Question about Epson Stylus Office Equipment & Supplies
Epson Stylus NX515 printer is out of alignment and smeary copy
When I print the right side of the copy is out of alignment and there is an area that has smeary print
  • Epson Master
  • 511 Answers
Only at the right side?? Check the linear encoder (plastic strip behind the carriage). It's for "horizontal measuring". Try to print without high speed option (printing only one direction).
Posted on Jan 21, 2013
SOURCE: Epson Stylus C86 won't print
The ssc program doesn't work if your ink light is solid red.
Posted on May 01, 2008
Ajkill
  • 2035 Answers
SOURCE: white lines on printed photos Epson Stylus NX400
You need to clean the print head on the cartridges , please follow these steps\
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Mar 15, 2009
  • 700 Answers
SOURCE: my r230 photo printer epson stylus was sevice required unable to print and see your printer documents
Reset your printer. Look for printer resetter , its a utility third party program. Or in search of web browser just key in " epson reset software"
Posted on Apr 17, 2009
  • 26 Answers
SOURCE: epson stylus dx4000 printing blank pages . how do
replace cartriges, clean printers heads from utility menu
Posted on Oct 25, 2009
cns assoc
  • 677 Answers
SOURCE: EPSON Stylus SX600FW printer. Recently changed
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 30, 2010
Blurry orinting
go to printer settings and go to print configuration and run set up for new cartridges, to align cartridge heads.
Mar 13, 2014 | Epson Stylus NX515 All-In-One InkJet...
Have nx515 epson printer that will not print in black.Replaced with new still no black. Fix?
Do a head aliment page to test the nozzle operation.
The line on the test page should be in black and white.
Jan 15, 2014 | Epson Stylus NX515 All-In-One InkJet...
Color red not printing
Magenta ink of color cartridge finished, may due to more use of red prints. Replace cartridge.
Jun 22, 2013 | Epson Stylus NX515 All-In-One InkJet...
I have an epson stylus 515 i print something and i comes out blank what would you think it could be
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Nov 18, 2012 | Epson Stylus NX515 All-In-One InkJet...
EPSON STYLUS CX 7800 HOW DO I ALIGN THE HEADS??
1. Turn on the Epson Stylus CX7800
2. Load several sheets of paper
3. Windows: Right-click the printer icon on you taskbar (in the lower right corner of
your screen). Select Print Head Alignment.
Macintosh OS X: Open the Applications folder and select Epson Printer Utility.
Select your Expson Stylus CX7800 in the printer list, click OK,
and select Print Head Alignment.
Jan 15, 2011 | Epson Office Equipment & Supplies
I replaced 2 cartidges. When I replaced the magenta the printer kept doing fine. When I replaced the black 20 minutes after the magenta it doesnt recognize the cartidge and I put another black cartidge...
Make sure there is nothing between the print cartridge and the place where it goes. Make all the plastic is removed from the cartridge. If you have a can of air, blow out the cartridge area.
Sep 04, 2010 | Epson Stylus NX515 All-In-One InkJet...
Will linksys wirless g print server woork with epson cx4800 printer
Yes,
This is a USB All-In-One printer and the Linksys Wireless G Print Server supports USB pprinters.
However,
For the cost of the Linksys print server, you can purchase an Epson NX515 that has built-in WiFi. It would also be less hassle if the Linksys/CX4800 has a problem. You would not know which device is causing the problem.
Oct 08, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Help! Prints a smeary mess!
it depends on the type of paper you are using.
ink chemicals react to the chemicals on the photo paper.
manufacturers have ¨recommended papers¨ : )
recommendation: ask for paper samples from paper vendors
Jan 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
75 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
