Question about Epson Stylus Photo R800 InkJet Printer
Clogged print heads
We purchased a used printer and got home to find that apparently there has been some kind of leaking in the past, there is a lot of ink build up under the print heads, at either end of the printer (under the ink cartridge holder "home" and the other end). This leads me to believe that the ink is also covering and clogging the underside of the ink cartridge holder, and so too.. the heads/jets/nozzles. Is there a way we can A) disassemble and clean the mess and B) ensure that this kind of thing doesn't happen again?
  • Epson Master
  • 511 Answers
Sure, you can do it. And it will happen again for long time using. Usually, it happened if using non dyes ink, like pigment ink.
Posted on Jan 21, 2013
  • karen_lancas
    karen_lancas Jan 23, 2013
    This is what we are most likely going to have to do. There is nothing able to get from the injectors to the paper because of the clogging. So we will tear it apart and clean every inch,
  • Anjazmoro Wicaksono
    Anjazmoro Wicaksono Jan 23, 2013
    There is nothing........ Nothing at all? Do head cleaning, and see at oultet pipe of head cleaning pump. Is there ink "out" from the pipe? If yes, and nothing at all print out, problem is in head and/or mainboard.
4 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: epson 440 won't print
The ink dried up in the print head. A printer should be used at least every two weeks to keep from drying up the ink. You may have to replace the print head or have it serviced.
This is not much help. Bud
Posted on Jan 25, 2009
tigertail
  • 163 Answers
SOURCE: Not printing magenta ink and tried cleaning heads already
Hi, one or two head cleans won't clear a clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Hope this helps.
Please take a moment to rate this solution, thanks.
Posted on Mar 28, 2009
desertrat144
  • 22 Answers
SOURCE: Epson 4800 clogged
I've had similar fun(?) with my Epson. The best solution that I've found is getting by a drafting (or crafts) supply store and getting a jar of Rapiograph, Koohinor, or drafting pen cleaner. With any kind of luck all you'll need to do is 'flood' the print head a bit (let the solution pool around the cartridge intakes), and set a few minutes, then do the Nozzle check.
The next step if that doesn't get it, is to get an old 'empty' cartridge, add a teaspoon or so to the cartridge, then insert as usual- be quick, as the ink inside has been greatly diluted!
Cycle the printer off & on several times allowing 3-5 minutes between the first & second cycles. What happens during cycling is the printer 'charges' then 'empties' the internal ink tubes; the solution is drawn back and forth, washing out the tubes and jets.
Make sure that your cartridges are 20+% full when using them to print. Epson was one of the bad guys that showed empty ink supplies when they were still full.
Hope this helps.
Posted on Sep 13, 2009
The head cleaning cannot be completed by the printer?
Epson printers use a lot of ink to do head cleaning. If you're low on ink, it will give you that message. Put in new ink carts, and head cleaning will happen. You may want to purchase "cleaning carts" that have a special solvent to help un-clog the print heads.
Sep 11, 2014 | Epson Office Equipment & Supplies
Printer prints every 2nd or 3rd line of a Word Document in pale gray ghostly way
Ink jets may be clogged, go into your printer software for the canon. At someplace in there there should be an option to run the cleaning program on the printer. This is used to clean out the jets and clean up the printer a little bit. Make sure that you have lots of ink, Cleaning process uses a lot ink
Nov 29, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
I replaced the color catridges of my Epson C84 with full compatible non Epson brands. The cyan works all right but the yellow and magenta's don't. The nozzle test displays vague black strokes. Could the...
The ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away.
Here's how to clear blocked print heads, given you've run the cleaning of the print heads or nozzles from the printer at least 5 times:
-remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Feb 03, 2011 | Epson Stylus C84 InkJet Printer
I replaced my black ink cartridge and the printer will not print. I tried shaking the new cartridge. I purchased an Office Depot cartridge #TO529
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any ink-jet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
If after that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 12, 2010 | Dell Inkjet 720 Printer
Bad print
This may be because ink is clogged in the printhead. ? Place the clogged cartridge in about 1/4 - 1/2 inch of warm water for a few minutes. When ink starts to slowly leak out take the cartridge out of the water and dry it using a soft cloth to "Q-tip." Then place it back in your printer and run the print head cleaning utility that comes with your printer software. You may have to run this 2-4 times before printing quality is reestablished. If your print head is destroyed, as can happen, you will have to buy a cartridge and refill that cartridge before it is fully empty.
Feb 19, 2010 | Epson Stylus CX3810 All-In-One InkJet...
A blank page when coping or printing in black. New black & yellow ink installed. Cleaned print heads, run all the diagnostics, but no black shows up. Cyan, magenta & yellow print, but no black.
As with all of the solutions I've provided on this and the other HP88 printers, the problem is that the black printhead has become clogged due to the conditions the printer is kept in.
For some reason the pigment black ink in the HP88 printhead is particularly prone to clogging when used in hot, dry conditions where there is air conditioning or similar...
The only solution I have found to date is to replace the black ink with a dyebase alternative and use that with a new printhead. Finding this solution took me about 14 printheads and a lot of head scratching so it wasn't easy...
Finding a dyebase alternative may be difficult but whatever you do, make sure you purchase a remanufactured original HP OEM, not one of the all plastic designs with no black rubber bulb in the bottom of the printer. They fail and leak a LOT!.
Hope that helps..
Martin
Jul 10, 2009 | HP Officejet Pro L7680 All-In-One Printer
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
Hi, I have an Epson Stylus 4000 printer at home. I had no problem printing high quality prints untill now. I thought that my nozzles were clogged (I haven't use it to print for a several months), so I...
print head clogged..if you remove it try cleaning it...or sink it in a boiled water to released clogged.....used tissue on cleaning...maybe its effective coz i repaired same printer you have...
Aug 27, 2008 | Office Equipment & Supplies
Print Head Problems
Try cleaning the print hade sensor useing alcohol.it is by the home position whera the print hade is installed.
Apr 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
No black print outs
Run the software cleaning utility (almost always accessible from the printer) in order to fix a clog. Replace the ink cartridge if the clog cannot be fixed or if the cartridge is almost empty. A way to physically clean the clog is using a q-tip dipped in rubbing alcohol and wiping it on the printer cartridge head.
Jul 23, 2007 | Brother MFC 210C All-In-One InkJet Printer
Epson Stylus Photo R800 InkJet Printer Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
