Question about Sentry Fireproof Safe
Sentry S3807 safe-cannot open
Battery is dead on a Sentry S3807 safe.  How can we open safe?
    Scholar:
  • Sentry Expert
  • 170 Answers
Locksmiths agree on how to install sentury safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe?
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Posted on Aug 09, 2010
How do I open my Sentry Safe when the batteries have gone dead?
Some safes come with a key to open it with when this happens.key hole is cancelled under or near the keypad...not sure if yours is one of them.or there maybe a slot to plug in a battery pack .good luck..hope I have helped.
Oct 03, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sep 23, 2012 | Sentry Fireproof Safe
Cannot open my safe, battery appears dead
Seems that you might need to get help from the security people as the battery needs to be replaced..there could be a method for the Sentry safe.
Sep 28, 2010 | Sentry Fireproof Safe
Wats the factory code for a sentry s3807
First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe ( on paper tag near hinge) or under handle. just note your model # and the serial#. A good locksmith should be able to help you with It
May 19, 2010 | Sentry Fireproof Safe
My Sentry S3807 just will not open. I have the combination right and the key, but it won't open. The batteries could be shot, I suppose, but how do I get in?
How to install sentry safe batteries
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 26, 2009 | Sentry Fireproof Safe
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
How to cahnge the battery on a sentry safe
There is a small opening on the front number panel of safe. Use a small hex screwdriver or pin to insert into opening. It will open up the front panel (slide panel to right to take off) showing you 4 AA batteries. Just replace and close panel. Very simple to do. I wish the manual show me how. Instead of trying to figure it out for hours.
Dec 25, 2007 | Optics
Sentry Fireproof Safe Logo
2,446 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
