Question about Kenmore Elite 21086
Seems like my dryer gets over heated and quits working
My dryer is overheating and shutting off.
  • norahix Feb 07, 2009
    My dryer overheated and blew the fuse. The repairman said it was a venting problem. He replaced the fuse inside the dryer. Four loads later it happened again. We had checked the vent and that is not the problem.
Make sure the transition vent pipe that conntects the dryer to the vent opening in your floor or wall is the shortest it can possible be and that it is not crushed between the wall and the dryer. Installing a metal transition vent pipe is the safest and most efficient. Next, your vent pipe inside the wall and to the outside should be made of metal--if it is plastic or foil, it should be replaced. How did you check your vent? A simple test is to cut a piece of paper about 2 inches by 2 inches--place the piece of paper in the empty dryer and turn it on. Let it run for about 30 seconds and open the door--if the paper is sticking to the back of the drum, this tells you that there is air being exhausted from the dryer into the vent. Also check the lint tray--it can be full of lint that obstructs air flow. Remove the lint screen and shine a light into the lint tray--if there is lint accumulated, clean it out. Finally, make sure there are no screens or other obstructions over the exhaust opening outside. While the optimum is to have the vent cover open 100%, there should be enough air flow so that you feel at a minimum, the equivilent of a 10-mph breeze; more is better. Getting the proper air flow is important to achieve the maximum efficiency from your dryer. Since there are so many dryers and vent configurations, you will have to determine if your vent is installed properly. A vent that is too long or that has too many 90-degree turns can cause problems as well. I agree with your repairperson that it sounds like a vent problem. If in doubt, have a dryer vent professinal look at it--they will advise you if it needs cleaning or repair. Once you have eliminated the dryer vent completely, then you can address other issues with your dryer.
Posted on Mar 01, 2009
  • 130 Answers
Usually is the thermostat not working properly.
Posted on Jan 26, 2009
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
The Dryer is starting, but shuts off after 10-15mins. It seems to be very hot. Is there an overheating element or something that can be easily replaced?
This certainly sounds like an overheating element. The problem is that the element is working. Something is allowing the element to get too hot. Then your over-limit switch is sensing the fire hazard and shutting down the system. Safety in action.
I suspect your blower fan is not running. This fan keeps the heating element from over heating by blowing the heat to the clothes in the drum. This is easily checked. The very next time you attempt to dry a load, start it and go to the exhaust vent outside. Put your hand close to it. See if it is blowing air or not. No air blowing = shut down in 10 minutes.
The blower motor should not be too hard to replace. Surely easier than the element itself. Before you pull the motor, use a multimeter to confirm that power is getting to the motor first. Power yes, motor running no, replace it.
Could also be something simple, like a wire broken or pulled off of the motor. That is why you check first. Good luck
Dec 06, 2009 | Dryers
I have an similar problem with my Amana Dryer LEA30AW.
First Clean out your filter, Assuming the element is okay and cut-out are fine it should run okay, you could also try running it on low heat will take a bit longer but hey if it works great..Good luck
Oct 01, 2009 | Dryers
My GE DVLR223ee0ww electrical dryer shut off after while
blow lint out of motor with compressed air.... vacuum will not work well here
Aug 14, 2009 | GE DVLR223 Dryers
Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Jul 06, 2009 | Kenmore 73952 Gas Dryer
Dryer runs heat and spin then shuts off timer continues to run but do not restart dryer.
Reach inside and turn the drum by hand. If it seems stiff then the rollers or glides need replacement. If the drum is pinching then that makes the motor get hot and quit.
Jun 11, 2009 | Dryers
Maytag Dryer quit working mid cycle
sounds like the timer,the only thermal fuse i know of is to protect from overheating which cools and resets itself
May 10, 2009 | Maytag PYE2300AY Electric Dryer
Gas dryer seems to be overheating
The first and easy thing to check is the vent going out of the house if it is restricted or cloged it will over heat and shut off check that first
Mar 28, 2009 | Maytag MDG6400 Atlantis Gas Dryer
Low heat, not drying
There´s a sensor inside that controls the temperature in order to prevent overheating.
Mostly they work with resistance. Oxydation can influence the resistance value, as like as some fluff.
Second option: you have perhaps not only one heating coil, perhaps one is not working.
Sep 19, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Washing Machines Logo
102 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
