Question about Dell Latitude C510 Notebook
I cannot get my dell 2405FPW monitor to connect ot my dell 1501 inspiron LT
I have connected the 2405 monitor to the LT using the VGA ( blue) cable supplied. I cannot get a screen image.e FN & F8 keys will not change the image from LT to the 2405. I cannot get anything to show on the monitor but 3 s-video , 4 - componenet and 5 - component. What do I do , I need this monitor for a sound studio display.
  • 77 Answers
Try to update the video driver
Posted on Feb 01, 2013
5 Suggested Answers
Fwayne
  • 97 Answers
SOURCE: Connecting Dell Inspiron 1501 to TV, Windows Vista
The PC card you have doesnt appear to work with that adaptor. Dell Has its own Svideo / Video output adaptors.
You need a converter not an adaptor. Try looking on Amazon for this: ITV-900 PC to TV Converter
Posted on Dec 23, 2008
RSBennett
  • 54 Answers
SOURCE: fn key on dell inspiron 1501 keyboard not working
Sounds like your number lock is on. Find the key with blue lettering that says 'Num Lk' (or something very similar). Press Fn and that key, and your number lock will be turned off and your keys will go back to normal.
Hope this helps.
Posted on Mar 10, 2009
Geekman
  • 32281 Answers
SOURCE: Dell Inspiron 1501 laptop screen will not work.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 21, 2009
laptopsbatte
  • 77 Answers
SOURCE: I connect my B130 to an external display using a
Just click the laptop battery screen power button to close it or Fn+F7.
Posted on Dec 16, 2009
Vertical black bars screen
Try connecting an external monitor to the 15 VGA (video) plug on the laptop and see if it displays properly on the monitor. You may have to direct the video from the laptop to the monitor by holding down the blue <FN> (key next to the space bar) and then press down the <F8> key.
If the display on the external monitor is correct, then you either have a problem with the laptop's LED display screen or cable that connects the LED to system board. Here is a link for the service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-9300_service%20manual_en-us.pdf
Feb 16, 2013 | Dell Inspiron 9100 Notebook
I want to connect a Dell Inspiron E1405 to a TV with a VGA cable
As long as your TV supports VGA then you should be fine. Just a reminder that your computer has an easy function key that you can use to switch to the VGA connection.
Key: <Fn><F8> (Ref page 33)
Ref: http://support.dell.com/support/edocs/systems/ins6400/en/om/MD402AO3.pdf
Dec 22, 2012 | Dell Inspiron E1505 Notebook
Unclear lettering & numerics
1: Resolving Laptop LCD Lines,
Fuzzy, Color, or Blurry Issues
Verify that the BIOS and Video drivers are the latest available from Support.Dell.Com Website, for more information refer to Dell Knowledge Base article, "How to Use the Drivers and Downloads Website"
Test the LCD in the System Setup (BIOS).
To enter the computer BIOS Setup Screen perform the following steps:
At the first text on the screen or when the Dell logo appears, tap <F2> until the message Entering Setup appears.
Note:
Some older Dell computers use an alternate key sequence instead of to enter System Setup. These key sequences include:
<Ctrl>+<Alt>+<Enter>
<Delete>
<Fn>+<F1> (laptop computers only)
<Fn>+<Esc> (laptop computers only)
If you observe the same issue on the setup screen, it is not an issue with the Operating System, it is a hardware issue, Contact Technical Support/font>.
Run the Laptop Built-In Self-Test (BIST).
To run the Built-In Self-Test perform the following:
Turn the computer off.
Press and hold the D key while pressing the power button. This will start the BIST.
The screen will display multiple flashing colors. Look for lines, distortion, or any other video issues you have observed.
The laptop will restart when the test is finished.
Click the following link to see an English-only video of this test How to Run LCD BIST Video .
If the LCD BIST passes, proceed to Step 4, otherwise Contact Technical Support.
For information on Beep Codes/Error Codes refer to Dell Knowledge Base article, Pre-Boot System Assessment (PSA) Diagnostics and Error Codes For Dell Computers
Connect to an external monitor (if available), for the different types of external monitor ports that may be available on your computer refer to (Figure 1).
Display Port
Display Port is a new digital standard for connecting monitors to computers and has the capability to provide a scalable digital display interface with optional audio and high-definition content protection (HDCP) capability. Display Ports usually resemble USB Ports with one side angled.
