Question about Kitchen Ranges
Ge Profile gas range model #J2S968SEK1SS started making a loud noise and then started making lots of big sparks and smoke. Now it will not turn on at all. Any idea what we need to replace?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
Where did all the fireworks come from? Did it come from the console, display area?
Posted on Jan 21, 2013
reg501
  • 413 Answers
SOURCE: I have a ge profile gas range and the burners are making a constant clicking noise and spark. The only way to stop it is by either unplugging it or turning the power off to it
Under each gas control is a switch that will turn on the spark module when rotated to the light position. One or more of these switches has failed. Some models these switches are individually replaceable, others the switch is an assembly of all four.
Posted on Jun 15, 2008
docjohn174
  • 943 Answers
SOURCE: GE Profile Gas Range Igniters working but gas takes a while to start flowing
HI thanks for your question. the igniter is the cause for this problem. the heat from the glow bar is just not hot enough to ignite the gas. i would replace the igniter. thanks
Posted on Oct 14, 2008
MNTECH
  • 1543 Answers
SOURCE: GE gas range igniter continues to spark, won't shut off.
Often times, just leaving the range unplugged for a time will solve the problem, which is most often caused by water or a cleaning agent getting into an igniter switch behind a burner knob. After the switch drys out it usually starts working again. In the mean time, you can still use the burners by lighting them manually with one of those long lighters, but you will not be able to use the oven or broiler without electricity. If the range continues to spark after being left unplugged for more than a day or two, you will have to determine which switch behind the burner knobs is causing the problem. Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Posted on Feb 18, 2009
MNTECH
  • 1543 Answers
SOURCE: replacing existing gas range
A " gas range installation kit " should not be required if you are replacing an existing unit. Some retailers "require" you to purchase things like this, or a new range cord for a new electric range, etc., but it is just their way of getting you to buy more. When purchasing a washer, some retailers will not even disconnect or reconnect you water supply lines. I'd sugest trying a smaller, independent retailer who actually has their own service staff in case you ever have any problems. The big boxes don't do service. (they tell you to call some 800 number) In the US, try www.geappliances.com/buy/ for a GE dealer. Tell them who you had planned on buying from, and the price they quoted. The independents usually can get your product faster and at about the same price. (make sure the independent you go with does their own service)
Posted on Jun 30, 2009
  • 1015 Answers
SOURCE: My GE Profile Gas Range Keeps clicking
You are getting water into the range when cleaning causing the igniter switch to short out. The reason why it goes away after a few hours is because the water finally dries up. When cleaning the range refrain from using so much water. You will need to leave the range unplugged until the water dries up again.
Posted on Sep 17, 2009
Gas stove ignator makes
sounds like you got the electronic ignitor valves wet try blowing them out with air or don't use for a few hours
May 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
May 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven makes a poof noise when turning it on.
HI thanks for your question. the poof you hear is the gas sorta igniting because of a failing bake igniter. i would replace it thanks if you need help don't hesitate. thanks.
Aug 08, 2008 | GE Profile JGSP48 Gas Kitchen Range
Jun 15, 2008 | Whirlpool SF368WWH Gas Kitchen Range
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
