Question about Dryers
I have a dryer with a 240v 30amp plug i just moved to a house that has a 250v 30 amp outlet what can i do this seems to be the new standard
  • kaybeebflo Jan 27, 2009
    This pointed in the right direction but the whirlpool manual clinched it. They show the installation of a 4 line plug and detail instructions for putting it on the machine. helpful hint for anyone else trying this, remove or **** the black plug to give the individual wires more room to flex where they need to go.
    Sniper:
  • 50 Answers
Go to a good hardware or home center store and look at the dryer plugs if they are the same as the one you have good if it differs buy new cord replace it wire for wire at terminal block in rear of dryer
Posted on Jan 26, 2009
I have a 440v 50 amp and a 220v 30amp main breaker box outside my house. the 440 goez to the inside of the house and i have to unplug the 440 and plug in myown 440 plug i connected to another breaker box...
Some of these numbers don't make sense?
I have Never heard of 440v and 220v in a residential application, they are two different systems, 480 volt is typically 3 phase power, and 240v is typically single phase, more in likely you have a 200- 400 amp main service, and a 100- 200 amp secondary service for the welder, that can't be 110 @ 200 amps?
I would need more info, and pictures of actual nameplates of the equipment,
and then I could advise a safe NEC electrical code answer...
Mar 17, 2015 | Electrical Supplies
How to connect a dryer
Hi Sheliah,
I'm an electrician and would like to help you. Assuming you're in the U.S. and this is an electric dryer (not gas), you will need to find a 240 (a.k.a. 250) volt / 30 amp circuit to connect it to for it to work. This would be connected to a double pole 30 amp circuit breaker in the electrical panel. There is no simple residential "adapter" to change voltage, current or number of wires - besides the old 3 wire grounding plug adapter in you grandmother's junk drawer. (What is a 50/250 volt dryer? - did you mean a 30A/250V?)
Your dryer should have a 4 wire cord with a 4 prong plug on the end - and it will need to be plugged into a matching outlet. The old electrical code allowed you to change the cord to match the outlet, but now it requires that both the cord and the outlet be a 4 wire type. The old 3 wire cord type is no longer permitted to be used when the dryer is moved or replaced. Of course, 3 wire cords are available everywhere and it is unlikely that anyone will turn you in for changing the dryer's 4 wire cord back to a 3 wire cord type (but I just wanted to tell they way it is supposed to be done). What you do - is your business.
If you have a gas (or LP) dryer, you probably only need a 120 volt / 15 or 20 amp outlet - they look like the standard types - but I think you'd have simply plugged it in and walked away if that were the case.
I hope this helped!
Apr 07, 2014 | Dryers
Will a spa with 240v ac, 60 hz 40a connect to an outlet with 30a-125, 250v
I read your question to mean that your spa is rated for a connection of 240VAC and 40 amps at 60 Hz. If that is the rating then no, do not connect it to an outlet only rated for 30 amps, period.
Sep 15, 2013 | Pool & Spa
I want to build a connection 30am breaker for dryer in my house
Honestly, thats something you would need to contact an electricain about due to permits and law requirements as far as wire soze for what distance, etc. For as long as I've been doing this line of work, going on 12-13 years, the breaker for the dryer has always been located outside near the meter with all the other 220 vac breakers.
Apr 30, 2012 | Dryers
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
How do you connect the LG DLEX5101V Dryer to the electrical outlet on the wall if there is no cord to plug in?
There are a couple of types of plugs in homes - and the dryer manufacturer use this excuse to not ship a cord with the dryer - profiting that much more. You'll need to purchase a cord set for your dryer. Assuming you live in the U.S., that means you need a 30 amp 240 volt cord. That's easy enough, but it does get harder.
Most homes have an outlet that has three slots in it - like the one below:
A 240 volt, 30 amp, 3 wire dryer plug.
New homes have a safer, 240 volt 30amp 4 wire plug. They look like the one below:
A 240 volt, 30 amp, 4 wire dryer plug.
The code states that when a dryer is purchased it should be connected via a 4 wire cord. This means if you have the older, 3 wire outlet - it will have to be changed along with the entire length of cable between the electrical panel and the outlet (the new outlet needs a 4 wire cable - the older plug was supplied by a 3 wire cable).
Those are the rules. Many people opt to purchase the older 3 wire cords so that they can connect directly to the 3 wire outlet already installed in their home. As an electrician, I have to caution you on doing that. It is a violation of the electrical code as it has been identified as an unsafe condition. The code hopes to rectify this by slowly requiring new dryers to be wired with 4 wire cords and making the homeowner upgrade the old 3 wire outlet to a newer, safer 4 wire outlet. Of course, no one will come to see what you had and if you changed it, etc.
Mose hardware stores, Home Depot, Lowes, etc. sell these cords for under $20. Make sure you choose a 30 amp dryer cord - and not the similar looking but thicker 50 amp stove or range cord.
I hope this helps & good luck! Please rate my reply.
Mar 22, 2011 | LG Dryers
Kenmore Elite HE4 dryer- can I change the plug from the present 4 pronged utility plug to a standard 3 prong plug and still work safely?
NO, You will need to get an electrician to install a NEMA 14-30R outlet for your dryer, the electrician will know what you need, in anycase a 240V 30amp outlet is needed if you dont already have one. DONT replace the plug.
Jun 20, 2010 | Kenmore Elite HE4 Electric Dryer
My mde7600ayw is a 3 wire 120/240 v 60hz 5600w.
Hi, yes that is the correct cord all right. If you'll notice the new cord has 2 hot (red & black) a neutral (white) and ground/earth (green) wires. In case you are not sure how to connect I've attached a photo which shows the correct way. If my attachment didn't work, check out you-tube and type in "4 wire dryer hook up". Thanks for visiting "fixya" and good luck macmarkus :) IMG_3336.JPG
Apr 19, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
I am re-wiring an outlet in my garage that normally goes to an electric dryer. I want it to have 30 amp 120V. Do I just leave off the red wire? And don't they make a 4 hole recepticle that will accept...
Yes on the red wire. I don't know of a 4 hole receptacle but that doesn't mean it doesn't exist. Do you also plan to change your breaker? You'll need to disconnect the red wire and cap it.
Here's a link to some instructions on how to do your project. Good luck!
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/Change-existing-220V-dryer.htm
Mar 14, 2010 | Reliance Controls L1430P 30 Amp Plug
Dryers Logo
67 people viewed this question
Top Dryers Experts
