Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
My washer doesnt spin or drain. any solutions/
    Sergeant:
  • 291 Answers
The machine must drain to spin. So assume it is a drain problem for now. There could be a sock in the hose between the tub and drain pump. Or even jambed against the pump. You'll have to get inside to see. It's also possible the belt has slipped from the pump. But i believe yours is a direct drive set up, so there are no belts.
Posted on Jan 21, 2013
Doesnt spin
Hi sadiedawq,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | LG WM-2277HW Front Load Washer
My frigidaire affinity washer doesnt spin during the rinse cycle.
Hi javierc569,
Kind Regards
JEDEMEYER1
Jul 26, 2011 | Frigidaire Affinity ATF7000E Front Load...
Doesnt spin y
Hi ajin 24,
The reason might be that the Drain pump can no longer pump out the water, and as such the Spin cycle can not begin.
Please look at my tip below for th fix:
ACCESS, DRAIN & CLEAN THE DRAIN FILTER...
If the Tip does not work for you, you might need to replace the Drain pump (Faulty)
Kind Regards
JEDEMEYER1
Jul 26, 2011 | Equator EZ 3600 CEE Front Load Washer /...
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Washes but doesnt drain or spin
Unplug Washer
Shut of Water hoses to Washer and Disconnect from Washer.
Turn washer around and remove back cover.
Look inside fro the Belt it should either be Loose, or Broken. Just Replace.
Hope that helped
Please Rate Me
George
Apr 29, 2009 | Washing Machines
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
389 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
