Question about Dishwashers
WHIRLPOOL PORTABLE DISHWASHER WON'T CONNECT SNUGLY TO MY SINK
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
GET A BETTER SINK THEN
Posted on Jan 21, 2013
ranger25
  • 72 Answers
SOURCE: Portable Dishwasher
You have to have a good seal. Get a hose washer from your local hardware store and replace both of them on the hose if they are like a garden hose. If you still don't get any water to the unit, post again and I'll step you through it.
Posted on Jan 28, 2008
Mrjtwright
  • 10 Answers
SOURCE: how do i connect a kenmore ultra wash II portable
You can get an adapter from a local hardware store. I'd come equipped with make and model number and the screw on screen retainer piece from your faucet.
Posted on Aug 21, 2009
Testimonial: "thank you for making this simple enough for a true blonde to do on her own"
  • 84 Answers
SOURCE: Convert a whirlpool portable dishwasher to undercounter
I would simply slide the unit under the counter and connect the inlet and drian hose permenantly.If the unit is not tall enough and sits too low then build a shelf or false floor in the cupboard for it to stand on.
Posted on Dec 30, 2009
SOURCE: I need a new faucet adapter for a Kenmore Ultra
the adapter i got with my new kenmore dishwasher does not fit with my kolher fauset. The sears serviceman said i need a longer adapter. I can't find one anywhere.
Posted on Jul 19, 2010
oldTech2332
  • 2341 Answers
SOURCE: Clean light flashes 7 times
The light flashing 7 times indicates error code number 7 and E7 is a error code for the flowmeter. What the flowmeter does is measure the amount of water coming into the dishwasher. The E7 error code can be cleared aby pushing the buttons in this order
HIGH TEMP WASH-HEATED DRY-HIGH TEMP WASH-HEATED DRY -- OFF/CANCEL
The error code will be cleared after pushing the buttons in that order...if after running the E7 error code returns the flowmeter would need to be replaced
The flowmeter is the part on the left side of the tub it is where the water enters the tub
The part number for it is W10195536
GENE
Posted on Sep 06, 2011
GE portable dishwasher connector hose slips off faucet adapter
Google your dishwasher you will see parts on line There are loads just looked .
Apr 13, 2017 | Dishwashers
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
Whirlpool dishwasher does not drain. Wash arm operates correctly
Check the drain hose under your sink make sure its not crushed or kinked if you have a garbage disposal the hose should go up into it at a 90 degree angle if not 180 degrees into your sink drain line
Jul 25, 2012 | Whirlpool Dishwashers
Whirlpool quiet partner 1 won't drain all the way suddenly
Hello.
HERE ARE TOOLS NEEDED AND INSTRUCTIONS ON HOW TO SOLVE THE DRAINING PROBLEM BELOW.
(A) Clean cloth(s)
(B) Wrench (if necessary)
Whirlpool brand dishwashers come in black, brown, stainless steel or white finishes and a variety of sizes as well. Most Whirlpool dishwashers are energy efficient, and many have features such as a sanitizing rinse, enhanced sound effects, large capacity tubs and adjustable shelves and racks. However, none of these features will help users much if the dishwasher is not draining. While this issue may require professional repair, some troubleshooting steps may help determine if there is a relatively simple cause for the problem.
1 Verify that the Whirlpool dishwasher has not lost power due to a power failure or motor overload. Wait a few minutes to see if the motor automatically resets and resumes operation. Reset the circuit breaker or fuse if necessary.
2 Press or select "Start" to resume the cycle if the dishwasher was stopped mid-cycle. Choose a new drain cycle if necessary to remove excess water from the unit.
3 Turn off the dishwasher and unplug it from power. Examine the connection between the dishwasher and the garbage disposer, usually located underneath the kitchen sink. Make sure the disposer knockout plug was taken out between the two.
4 Run the garbage disposer in the kitchen sink to remove potential blockages.
5 Remove objects that may be blocking the drain on the dishwasher. Clean out the drain hose at the rear of the dishwasher.
Thanks.
Nov 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
My model DU810swkqo dishwasher will not drain completely [leaves about a couple of qts of water in the bottom after cycle.It has started dripping water out the bottom of the door.Can or does it need drain...
Hello
If the water won't drain from the dishwasher, first manually remove as much water as possible and then check the sump area for paper or any other large object. Make sure the door is properly latched. The pump will not drain if the door is not latched properly. Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
A cup or so of water in the sump area of your dishwasher is normal. It is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it's possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn't turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Aug 06, 2011 | Dishwashers
My Whirlpool dishwasher won't drain and won't start, it makes a slight buzzing sound then clicks off...
While this could be a number of problems, I'll start by asking how old is the unit?
Jul 09, 2011 | Whirlpool Dishwashers
Dec 30, 2009 | Whirlpool DP940PWKQ Free-standing...
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
Owen Barnes
