Question about Coleman Mach 15 Air Conditioner
What are the 1st 3 blower settings for?
I have a Coleman TSR in my 1991 Itasca Class C. I do not have instructions. I have 5 blower settings. The last 2 are for the a/c fan, low & high.. What are the 1st 3 for? Are any for pulling in fresh outside air? I've noticed the 3rd one, pointing straight up, blows harder that the 1st 2.
    Problem Solver:
  • 3 Answers
Those are for the run time of the circulating fan after the heat has been satisfied.
Posted on Jan 27, 2009
Where are the fuses located for the 2015 Itasca Sunstar 36Y?
Winnebago RV Sales ' Itasca RV Sales ' Winnebago ...
www.lichtsinn.com/new-rvs-for-sale.aspx
Location: Main ... The All New Fuel Efficient Fuse with the Ford Transit Power Stroke Diesel! .... New 2016 Itasca Solei 36G The Forza and Solei Offer Diesel Pusher ... New 2016 Itasca Sunstar LX 27N All New Upgrades to the Vista and Sunstar with ... 2016 Brave Returns with Its New Crown as the 2015 RV of the Year Title!
Sunstar ' Specifications ' Winnebago RVs
winnebagoind.com/...a.../2015/sunstar/specificatio...
Winnebago IndustriesSunstar ... Length, 27'1", 31'3", 28'3", 31', 36'5", 35'5", 37'. Exterior Height1, 12'2", 12'2", 12'2", 12'2" ..... 2015 Winnebago Industries, Inc. All Rights Reserved.
Winnebago Industrieswinnebagoind.com/resources/manuals/Winnebago IndustriesIf you are not in a position to visit your dealer, some parts are available online at www.WinnebagoOutdoor.com. Please note that you can look up part information ...Winnebago RV Sales ' Itasca RV Sales ' Winnebago ...
Jan 01, 2016 | Itasca 2015 Sunstar 36Y
How tou remove a coleman tsr mac 3 roof top a/c?
If you Google airxcel.com, you should get some options. to get either their literature or tech support and they should be able to help you.
Aug 07, 2014 | Coleman Heating & Cooling
Coleman mach rv central air conditioner maintenance
maintaining rv a/c is just a matter of changing filters, cleaning coils and drain lines. visual inspection of wireing for heat damage.
Jun 18, 2014 | Coleman Heating & Cooling
HOW OLD IS MY UNIT? IT'S A TSR MACH 3 WITH BLUE LETTERING THANKS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Feb 20, 2010 | Coleman Mach III Air Conditioner
Tsr mach3 conditioner
The smell is because of the stuff growing inthe water from the air conditioner. When you run the a/c it keeps the water condensed on the coil. When you turn the a/c off and run just the fan, it allows the water to warm up and start evaporating thus allowing the goodies in the water to become airborn. It would be adviseable to have the unit disassembled and cleaned by a professional due to the obvious danger of mixing water and cleaning chemicals with electrical equipment
Jun 25, 2008 | Coleman Mach 15 Air Conditioner
COLEMAN TSR MACH 3 COMPRESSOR
I would check the thermostat based on what you said it could be out of calibration
Jun 11, 2008 | Coleman Mach 15 Air Conditioner
Coleman tsr mach 3 RV Air Conditioner
I don't think you need a new one just a good cleaning and service. The unit has a liquid high temperature line near the compressor with a fan blowing outside air across it this coil gets clogged over time with air-borne dirt and pollen and leaves and such and must be cleaned regularly or the unit will be unable to remove the heat from the coil and during the peak demand (3pm) the circuits that protect the compressor and the trailer wiring from being overloaded and burning or melting will trip. From what you have described it sounds like the RV is working as it should with a condenser coil that needs to be cleaned. GL and happy camping!
P.S. I've only serviced the occasional RV unit but in those cases I laid a piece of plywood on top of the Rv for work platform removed the retaining screws from the top cover and used a spray bottle with a good heavy foaming cleaner a shop-vac and a brush to get the job done.
Jun 11, 2008 | Heating & Cooling
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
May 20, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
183 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