A Display Port cable should be used if Display Port connectors are available on both the computer and the monitor.
DVI
Digital Video Interface (DVI) is the digital standard for connecting monitors to computers. DVI connections are usually color-coded with white plastic and labels.
DVI cables provide a higher quality signal than VGA cables. A DVI cable should be used if DVI connectors are available on both the computer and the monitor.
VGA
Video Graphics Array (VGA) is the analog standard for connecting monitors to computers. VGA connections are commonly color-coded with blue plastic and labels.
A VGA cable should be used if DVI connectors are not available on either the monitor or the computer.
Once it's connected, press and hold down the FN and press F8, this should display the screen on the external monitor.
When the external monitor does not work or you did not have one to test with, Contact Technical Support.
When the external monitor does work it may be an issue with the Operating System. Verify that all the drivers are the latest available from Support.Dell.Com Website, for more information refer to Dell Knowledge Base article, "How to Use the Drivers and Downloads Website". When that does not fix the issue the Operating System may need to be reinstalled, for more information refer to Dell Knowledge Base article, "How To Restore or Reinstall Microsoft Windows on a Dell Computer".
Check for visible damage to the LCD. To identify any damage not visible to the ***** eye, ensure you run LCD BIST on the system (refer to Step 3).
If the LCD has damages which is not covered by any applicable statutory warranty, limited hardware warranty and/or Dell-branded service, including Complete Care / Accidental Damage service, there may be a cost incurred by you for the replacement of parts.
Oct 04, 2012 | Dell Computers & Internet
How to connect my dell inspiron 1501 laptop to my hdtv. am using a vga cable with rca out, to connect to the tv. i have tried everything but none works. if this can work please sent me step by step...
1 - the cable you are trying to use will not work - the RCA inputs in your tv can't accept the signal coming from the VGA. To connect the laptop to a tv the tv must have an VGA input, nothing else will work.
2 - When you start the laptop with an external device (such as an external monitor or tv) attached and turned on, the image may appear on either the laptop's display or the external device.
Press to switch the video image between the display only, the external device only, or the display and the external device simultaneously.
Apr 27, 2011 | Dell Inspiron 1501 Notebook
Connect Dell Mini with HDMI to VGA PC flat monitor
hi,
you would need an HDMI to VGA adapter. sometimes it would come in a form of a separate cable or just a regular adapter which would convert the HDMI end to VGA (the blue one that has 15 pins)
you can purchase these cables from your local computer store.
hope this helps
Jul 12, 2010 | Dell Inspiron Mini 10 Notebook
I am trying to connect my laptop to the TV and would appreciated if someone could share information about connection details My dell inspiron 501 laptop has only the VGA port. The lowest resolution that...
Your dell should pick the TV up as a monitor if you have the VGA cable connected. The vga cable has a blue color on the TV but on the laptop, the color of the port is usally brown or dark in color. Windows should pick up on the new device and enable it. The Dell has an Fn key combination to allow you to toggle through the integrated / external monitor choices that you would have with two monitors active, that being clone both desktops to both monitors, extend the desktop from the laptop to the TV, use only the tv and turn the integrated off, use just the integrated and leave the TV off. The key combination is: Fn + F8
Jan 12, 2010 | Dell Inspiron 1501 Notebook
How to hook up dell inspiron 1501 laptop to tv with vga
Do the following:
1. Get a VGA cable (male-male) and connect to your TV and your laptop
2. Select your TV's source as PC (check ur TV manual)
3. From your laptop, select video output to external monitor by clicking on the Fn key and the F8 key at the same time
NOTE: Please rate our help to keep this free service online
Jan 12, 2010 | Dell Inspiron 1501 PC Notebook
Use hdmi out on 2408 display
No, won't work as teh monitor does not have sound capabilities. However, this will work if you have some sound input into the monitor, like if you use the HDMI (which includes sound) to send signals to the monitor, instead of the VGA / DVI connector. (All sound output on a system is from the sound card on the system only, monitor sound options are usually just an extension of the same)
Jan 07, 2009 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dec 23, 2008 | Dell Inspiron 1501 Notebook
Dell Latitude C510 Notebook Logo
Alun Cox
