My router keeps flashing amber light and cannot connect to it after i resseted it
Power lost for 2 mins and after it would'nt work anymore.
  • 826 Answers
Set router POWER OFF:
->Reset Broadband Modem: press RESET button momentarily.
and wait 60 secs.
Set router POWER ON.
->Reset router: With a straightened paperclip, press RESET button momentarily and Wait 60 secs.
Open PC Command Line:
Click [Start] - Click [Run...] - enter: cmd, press [ENTER]
At the prompt (c:\.....>) enter: ipconfig /all, press [ENTER]
- Ensure DHCP Enabled == YES
At the prompt (c:\.....>) enter: ipconfig /release, press [ENTER]
At the prompt (c:\.....>) enter: ipconfig /renew, press [ENTER]
TEST: Open Web Browser: Connect to Internet.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Posted on Jan 21, 2013
bc_axys
  • 49 Answers
SOURCE: My WAN light keeps flashing while the M1 amber light remain fix at ON(M2 amber light = OFF)
You must have done something wrong when upgrading the firmware. because there are pre-requisite settings on the computer before performing an upgrade. Like setting static ip and forcing  card to 10mb/half only prior to upgrading. If this flashing is unusual, then you mightn have damage the wan port.
just to let you know, wan port will really flash but not that continous.
Posted on Oct 13, 2007
SOURCE: no internet connection
I received this solution from Belkin. It worked for me & I hope it does for you. Good luck!
Belkin solution:
Please follow the details given below:
1. Please contact your internet service provider to know the connection type details (Is it PPPOA,PPPOE, Dynamic or static)
2. Belkin router F5D8633 ADSL router works only with ADSL broadband connection and does not support Cable broadband connection.
3. Do not use the Setup CD Assistant; reset the unit and configure it manually. Make sure to set the correct VPI/VCI values in the process as the default settings may not be correct.
4. When using PPPoA, always use VcMux encapsulation, when using PPPoE, always use LLC encapsulation. Keep the VPI and VCI as 0/38.
5. Please follow the instructions given below to configure the router manually:
- Connect the phone line direct to the router, or through the filter.
- Connect the computer to one of the LAN ports on the router.
- Switch off the router and power it back after 5 seconds.
- Restore the router to factory defaults by holding down the reset button on the back of the router.
- The power light will flash and then come back ON solid, indicating that the router is being restored to factory defaults.
- The corresponding lights on the router should be lit-up.
- Check if the computer has an IP address in the range of 192.168.2.x
- Click on `start` & click `Run`.
- Type in `cmd` & click `ok`.
- Type `ipconfig` and Enter. Check for IP address, subnet mask & Default Gateway.
- If not, specify a static IP address, gateway and DNS by following the steps at http://web.belkin.com/support/kb/kb.asp?a=2824
Then follow the below instructions to reset IE.
-Open Internet Explorer
-Click on Tools -> Internet Options
-In the General tab, click on Delete Files under Temporary Internet Files
-Click on Clear History
-In the Connections tab, select Never Dial A Connection and click on LAN settings
-Uncheck all the options and click on OK
-In the Advanced tab, click on Restore Defaults
-Click on Apply and then OK.
- Open a new Internet Explorer window and on the address bar please type in http://192.168.2.1 and click on go.
- You should be able to access the routers set up page.
- By default the password is blank.
- Click on Connection Type and Reconfigure the connection on the router (using your ISP details).
- Save the Changes.
Note: Please obtain the correct values regarding the Internet connection from your Internet Service Provider.
Internet Status should show Connected on the top right hand corner of the web page.
If the problem persists, please get back to us with the following information given below:
1. Type of connection provided by the ISP (Is it PPPOA,PPPOE, Dynamic or static)
2. The ADSL light status on the router. Please let us know if the ADSL light status on the router is solid or flashing.
3. ADSL broadband connection or Cable broadband connection.
4. Operating system on the computer and the version number for the internet explorer like IE 6 or IE 7.
5. Internet Status shows as Connected or Disconnected on the top right hand corner of the router web page.
Log on to the router web interface at http://192.168.2.1
- By default, the password is blank.
- Click on Security log under "Firewall" option (let us know the message you see under the security log or send us the screen short of the message you see under the security log)
6. Then, check the IP address of the computer. For checking the IP address:
- Click on start & click `Run`.
- Type in cmd & click `ok`.
- Type IPCONFIG and Enter. Check for IP address, subnet mask & Default gateway.
- The IP address should be in the range of 192.168.2.x (x=2 to 254)
- In the command prompt type PING 192.168.2.1 & Enter. Check if you are getting replies.
- Type, PING 4.2.2.2 & press Enter. Check if you are getting replies.
- Try pinging yahoo by typing PING yahoo.com and Enter. Check if you are getting replies.
Posted on Jan 21, 2009
SOURCE: the internet port light keeps flashing amber
Frustrating that the answer is not readily apparent from Netgear but it's really pretty easy. An Amber light on the Internet Port means the same as an Amber Light on a Lan Port. That is, the router senses the connection is less than the maximum speed. No, Netgear does not document this in their manual but will 'fess up to it if you talk to a real Tech Support person. There is no difference in the lights in the Internet Port and Lan Ports. They are both "Ports". From Netgear:
Green - The LAN (local area network) port has detected link with a 100 Mbps
device.
