Question about Dell Dimension 2400 PC Desktop
Have a used dell dimension 2400, hard drive died i replaced it, but i dont have the original os disc that came with the system, can i use my copy of vista, or find another copy
On startup after the dell logo screen , it will go to a black screen with a blinking cursor, or boot device menu screen with 8 choices 1 normal 2 diskette drive 3 hard disk drive c 4 ide cd rom device 5 usb flash device 6 system setup 7 ide drive diagnostics 8 boot to utility partition. And final I upgaded the hd drive from 40 gb to 320 gb and ram from 768 mb to 1 gb
  • Dell Master
  • 32,281 Answers
If your Dell computer had Vista installed then you can use your copy of Vista CD and you can use the product installation code that is printed on the Windows label that is attached to your Dell.
When you insert the Windows CD into your Dell and boot up your computer then select the CD as the boot device (ie 4=IDE CD).
After Windows is installed and activated then you need to install the Dell computer's device drivers.
You can download the device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Posted on Jan 21, 2013
frcs68
  • 1605 Answers
SOURCE: Dell Precision 470 Dual Processor
enable "auto" in BIOS for drive #0 and drive #1. you can select IDE or SATA drive. restart the machine.
Posted on Dec 10, 2008
  • 166 Answers
SOURCE: pc won't boot
Any leaking brown stuff means blown capacitors- DELL (along with other manufacturers) were sold some "fake" capacitors and they didn't have all the correct ingredients to perform like they should. After about 2-3 years of use they started to break. DELL was replacing them mobos for awhile, even after the warranty ran out, but that deal is probably over. I know because I was able to replace several of them - out of warranty.
As far as your hard drive goes, Do you have an IBM Deskstar, also a.k.a as DeathStar? If it says it can't find the hard drive and you did not change the cables or mess with the jumpers and you have checked that the cables did not come loose from the motherboard and drive, then you most likely have a dead drive. You can always try to recover from the recovery console using CHKDSK. I have recovered a few drives this way. If you do recover then get your files off immediately.
Posted on Mar 09, 2009
crapiemael
  • 241 Answers
SOURCE: Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
Posted on May 28, 2009
  • 7 Answers
SOURCE: Dell DimE310 wont reeboot
try this unplug your machine,take off the side cover,there is a jumper near the battery for the cmos,it has three pins,remove from pin 1&2
and place on 2&3,remove an return to the original position.
plug in and restart,at startup press F2,scroll to boot sequence and press enter,change order to (1)CD,(2) IDE hard drive(3) SATA hard drive,save and exit.
Posted on Jul 01, 2009
  • 998 Answers
SOURCE: no boot device available stike
Your computer cannot find a boot-able storage device, i.e. hard disk drive, to boot from. Either your hard disk drive is defective or the OS (operating system software) is corrupted and needs to be re-installed.
Posted on Jul 27, 2011
Problems to obtain a complete system boot at first try.
See if you can boot to safe mode. Run check disk on the hard drive. Make sure the BIOS battery is ok.
Oct 29, 2017 | Dell Computers & Internet
How to delete console port and telnet passwords through BootROM?
1. Connect a PC to the device with a serial cable and log in to the device through the console port.
2. Restart the device. When the message "Press Ctrl+B to break auto startup ..." is displayed, press Ctrl+B and enter the password to display the BootROM main menu.
3. Select choice 4 to enter the Startup Select menu.
4. Select choice 1 to view the system configuration.
In V200R001C01SPC300 and later versions, you can use the following method to view the configuration file. In Huawei V200R001C01SPC300, the menu choice is Startup Information. In Startup Information and later versions, the menu choice is Display Startup.
Startup Select
1. Display Startup
2. Set Boot File
3. Set Config File
4. Startupfile Check Manage
0. return
Enter your choice (0-4):1
************** Current Stratup info ****************
Valid Flag State : Vaild
Boot File Name : sd1:/software.cc
Config File Name : sd1:/vrpcfg.cfg
Licence File Name :
Patch State : Deactivate
Patch File Name :
Voice File Name :
In V200R001C01SPC200 and earlier versions, the configuration file cannot be viewed. The system often uses the file vrpcfg.zip or iascfg.zip.
5. Rename the configuration file.
6. Restart RouterA.
7. Stop Auto-Config.
8. Change the renamed configuration file to executable file. Select one file format.
9. Restore the configuration.
Aug 19, 2015 | Computers & Internet
Error code: 1000-0143
I would suspect hdd errors and replace the drive.
Sep 06, 2014 | Dell Computers & Internet
Have used dell dimension 2400 hard drive died replaced it now it only goes to boot device menu or black screen with blinking cursor
You will a full blown version of whatever software you want to install. Also try using the F8 key during bootup. See if the computer will boot up into Safe Mode. You should be able to made System restore disks from there if it will get that far.
Jan 21, 2013 | Dell Dimension 2400 PC Desktop
Laptop goes blank on startup but still display logon screen
Have you upgraded the OS? At boot start tapping the F-2 key, do not wait for the Dell screen. Take a look at this forum:http://www.computing.net/answers/windows-95/dell-s-bios-startup-screen/85976.html
Nov 22, 2012 | Dell Inspiron Computers & Internet
I dont have a hard div
Hard Drive
Oct 21, 2012 | Dell Dimension 2400 PC Desktop
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
What's your problem?i have a dell optiplex 755 (tower).. it was working fine.. but one day when switched it on,, it doesnt behave normal.. and no screen was showing on the monitor.. the pc was sho
Welcome to the world of Windows 7. Don't you miss Windows XP? LOL, Windows 7 is a nightmare just like Vista.
Anyway I think it's your Memory. You mentioned moving the memory chips around, but you didn't mention trying one at a time. I think one of them is bad.
Memory ChipRemove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.Try just working with one of them in Slot 1 and swap them out in just Slot 1.
Oh, I just thought of something else, Maybe you have bad Capacitors on the motherboard. Remove the Power Cord, Remove the Case. Take a flash light and look inside the computer at the capacitors. They look like little Battery Towers. If any of them are spewing corrosion out of them, they can cause the computer to go crazy just like yours is doing.
Apr 22, 2012 | Dell Computers & Internet
My Dell Dimension 2400 has stopped working - how do i restore the factory settings ?
It appears your model Dell 2400 should have been supplied with the CD's for reinstalling Windows XP, CD will be green or blue in color and the drivers and applications that came with the computer.
If so, back up your files first to an external drive and then put the CD in the CD drive and reboot the computer. It should come up to reinstall XP.
If good to go, you will be prompted to install the second Cd as well as online XP updates.
Software that was installed after you bought the computer also wouyld have to be reinstall as well as restoring your backed up file.
Rememberm all data is lost when you reinstall your operating system, unless these is a choice on install that may ask for destructive, or non-destrutive (keeps files).
I am attaching a link to Dell for your to copy and paste into your web browser for the support page for drivers and user guide in the event you need to reveiw the process.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Sep 06, 2011 | Dell Dimension 2400 PC Desktop
No boot device available stike f1 to retry boot and f2 for setup utility diskette drive 0 seek failure a dell dimension 2400 series
Jul 27, 2011 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
60 people viewed this question
Alun Cox
