Question about Bosch B20CS51SNI Stainless Steel Side by Side Refrigerator
Is my Bosch water tube supposed to be hot? - Bosch B20CS51SNI Stainless Steel Side by Side Refrigerator
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
I am guessing your question about the "water tube" you mean the water line coming into your refrigerator. If this line is hot it is likely that it is connected to a hot water line instead of a cold water line. This will cause longer freeze times for your ice maker and longer time to cool drinking water, if you have a water dispenser. This is consuming more energy raising your utility expense every month. I recommend you find a cold water line to connect to. If you are comfortable doing this you can purchase everything you need at either of the big box stores, if not then I suggest you call a good plumber.
Posted on Jan 21, 2013
Heating coils were replaced last december and today no hot water for a shower after 5 minutes in the shower. The electric is flying on the meter. Have shut off the circuit breaker for this hot water
Copy following link for tank-type electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#skyrocket
Press reset button located on upper thermostat.
Test elements for short to ground against steel tank.
Clean sediment out of tank. Check for water leak running hot water out of tank.
Replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Nov 25, 2012 | Rheem Water Heaters
Need install guide for bosch dishwasher model smu 2042 uc Need to know if it suppose to hook up to cold or hot water?
Welcome to FixYa.
The dishwasher must be connected to an adequate hot water supply.
Adequate meaning a good strong rate of flow and pressure of hot water.
That should answer your question. Thank you for choosing FixYa.
Good luck.
Regards,
Macmarkus :)
Sep 04, 2010 | Bosch 24 in. SMU20 Built-in Dishwasher
Difficult to turn the water heater
step one... remove from wall
step two... throw in dumpster
step three... purchase and install a quality tankless water heater.
Rinnai, takagi, Noritz are the only brands I install now. Aquastar (Bosch) always had problems, then purchased by Bosch but never fixed the problems, just put their name on it and sold them at Lowes or home depot.
Garbage!
Jul 31, 2010 | Bosch & Tankless LP Hot Water Heater
I have a Bosch GWH 425 HN Tankless Hot Water Heater...On 2/28/2010, it began intermittant exploding when demand for hot water occurred. Local technicians worked on the unit several times, changed and...
I have the same problem with the same model. The problem has been identified by a friend of mine, correctly, I think.
This is a very dangerous problem involving Bosch's much touted safety feature, ironically enough. IT IS THE FLAME SENSOR IN THE GAS VALVE. The flame sensor is supposed to confirm that the pilot has lighted BEFORE the main gas line sends gas to the main burners, after which the pilot shuts off. The pilot light is not coming on, the sensor that shouldn't let gas fto the main burners is failing and the main gas is flowing and ignighting from the spark that is supposed to light only the pilot in a big explosion.
This is the 2nd unit of this model that has failed. I think Bosch should do a recall
Apr 25, 2010 | Bosch & Tankless LP Hot Water Heater
My bosch washing machine has taken to only allowing washing at 30 degrees. When a higher temperature is requested, no water flows into the machine. Any ideas why?
Clogged/defective/burnt out hot water valve. Disconnect hot water hose and clean the filter in the valve inlet. If this did not help, check if there is power to the hot water valve when it's supposed to fill. If there is power, but no water is coming into the washer - replace the valve.
Apr 10, 2010 | Washing Machines
Does the unit suppose to retain the water?
No. The unit is not supposed to retain water. By product of a/c or
refridgeration is water due to air being cooled below dew point of air.
(Check your uninsulated cold water pipes on a hot, humid day. They
are usually sweating.) The tubing should be routed to drain or outdoors.
Jul 24, 2009 | GE APH10AA Air Conditioner
My Bosch on demand water heater is clogged. I cleaned the inlet line but seems to be inside the smaller copper tubing. HELP!
If you can access the pipe that is clogged, Poor some lime away into it . Let it sit and ad more as needed. the calcium will sofen and ca be flush out. Takes patience. Once you get some flow, fill the tubing with a descaling solution (hardware store) and let it sit. Pool acid works but must be thoroughly flushed out. be careful with acids, always wear gloves.
May 02, 2009 | Bosch & Tankless LP Hot Water Heater
Bosch 1600h NG not heating water hot enough
it sounds to me like the dip tube has failed. this is a plastic tube that is inside the water heater on the cold side. It is designed to put the incoming cold water at the bottem of the tank allowing heated water out at the top. when this tube deteriorates the cold water mixes at the top of the tank instead of the bottom. a new dip tube is about 5 bucks but must be inserted on the cold side by someone with plumbing experience.
Jan 08, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
SHU43C02UC
Dishwashers don't heat water to clean dishes. It is supposed to be hooked to the hot water line, make sure it is the hot water line.
Sep 26, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch B20CS51SNI Stainless Steel  Side by Side Refrigerator Logo
240 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
