Question about HP Compaq Presario F730US Notebook
Blank (dark) screen
When I turn on my Compaq Presario F700 laptop, the screen is black and stays that way. At certain angles, there is limited ability to see things on the screen. I've tried the "fn" f8 button, which has no effect on this problem. Is there anything else I can do? its comes on but blank black screen and its only a year old warranty just ran out
  • HP Master
  • 4,806 Answers
If you can still see a faint image on the screen, then its the inverter coil or the inverter itself which has gone bad or maybe even worked itself loose causing a bad connection.
Either way you will have to take it to PC repair shop to be looked at.
Good luck and thanks for using Fixya!
Posted on Jan 26, 2009
  • 41 Answers
Sometimes there is a switch up above the keyboard that can get stuck down. The switch controls the backlight on the LCD, so if it gets stuck down you'll have this dimming problem.
If the switch isn't stuck, or if it isn't visible you might have a bad LCD inverter. It's a very common problem. The inverters are $10-$20(USD) on eBay. They are moderately difficult to install, but not impossible.
Please let me know if you have any other questions. I'll monitor this thread.
Jason
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
HP Compaq Presario turns on monitor stays blank
Yes it could especially when it does not work on another monitor.
Try another video card.
Sep 22, 2012 | HP Compaq Presario PC Desktop
My LCD screen has been flickering.
Sound like the display panel needs to be replaced
Aug 16, 2012 | Compaq Presario CQ62-215DX Laptop
My hp f500 powers on but stays at a black screen and i dont know what the problem is need help
I have the same problem with the f700. tried replacing the inverter and even the screen but its something else... HELP?
Nov 20, 2010 | HP Compaq Presario F500 F700 and G6000...
Compaq Presario CQ50-110US...blank screen, no display
Can you see what's on the screen if you hold it under a light? Did the screen die suddenly or were there more symptoms?
May 05, 2010 | HP Compaq Presario CQ50-110US Laptop
Blank Screen on Start Up. (Compaq Presario 700)
Unplug all external devices and then check. Go to BIOS and restore it to factory defaults
Mar 03, 2009 | Compaq Presario 700 470024-192 Notebook
Blank (dark) screen
Yes,
But, this requires you to access the screen adjustment buttons on the front side panel bezel or on the side of your screen's panel bezel.
I'll be, owning a few flat panels, the first to tell you that dealing with these buttons is tortuous. The are labeled but poorly, Usually the top or first button is the Menu button. When you press this one you will have the menu displayed on screen. If you don't, your screen is dead and needs replacement under warranty or not. Otherwise, the other buttons are up, down, ok and exit. Figuring out which buttons are which of these is nothing but a headache and frustrating.
You need to access the menu, navigate your way around the many menus until you find the Reset or Restore Factory Presets. Or, even just words to that effect. Once you do find it, pressing it should bring your screen up to normal display, you can do this while your PC is off. After getting the Presets Reset, you could find the brightness and contrast adjustments. Normally, you want Brightness at 100% and Contrast at 50%. Gamma adjusts the white level of your display, so don't mess with that until you are in Windows once again and can see your desktop on your display.
If your screen is tinted either Red or Green and even Blue for that matter your plug at the monitor is loose, use a flat blade screwdriver to tighten the plug down, same at your PC connector.
If you can't get to any of these places after trying everything for a first, second and third attempts, your flat panel has problems and needs service/replacement under warranty or not. LET ME KNOW this so I can assist you.
Other wise if its working again, go to this page and choose a download from link and once this program is downloaded, install it and run the program to make final adjustments or examine the test patterns to see if your flat panel is working as expected or not.
Regards,
Worldveet
Aug 03, 2008 | Compaq Presario 700 470024-192 Notebook
HP Compaq Presario F730US Notebook Logo
378 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
