Question about Sony PlayStation 2 (PS2) Console
Ps2 controller sorry for askin too much questions but i do no have alchol or an electric cleaner. Could i use a deodrant spray can and apply some of it on the board? thankyou
  • 67 Answers
No don't used that,deodorant are sticky it will only worsen the problem try damp clean cloth instead.
Posted on Jan 26, 2009
What is the problem of high rpm of mercury sable
You see the vacuum hose solution by Shadow Gilbert? This still applies.......but usually if it's a vacuum leak,the engine will run a little rough.
Could be you need to remove the solenoid IAC in the aluminum duct that has the throttle control close by.
They actually make a special spray to clean this and the holes it works thru.
Also, you have what's called a MAF sensor,and these need the tiny wires inside gently brushed off and sprayed clean with electrical contact or what I use is brake cleaner spray.
Something that leaves NO residue.
don-ohio (:^)
Dec 31, 2012 | 2001 Mercury Sable
Tip
Electronics spray cleaner
The most common problem with guitar amplifiers
and other electronics that are making noise or cutting out
or sticking and not working correctly is a simple fix...
I use Radio Shack electronics spray contact cleaner
for most of my basic repairs
in the pictures posted I show the basics you need....
some screw drivers, basic knowledge, paper towels,
electronics spray contact cleaner, and a knife
First I carefully remove the nobs (volume control, tone control, etc...)
I use napkins to mask the area and keep from scratching the surface
Then I carefully spray into the (control} and work in back and forth....
the Best way is to spray directly into the potentiometer
that requires access to the internal chassis
on a quality pot there is a Notch that you want to spray into
on a standard pot just spray....
this will repair any scratchy noise or sound that cuts out
on guitar and bass amplifiers,
also can be applied to many other common basic sound problems
I hope this helps someone out?
i could Not upload photos? so please check My link....
https://plus.google.com/105897664234915107933/posts/iHG1R6dpvkU
on Mar 13, 2015 | Music
When i try to turn the sensitivity up or down its like the amp will push full power then cut back power. if i wiggle the control its works right then the same thang.
Hello... sorry to hear you are having problems. It sounds as if you have dirty pots inside the amplifiers attenuator. They make electronic cleaners that you can spray into the opening to remove the dust and debris that will accumilate inside electrical components. You can purchase this cleaner at Radio Shack. They may have it at WalMart as well. Check in the computer area. The spray is kinda expensive. After spraying the level control, take and rotate it back and forth and spray it again. Repeat a couple of times. If it still does it after this process, then you will need to take it in to be serviced. Hope this helped! Good luck with your venture!
20 year car audio/video installer
Bay manager
Mar 15, 2011 | Car Audio & Video
My Playstation 2 Plays PS1 games but not PS2 games...
Well your lcd is no that clean so just take a cotten ball get some rubbing alchol and dab it on the lcd then dry it if you have troubles on opening the system up go on youtube and type how to open up ps2
Oct 07, 2010 | Sony PlayStation 2 (PS2) Console
The cleaning station for my 8995 goes through the motions of cleaning but the bristles are no longer flushed into the fluid reservoir as they used to - they remain inside the shaver and also in the...
You can make sure you have a nearly empty old cart in your shaver cleaner base, and then run some rubbing alchol into shaver or even some mixed with some soap to help break down the oils in the stubble crud. If you can put some also in a spray bottle and use it to clean with a little force, that will help some.
Nov 19, 2009 | Braun 8585 Electric Shaver
My speakers have static when i turn them up and sound is unequal!
This is a symptom of a bad connection or dust in the volume control. Purchase a can of Electrical Cleaner. remove the volume control knob and spray the control. Remove the connections at the computer and spray both the male and female connections with the computer turned off. This should solve your problem. If it does not remove the connections and clean the ends with a pencil eraser and then spray this off with the electrical cleaner. Be sure and only use electrical cleaner and do not use a product such as WD40. After cleaning connections at the computer wait about 15 minutes before turning the PC back on. The cleaner will evaporate by then. If this does not help try another set of speakers.
Nov 06, 2009 | Dell Dimension 4700 PC Desktop
Need to clean my ps2
To Clean you PS2 Here are the steps
1. Unscrew you PS2 bye the top
2. Get a duster air can to spray off the dust. (make sure you don't spray to much they might have gas in them.)
3. Take a two sided Q tip or one sided doesn't matter and dip the cotton sides into rubbing alcohol and careful clean of the lens do not scratch it or you ruin your PS2.
4. Take all peices that you might have moved and put the exactly in place.
5. Put cover on.
6. Screw the screws back in (P.S. do not use a electric powered screw driver use a hand held one.)
7. Turn on and test it if it has problems like heating up dust out the fan on the back.
8. Enjoy. <(^ . ^)>
And, if you have a small PS2 even thought they are junk just dust out the fan open the part that you put the disc in and dust arond the lens and inside and then just clean the lens with the Q tip and alcohol.
YOUR WELCOME
Apr 26, 2009 | Video Game Consoles & Games
L1 not working on PS2 controllers
Try Using A Keyboard Cleaner To Spray It Out As It Will Leave No Residue Also Try Spraying Or Blowing In The Play stations End.
Jan 06, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 wont read the disk. says there is no data. help
it's your laser with something like dust keeping it from reading the discs. Just get a simple CD cleaner kit, one that has the little brush on it and then of course put some solution on it. Rubbing alchol will due. This happens to everyone eventually.
Should do the trick.
If it doesn't do it after playing the cleaning disk three times for around 10 secs each, then you may want to open it up and put clean the laser lens directly with a rubbing alchol soaked que tip and a dry one. For more instructions on how to open it do a search on fixya and there is one guru who goes into great detail about this.
Dec 27, 2008 | EA - Electronic Arts Rock Band
Sony PlayStation 2 (PS2) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
