Question about Kenmore 24032\24036 Top Load Washer
Kenmore elite, water leak
Looked at hose connections to pump and did not see anything, but water leaks in the begining of wash cycle??
  • 198 Answers
Check the mix valve area where the water enters the machine, during the fill.
Posted on Jan 27, 2009
Kenmore elite washer leaked water all over floor
anything that uses water can leak . you have to look for where it came from and fix what ever you find .could be the pump or just a loose hose .
Sep 30, 2015 | Kenmore 24032\24036 Top Load Washer
Where potential water leaks for kenmore elite washeer
the drain pump might be leaking, it's quite common on washing machines, the bearings begin to go and leak.
the good news is that on most machines they're quite easy to replace - ensure it's throughly drained, tilt the machine onto its side, unbolt the pump, undo clips, slide off hoses, fit new pump, refit hoses and clips. Pumps usually cost under 40 or so, depending, so it's only worth doing if the machine still has a few years of life left.
Jul 22, 2014 | Kenmore Washing Machines
Water from vent
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Dec 30, 2012 | Kenmore Elite 45986 Front Load Washer
It leaks
where does it leak from,could be drain hose, or pump or connections to and from drain hose and from pump,, look for rusted clamps under neath,,,or holes, also chek waterhose connections,when loking underneath chek for water spots on hoses and pump..
Oct 10, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
KENMORE WASHING,wATER IS LEAKING FROM THE BOTTOM NOT THE HOSES
Possible circulation or drain pump leaking or associated hoses. See page 11 Oasis Tech Sheet
Jan 25, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
It's an Elite not sure the model number but I have a leak from underneath after the clothes are washed and when the water is discharged before the spin cycle.
this could be a broken hose or a leak from the water pump , if you have an access panel in the back u can check this , or access from underneath
Sep 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Washer Water Leak
Pump is not repairable and yes your pump is shot. You can replace it farely easily and cheap at repairclinic.com
May 22, 2009 | Washing Machines
Water leak from Kenmore elite
If the leaks happens during drain cycle, this is usually because of a leak on the drain pump hose, or because of a faulty drain pump that is leaking.
As the appliance must be taken apart and the pump may need replacement, it is better to call a repairman to do the job.
Check that leak is not from drain hose, from water supply hoses, or from gasket first.
Dec 29, 2008 | Kenmore Elite HE4 Electric Dryer
Water comes out the bottom of washer as fast as it goes in the top
hazy, it's possible it's running out your pump. You need to pull the cabinet off to get a real look at where the leak is coming from. Check out the pics...and post back.
Apr 23, 2007 | Kenmore Elite 20972
Kenmore 24032\24036 Top Load Washer Logo
56 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