Green Blinking - Data is being transmitted or received at 100 Mbps.
Amber - The Local port has detected link with a 10 Mbps device.
Amber Blinking - Data is being transmitted or received at 10 Mbps.
No light - No link is detected on this port.
But your Internet still works you say. Yes, that is because your connection to your ISP is just about always less than the minimum speed, so you don't notice any difference other than an annoying change in color on the router. This usually can be resolved by resetting the modem. That will cause the ISP to reconnect to you with a different modem at their end. They have a piece of equipment that is less than optimal but if they are like most ISPs, they will not have a clue (or an interest in getting it fixed). If you call your ISP, they will probably set you on a whole course of checking your computer network drivers, updating router firmware, resetting and rebooting your computer, etc. All steps listed in the Official HelpDesk Guide to Getting the Customer Off the Phone Manual as one of those usually will eventually will be a reset of the offending piece of equipment.
Posted on Nov 27, 2009
  • 153 Answers
SOURCE: The ''wireless'' light on my wireless router is flashing amber
What have you tried so far?
1. You can unplug the power cord of your modem on the back of the modem.
2. Unplug the power cord on the back of your router
3. Unplug the ethernet cable at the back of your modem
4. Unplug all the ethernet cable at the back of your router
5. Wait for 2 minutes then plug the power cord back into your modem and the ethernet cable
6. Wait for 2 minutes again then plug the power cord back into your router and the ethernet cable
7. Try to reconnect
(Note: Resetting your router will restore to factory default)
8. If not successful, try resetting the router. While the power cord is plugged at the back of your router press the reset button for 15 seconds, unplug the power cord of your router and press the reset button again for 15 seconds then plug the power cord back into your router and press the reset button for 15 seconds. (after resetting reconfigure your router) Try to connect.
9. If not successful, try to upgrade the firmware
Posted on Jan 09, 2010
bahratt
  • 561 Answers
SOURCE: My belkin N router flashes amber on my modem...all the time.
You may need to upgrade the firmware of the device. Please see setp by step instructions here: http://en-us-support.belkin.com/app/answers/detail/a_id/497/q/routers
Download your latest firmware from: http://en-us-support.belkin.com/app/answers/detail/a_id/306/kw/F5D8236-4/r_id/166
Posted on Jan 12, 2010
Amber light flashing on belkin 150 router
Disconnect the ISP modem power and network / cable. Do the same with the router. Wait a few minutes and reconnect starting with modem.
Oct 08, 2012 | Belkin Connect N150 Wireless Router...
The internet connection in my area went down yesterday, but i didn't know this and thought the reason i couldn't access internet was a problem with my linksys wrt54g router. So i unplugged and...
The first thing you should do is a proper 'powercycle' for all of your internet equipment.
To do this:
1) Unplug the power to your modem and your router, and power off your computer.
2) Wait a full minute.
3) Plug the power back in to JUST the modem.
4) Wait some more - for the modem to fully connect to your ISP, and the lights to indicate. If you're not sure, just wait about 2-3 minutes.
5) Plug the power back into the router.
6) Wait another minute or two for the router to finish connecting.
7) Then turn the computer back on.
You can bypass the computer turning on and off if you can repair your wireless connection.
If this doesn't work, there is a pinhole sized reset button on the router itself that you will need a toothpick or somesuch to press - press and hold the button for 5 seconds, and then try the steps above again. If you do this, the network id and password will be reset to the default, just like it was when you bought it.
Jul 20, 2011 | Linksys Wireless-G WRT54G Router
The wlan doesn't work-it used to until last week! The flashing amber light on the front is completely gone and does not flash anymore! and it says that NO wireless networks detected - although my friend's...
1. check with you ISP. You may have an issue with the server.
2. check the connection in the router (router status) using 192.168.0.1 then enter "admin" and a password if used.
3.
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Aug 10, 2010 | Acer Aspire 3000 Notebook
Contact Belkin for Care at 1-800-585-2494 Toll Free,,
Jan 09, 2010 | Belkin F5D8236-4 Router
Blinking amber light.I changed 2 motherboards out and still blinking amber. Changed the CMOS battery, same thing blinking amber. Swapped memory and removed all pci cards, same thing. The motherboard has a...
I'm not clear about the blinking amber light you are referring to. Is it on the computer or the monitor.
I checked Dell's web site for the service manual for this computer model, & found this document:
http://support.dell.com/support/edocs/systems/dim8300/sm/adtshoot.htm#1102195
If the blinking amber light is on the monitor, check the connection between it & the computer itself. Make sure the cable is not damaged & that it does not have any broken pins in the socket.
Dec 16, 2009 | Dell Dimension 8300 PC Desktop
Oct 06, 2007 | D-Link DI-704P Router
Computers & Internet Logo
David Payne
David Payne
