Question about Dryers
Whirlpool LP dryer will not light. model LGR7646EQ2.
Ignitor does not glow. Is this the problem or is something else causing the ignitor not to glow?
  • michelle_sei Jan 26, 2009
    Igniter is not broken. Could the igniter still be the problem
    Sniper:
  • 50 Answers
The ceramic ignitor probably is broke. turnoff power and gas, then remove burner assembly ther are two screws holding it in. also loosen gas connecter .pull burner out an visibly check igniter you most likely will see the ceramic coil broken remove it and bring it and model # to a part house then reassemble burner
Posted on Jan 26, 2009
My whirpool gas dryer model number wdg6200swq, wont heat up. the ignitor lights but no gas lights
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 02, 2011 | Whirlpool Dryers
Gas whirlpool dryer model LGR6611LQ0 will not heat up . Ignitor turns on but will not light
heatman101
Dec 19, 2010 | Whirlpool LGR5636L Gas Dryer
Drum turns but does not heat the air. I replaced the ignitor, but no help there. Whirlpool gas dryer model 63003W0
If the ignitor glows but does not light the burner you need to replace the gas valve coils.
If there is no glow you must check all the thermostat safeties and thermal cutout fuses for continuity with a ohm meter. No continuity is a bad component. Remove at least one wire from each component before testing.
Unplug the dryer before any test.
Feb 17, 2010 | Whirlpool Dryers
Not heating up Gas Dryer
Modern gas dryers do not have a pilot light. They have an electronic ignitor (glow or spark). A glow ignitor turns on several seconds before the gas turns on and should get orange hot. A spark ignitor should make a clicking or buzzing noise.
Most likely the ignitor is bad but you can check it fairly easily to make certain. The best instructions I have found are at
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
If it is the ignitor it can be replaced with a few hand tools. Remove the bad ignitor. Write down the make, model, and serial # of your dryer. Call your local appliance parts store to see if they have one it stock before driving over there.
Dec 22, 2009 | Whirlpool Dryers
Have a Whirlpool Gas Dryer - model # lgr7646a spins but no heat
Thre is no pilot light. This dryer uses an ignitor (glow bar or coil).
Open the lower front "door" (small access door) and turn on dryer.
If the ignitor does not glow (bright orange), then the ignitor needs to be replaced ($60).
If it does glow, then the gas valve needs replacement ($60).
If it isd the valve, the internal spring is stuck. Do not try to repair it, you must replace it.
Sep 25, 2009 | Whirlpool Dryers
No heat from whirlpool dryer model lg6881xtw1 , replaced burner ignitor, still does not light up , what should i check next
Check the thermal fuse on the blower housing. That is assuming the glow bar does not light up. If the ignitor is glowing and it will not light it is likely one or both coils on the valve are bad. (replace as a set) Eric
Sep 14, 2009 | Whirlpool Dryers
No heat
Should be a cover about the size of a quarter on the front lleft bottom...pop off with a small screwdriver and start dryer....look inside and see if the glow bar lights up...if glow bright orange, probably good, may need gas solenoids or ignitor
Jun 10, 2009 | Whirlpool LGB6300 Gas Dryer
There is no heat being produced
HI, Remove the front lower panel. Start the dryer and see if the ignitor glows. If it glows but the gas valve does not open, Change the coils on top of the gas valve.
If the ignitor does not glow, test the ignitor for 120V. If there is voltage to the ignitor but no glow, change the ignitor.
If there is no viltage to the ignitor, check continuity on the thermostats and the fuse that are located on the blower housing. Also test the sensor located on the burner.
I hope this helps. Please let me know if I can assist you further.
Vic
May 24, 2009 | Dryers
Whirlpool gas dryer model number ler7646eq2 does not produce heat
Need more info. Does it rotate? If it has a viewing door on the front, you may see if the ignitor is glowing. If the ignitor glows, the ignitor (flame) sensor may be bad, and the ignitor will shut down.
Aug 09, 2008 | Whirlpool Dryers
Kenmore elite gas dryer
Does the ignition glow when you start the dryer? if so you have power to gas valve and ignition system. if not you may have an open thermostat or thermalfuse.
If the ignitor just sits there and glows all day, you have other problems, It could be a gas valve, or ignitor sensor.
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
231 people viewed this question
Top Dryers Experts
