice and a metal hanger to clear the drain,let me know how you make out-mike
Nov 02, 2008 | Sub-Zero Refrigerators
Sub Zero 550 series... The freezer door gets stuck and won't open. There's frozen condensation leaking.
The right side of the freezer has a drain that is plugged with ice. When the freezer defrosts the water runs down the inside of the box and onto the drawer rails, where it then freezes. The drain tube is normally kept ice free by an aluminum strap wrapped around the copper defrost tube in the freezer heat exchanger, which runs down into the drain tube. Over time the copper defrost tube gets some surface corrosion and the aluminum strap doesn't get warm enough during the defrost cycle to melt ice in the tube. If you can get it apart, you can clean up the tub surface with steel wool, or buy the electric defroster for the drain tube to replace the aluminum strap.
Sep 15, 2008 | Sub-Zero Refrigerators
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
I had a similar issue that started about a year ago with my Sub-Zero 550. My freezer gasket actually tore after several times of freezing closed. I thought that a new gasket would solve it, but a second but related problem developed where I was getting alot of condensation under the left side of the unit, with the water dripping onto the floor...eventually staining the hardwood floor in front of the unit.
I traced the problem to a clogged condensation drain pipe in the refrigerator. It is a corrugated pipe that drains a trough behind the crisper drawers. My pipe was clogged with black sludge and frozen down below. The condensation in the fridge would overflow out of the trough and leak below the crisper drawers, down out through the gasket.
To resolve, I used a piece of solid thin wire folded in half and twisted with a small loop at the end to fish out as much sludge as I could. Then squirted hot water into the pipe until it totally unclogged. I believe this will solve the problem without any need for a heater underneath the unit. The 550 worked fine for 4-5 years before this happened.
Jan 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Ice in Refrigerator Section
there are 2 possibilities. first the drain is blocked causing water to overflow from the defrost water gulley at the bottom rear of the inside of the fridge. this can form ice as it is close to the division between fridge and freezer. second, the .fault of ice growth can be caused by breakdown of the cabinet insulation. of the two, the first is the moree likely. to test drain is cloear, pour a little water down the drain. if it does'nt flow freely, push something flexible down the drain hole till blockage is clear
Apr 14, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
1,247 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
